    MMM-Multimonth
    calendarmagicmirror2module
    78 Posts 19 Posters 62.8k Views 17 Watching
    • BKeyportB
      BKeyport Module Developer
      MagicMirror Module to display a calendar with multiple months
      A mini-calendar with as many months as the user wants, assuming screen space is available.
      Download
      https://www.github.com/BKeyport/MMM-Multimonth
      [card:BKeyport/MMM-Multimonth]
      Installation
      Clone this repository in your ~/MagicMirror/modules/ folder ( $ cd ~MagicMirror/modules/ ):
      git clone https://github.com/BKeyport/MMM-Multimonth.git
      Using the module
        module: 'MMM-Multimonth',
      	position: 'top_left', // can be any of the postions
      	config: { // Optional - will default to 3 months, with one previous and one next.
      	  startMonth: -1, // Define when you start from current month (negative is before current, zero is current, positive is in future)
               monthCount: 3, //  How many months to display
               highlightWeekend: false // highlightWeekend if desired, set to true.
      Many thanks to kirash for the inspiration with the monthly_calendar module, sdetweil and lavolp3 for the help in coding and CSS work. Without your help, this would just be a pipe dream.
      This is a basic module, but I felt it was good enough for release to the public.
      Please, if you have any suggestions for improvement, let me know, I’m learning Javascript and CSS as I write this, and I dream of much bigger things.
      ~~Localization is provided by moment.js and controlled by the master language of MagicMirror. Please file any errors with localizations as bugs with the moment.js team - https://github.com/moment/moment/~~
      Please see github for version info and further instructions.
      BKeyportB 2 Replies Last reply
      Reply Quote 6
        ShoeBox
        @BKeyport this is great! Thank you. Is there a way to change the colors?
          matelot20
          @BKeyport I would like to know as well if the header color can be changed.
          • BKeyportB
            yes. It’s all in CSS. Take a look at the CSS file in the directory, and copy over to your custom.css
              PH1TCH
              @BKeyport Great MMM, exactly what I was looking for! :winking_face: Can the first day of the week be changed to monday?
              BKeyportB 1 Reply Last reply
              • BKeyportB
                BKeyport Module Developer @PH1TCH
                @PH1TCH It’s in the notes I haven’t figured out how to do this yet. Everything I’ve tried has failed due to API issues. I’m cracking on it when I can. My business takes priority, and we’ve been extended out due to this whole virus thing.
                P 1 Reply Last reply
                  PH1TCH @BKeyport
                  @BKeyport Okay, thanks for the update!
                  • W
                    Werner1340
                    Hello, how can I change the color from grey (days+numbers) from grey to white?
                    • BKeyportB
                      BKeyport Module Developer @Werner1340
                      @Werner1340 That’s actually a magicmirror default. I believe it’s getting it from here:
                      .normal {
                        color: #999;
                      W 1 Reply Last reply
                      • W
                        Werner1340 @BKeyport
                        @BKeyport Hm, i found that code in the main.css and changed the color to #fff.
                        …still grey color in calendar. ;-). any more Ideas?
                        • W
                          Werner1340
                          found it!
                          in main.css change:
                          body {
                          color: #fff
                          thx for the hint :-))
                          • BKeyportB
                            Werner: Don’t ever change main.css
                            use custom.css instead.
                            • BKeyportB
                              UPDATE:
                              I’ve pushed this to 0.9. Module now will change start of week fully.
                              Localization including start of week is provided by moment.js - translation errors and/or start of week issues (example: they have it on Sunday, but it should be Saturday) should be reported to them. https://github.com/moment/moment/
                              Thanks!
                              • BKeyportB
                                Update:
                                Now at 0.95 - Change of start of week was backwards. Whoops.
                                Localization still is provided by moment.js, data from it on start of week.
                                • BKeyportB
                                  Updates:
                                  0.99 - Thanks to Volker Wegert (Danke sehr!) - the code has become a lot more flexable and functional. He rewrote my work rather dramatically, and I absolutely love it.
                                  1.00 - Tweeks here and there to standardize.
                                  • BKeyportB
                                    Update:
                                    1.10 - Added leading and trailing months when 1 month is selected per user request.
                                    Forgot to mention, from 0.99 forward, new CSS system, color changes are now handled under my own CSS names.
                                    Please see the CSS file for examples - but remember, please put your changes in custom.css.
                                      A Former User
                                      • BKeyportB
                                        Please add this to your custom.css - I’ll test it and see if it works for global action, then update with next release.
                                          MC
                                          i like this module. i have a double display and show the whole year on 1 screen.
                                          My question:
                                          Is it possible to highlight the school holidays for my wife :-) ?
                                          greetings and thanks for this module !
                                          ? BKeyportB 2 Replies Last reply
                                            A Former User @MC
                                            Reply Quote -1
                                            • 1 / 4
