    MMM-Random Fact
    Scheduled Pinned Locked Moved Education
    59 Posts 12 Posters 47.7k Views 11 Watching
    • cowboysdudeC
      @lavolp3
      https://github.com/cowboysdude/MMM-rfacts
      New api, tested and working :)
      C StoffbeuteluweS 2 Replies Last reply
      Reply Quote 2
        chassain 0 @cowboysdude
        @cowboysdude hello,
        Sorry but nothing to display after new install. Only “obtenir un fait…” (french)
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @cowboysdude
          @cowboysdude Sorry nothing is showing… only (Eine Tatsache bekommen) German
          • cowboysdudeC
            cowboysdude Module Developer @Stoffbeuteluwe
            @Stoffbeuteluwe Not sure why it’s working here… so if you can PM me and I’ll have you try something to see if it’s the api or something else. Thanks
              @cowboysdude hello,
              what can we do to check ? thanks…i have update (latest and stable) npm and the same result
              • lavolp3L
                lavolp3 Module Developer
                @cowboysdude Dude you’re ignoring all the debugging!
                (After including debug logs) I got the response code 503 from the API
                [2020-04-23 10:35:54.046] [LOG]    10:35:54 <log> Wrong response code: 503 (/home/pi/MagicMirror/modules/MMM-rfacts/node_helper.js:47 Request._callback)
                [2020-04-23 10:35:54.054] [LOG]    10:35:54 <log> {"statusCode":503,"body":"<!DOCTYPE html>\n<html>\n<head>\n<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n<meta charset=\"utf-8\">\n<title>Application Error</title>\n<script src=\"/cdn-cgi/apps/head/mRZC9wXQsm0r4xm9M3hblvWOKNw.js\"></script><style media=\"screen\">\n\t\t  html,body,iframe {\n\t\t\tmargin: 0;\n\t\t\tpadding: 0;\n\t\t  }\n\t\t  html,body {\n\t\t\theight: 100%;\n\t\t\toverflow: hidden;\n\t\t  }\n\t\t  iframe {\n\t\t\twidth: 100%;\n\t\t\theight: 100%;\n\t\t\tborder: 0;\n\t\t  }\n\t\t</style>\n</head>\n<body>\n<iframe src=\"//www.herokucdn.com/error-pages/application-error.html\"></iframe>\n</body>\n</html>","headers":{"date":"Thu, 23 Apr 2020 08:35:53 GMT","content-type":"text/html; charset=utf-8","transfer-encoding":"chunked","connection":"close","set-cookie":["__cfduid=dba2fb4d60e085d460cd31721c37883191587630953; expires=Sat, 23-May-20 08:35:53 GMT; path=/; domain=.sameerkumar.website; HttpOnly; SameSite=Lax; Secure"],"cache-control":"no-cache, no-store","cf-cache-status":"DYNAMIC","expect-ct":"max-age=604800, report-uri=\"https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct\"","server":"cloudflare","cf-ray":"588640f1695a0026-LHR","cf-request-id":"0247c6eadf000000267690a200000001"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"useless-facts.sameerkumar.website","port":443,"hostname":"useless-facts.sameerkumar.website","hash":null,"search":null,"query":null,"pathname":"/api","path":"/api","href":"https://useless-facts.sameerkumar.website/api"},"method":"GET","headers":{}}} (/home/pi/MagicMirror/modules/MMM-rfacts/node_helper.js:48 Request._callback)
                [2020-04-23 10:35:54.064] [LOG]    10:35:54 <log> null (/home/pi/MagicMirror/modules/MMM-rfacts/node_helper.js:49 Request._callback)
                I guess my pre-posters have a similar experience.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                lavolp3L 1 Reply Last reply
                • lavolp3L
                  lavolp3 Module Developer @lavolp3
                  @cowboysdude @chassain-0 @Stoffbeuteluwe
                  Its obviously an API problem. The API page returns an Application Error.
                  I guess we need another API.
                  How about this one?
                  https://uselessfacts.jsph.pl/random.json
                  It seems to use (at least) the german source “neon”.
                  I was actually looking for that for some time because neon has published a range of books called “useless facts”. FOund it accidentally just now.
                  It could be implemented and then translated from the source language to the user language.
                  If it uses all of neon’s facts there quite a lot.
                  If you don’t want to use this source, no problem, then I’d build an own module.
                    chassain 0 @lavolp3
                    @lavolp3 we can use this for the moment…and see after…the modul is so fine that i can 't work without :)//how integrate this new api ?
                    • lavolp3L
                      lavolp3 Module Developer @chassain 0
                      @chassain-0 I have it working but changed lots of things on the frontend and in node_helper.js. So need to check the changes again.
                      • lavolp3L
                        @lavolp3
                        PR sent
                        https://github.com/cowboysdude/MMM-rfacts/pull/12
                        It seems I have done a bit too much JS programming in recent months… Lol.
                        @cowboysdude have a look at it and let me know what you think.
                        Reply Quote 3
                          chassain 0 @lavolp3
                          @lavolp3 It works fine for me (in french) with the changes manualy
                          • cowboysdudeC
                            Thanks Guys…even with the world in chaos I am busy…VERY.
                            Thank you @lavolp3 working perfectly ;)
                            The new api I had gotten apparently ONLY works in the US for some reason…
                            • StoffbeuteluweS
                              Hi to all …thanks for your work, everything works nice
                              • K
                                kisagluk
                                Hey, first of all, awesome module and I really like it!
                                Thank you :)
                                One thing I see is that on my English system, from time to time I get facts in German.
                                For example in one run, I get 3 in English, number 4 is in German and then English again.
                                The behaviour is quite random, sometimes it’s a first one etc.
                                Any idea why this happens?
                                • 3 / 3
