    MMM-NewsFeedTicker
    94 Posts 15 Posters 90.0k Views 14 Watching
      sdetweil @Giarry88
      @Giarry88 ok, I hate this thing.
      npm run config:check
        sdetweil @Giarry88
        @Giarry88 said in MMM-NewsFeedTicker:
        What does “check.config” do?
        It checks the config.js file
        • G
          Giarry88
          @sdetweil said in MMM-NewsFeedTicker:
          Ok, i’ve checked and corrected it with geanie and now the syntax is correct but it still doesn’t show it on mm
            sdetweil @Giarry88
            @Giarry88 open the developers window ctrl-shift-i on the keyboard, and select the console tab and scroll up to see any errors.
            • G
              Giarry88 @sdetweil
              yes,
              Load script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
              :8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
              loader.js:187 Error on loading script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
              script.onerror @ loader.js:187
              loader.js:194 Load stylesheet: css/custom.css
              (index):1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
              loader.js:203 Error on loading stylesheet: css/custom.css
                sdetweil @Giarry88
                @Giarry88 sounds like u didn’t install the module in the right place
                • G
                  Giarry88 @sdetweil
                  I’ve nstalled it in the Modules folders (outside of the Default folder, correct?)
                    sdetweil @Giarry88
                    @Giarry88 :8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                    says file not there
                    you can get rid of this one by creating an empty custom.css (my installation script does this)
                    touch ~/MagicMirror/css/custom.css
                    • G
                      Giarry88 @sdetweil
                      says file not there
                      so…
                      I created the custom.css (but I’ve added the command for removing the borders, because I had it in the main.css - yes…i know…my bad :grimacing_face: - also it seems I can’t remove the spacing at the top, but this is a ittle bit OT) now as you said it previously that error disappeared.
                      Now I have only
                      GET http://localhost:8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js net::ERR_ABORTED 404 (Not Found)
                      But this morning I’ve installed an other module (MMM-networrk-signal) in the same way and it is working properly
                      Load script: modules/MMM-network-signal//MMM-network-signal.js
                      Module registered: MMM-network-signal
                      I am confused…
                      EDIT
                      My mistake was that I didn’t put capital letters in the name of the folder (I didn’t think it would have mattered)…
                      Now I can see the red bar with “Loading” and in the console it keeps showing :
                      MMM-NewsFeedTicker - unknown notification, ignoring: CLOCK_SECOND
                      MMM-NewsFeedTicker - received notification: CLOCK_SECOND
                        sdetweil @Giarry88
                        linux is case sensitive… windows is not
                        look in the console where u start ed MagicMirror
                        if pm2, the use the pm2 logs --lines=100 command to view the logs…
                        the error more than likely is a bad url, ???
                        • G
                          Giarry88 @sdetweil
                          I don’t know why, when I closed and Opened again Magic Mirror, it wasn’t working at all; so I started with the backup of the config file and now it is working everything, ticker included. I think that I just needed to remove the default feed (especially the url - I was asking him to load the same feed on both modules -).
                          Now I only have an issue with the stuttering ticker (but I’ve read something about it so I will try solving it by looking at those posts).
                          Thanks again sdetweil, especially for your patience!
                          • L
                            liquidevo
                            Hi love the module can anyone help me out ? I want each of the headlines to be longer sometimes it cuts the headline midway so I cannot read completly , and also anyone knows if I can add the qr code to this module ?
                            thank you
                            • Cr4z33C
                              Cr4z33
                              @justjim1220 I’ve moved to a NUC and your module is now scrolling incredibly smooth. :D
                              Only can you please tell me what to edit to avoid scrolling from right to left (after having scrolled from left to right)?
                              • Cr4z33C
                                Cr4z33 @Cr4z33
                                @Cr4z33 said in MMM-NewsFeedTicker:
                                @BKeyport sorry for always bothering you lol, but you look still quite active here in the forums (despite of other developers that might have left). :)
                                Do you know by chance what to edit here?
                                • BKeyportB
                                  BKeyport Module Developer
                                  I sure don’t, I’ve just started writing my own after running into the same problem as you.
                                  • cowboysdudeC
                                    So you guys got it figured out? :)
                                    • Cr4z33C
                                      Cr4z33 @cowboysdude
                                      @cowboysdude not yet. :neutral_face:
                                      • cowboysdudeC
                                        What are you trying to do?
                                        S Cr4z33C 2 Replies Last reply Reply Quote 0
                                          sdetweil @cowboysdude
                                          @cowboysdude make the ticket scroll left to right. I posted the solution in the other
                                          topic
                                          https://forum.magicmirror.builders/topic/13397/mmm-newsfeedticker-scroll-from-left-to-right-only/16
                                          • Cr4z33C
                                            Cr4z33 @cowboysdude
                                            @cowboysdude sorry for being late, but thanks for willing to help. :D
                                            @sdetweil going to check right now thanks.
                                            • 5 / 5
