    Works with Node Serveronly but not npm start MM
    24 Posts 4 Posters 6.8k Views 4 Watching
      sdetweil @JohnBachini
      @JohnBachini is the browser ON the same system?
      how about opening chromium-browser on the same server to the server
      electron is all javascript…
      J 1 Reply Last reply
        JohnBachini @sdetweil
        Just tried it and it works in chromium on server !?
          @JohnBachini different version of javascript inside chromium…
            oh i see… Thanks again.
              bhepler Module Developer
              Please use the markdown features of the forum when posting code and/or error messages.
              lavolp3L 1 Reply Last reply
              • lavolp3L
                lavolp3 Module Developer @bhepler
                @bhepler Added code tags for better readability
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  try this
                  cd ~/MagicMirror/modules/MMM-synology-ds
                  npm install mmmagic
                    Tried , unfortunately doesn’t seem to have made any difference.
                    pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ npm install mmmagic
                    > mmmagic@0.5.3 install /home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
                    > node-gyp rebuild
                    make: Entering directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/apprentice.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/apptype.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/ascmagic.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/cdf_time.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/compress.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/der.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/encoding.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/fsmagic.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/funcs.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/is_tar.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/magic.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/print.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/readcdf.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/readelf.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/softmagic.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/fmtcheck.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcat.o
                      CC(target) Release/obj.target/libmagic/deps/libmagic/src/strlcpy.o
                      AR(target) Release/obj.target/deps/libmagic/magic.a
                      COPY Release/magic.a
                      CXX(target) Release/obj.target/magic/src/binding.o
                    In file included from ../src/binding.cc:3:
                    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                    ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                    ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>& ’:
                    ../src/binding.cc:184:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                                      (uv_after_work_cb)Magic::DetectAfter);
                    ../src/binding.cc: In static member function ‘static void Magic::Detect(const Nan::FunctionCallbackInfo<v8::Value>&)’:
                    ../src/binding.cc:217:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    In file included from ../src/binding.cc:1:
                    ../src/binding.cc: At global scope:
                    /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                           (node::addon_register_func) (regfunc),                          \
                    /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
                       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                    ../src/binding.cc:415:3: note: in expansion of macro ‘NODE_MODULE’
                       NODE_MODULE(magic, init);
                    In file included from /home/pi/.cache/node-gyp/10.20.0/include/node/node.h:63,
                    /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                    /home/pi/.cache/node-gyp/10.20.0/include/node/node_object_wrap.h:84:78:   required from here
                    /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                    reinterpret_cast<Callback>(callback), type);
                    /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                    ../../nan/nan_object_wrap.h:65:61:   required from here
                    /home/pi/.cache/node-gyp/10.20.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callbac ’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                      SOLINK_MODULE(target) Release/obj.target/magic.node
                      COPY Release/magic.node
                    make: Leaving directory '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build'
                    + mmmagic@0.5.3
                    updated 1 package and audited 14 packages in 18.498s
                    found 0 vulnerabilities
                    pi@MagicMirror:~/MagicMirror/modules/MMM-synology-ds $ cd …
                    pi@MagicMirror:~/MagicMirror/modules $ cd …
                    pi@MagicMirror:~/MagicMirror $ npm start mm
                    > magicmirror@2.11.0 start /home/pi/MagicMirror
                    > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "mm"
                    [2020-04-28 14:26:28.842] [LOG]    Starting MagicMirror: v2.11.0
                    [2020-04-28 14:26:28.849] [LOG]    Loading config ...
                    [2020-04-28 14:26:28.855] [LOG]    Loading module helpers ...
                    [2020-04-28 14:26:28.857] [LOG]    No helper found for module: MMM-Logging.
                    [2020-04-28 14:26:28.860] [LOG]    No helper found for module: alert.
                    [2020-04-28 14:26:28.895] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:28.896] [LOG]    Module helper loaded: updatenotification
                    [2020-04-28 14:26:28.896] [LOG]    No helper found for module: clock.
                    [2020-04-28 14:26:28.897] [LOG]    No helper found for module: MMM-OpenmapWeather.
                    [2020-04-28 14:26:28.898] [LOG]    No helper found for module: weatherforecast.
                    [2020-04-28 14:26:29.198] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:29.199] [LOG]    Module helper loaded: MMM-Tools
                    [2020-04-28 14:26:29.200] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                    [2020-04-28 14:26:29.202] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:29.202] [LOG]    Module helper loaded: mmm-hue-lights
                    [2020-04-28 14:26:29.204] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:29.205] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                    [2020-04-28 14:26:29.360] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:29.361] [LOG]    Module helper loaded: MMM-Hotword
                    [2020-04-28 14:26:30.447] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.447] [LOG]    Module helper loaded: MMM-AssistantMk2
                    [2020-04-28 14:26:30.449] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.449] [LOG]    Module helper loaded: MMM-Assistant2Display
                    [2020-04-28 14:26:30.836] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.836] [LOG]    Module helper loaded: MMM-Parcel
                    [2020-04-28 14:26:30.909] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                    was compiled against a different Node.js version using
                    NODE_MODULE_VERSION 64. This version of Node.js requires
                    NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                    the module (for instance, using `npm rebuild` or `npm install`).
                    [2020-04-28 14:26:30.910] [LOG]    Loading module helpers ...
                    [2020-04-28 14:26:30.911] [LOG]    No helper found for module: MMM-Logging.
                    [2020-04-28 14:26:30.911] [LOG]    No helper found for module: alert.
                    [2020-04-28 14:26:30.912] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.912] [LOG]    Module helper loaded: updatenotification
                    [2020-04-28 14:26:30.912] [LOG]    No helper found for module: clock.
                    [2020-04-28 14:26:30.913] [LOG]    No helper found for module: MMM-OpenmapWeather.
                    [2020-04-28 14:26:30.913] [LOG]    No helper found for module: weatherforecast.
                    [2020-04-28 14:26:30.914] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.914] [LOG]    Module helper loaded: MMM-Tools
                    [2020-04-28 14:26:30.915] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                    [2020-04-28 14:26:30.915] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.915] [LOG]    Module helper loaded: mmm-hue-lights
                    [2020-04-28 14:26:30.916] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.916] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                    [2020-04-28 14:26:30.916] [LOG]    Module helper loaded: MMM-Hotword
                    [2020-04-28 14:26:30.917] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.917] [LOG]    Module helper loaded: MMM-AssistantMk2
                    [2020-04-28 14:26:30.918] [LOG]    Initializing new module helper ...
                    [2020-04-28 14:26:30.918] [LOG]    Module helper loaded: MMM-Assistant2Display
                    [2020-04-28 14:26:30.918] [LOG]    Module helper loaded: MMM-Parcel
                    [2020-04-28 14:26:30.924] [ERROR]  App threw an error during load
                    [2020-04-28 14:26:30.925] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                        at process.func (electron/js2c/asar.js:138:31)
                        at process.func [as dlopen] (electron/js2c/asar.js:138:31)
                        at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
                        at Object.func (electron/js2c/asar.js:138:31)
                        at Object.func [as .node] (electron/js2c/asar.js:138:31)
                        at Module.load (internal/modules/cjs/loader.js:645:32)
                        at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                        at Module.require (internal/modules/cjs/loader.js:685:19)
                        at require (internal/modules/cjs/helpers.js:16:16)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/lib/index.js:1:13)
                    [2020-04-28 14:26:30.926] [LOG]    Whoops! There was an uncaught exception...
                    [2020-04-28 14:26:30.926] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                    [2020-04-28 14:26:30.930] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-04-28 14:26:30.930] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [2020-04-28 14:26:31.008] [LOG]    Launching application.
                    ^C[2020-04-28 14:26:54.721] [LOG]    Shutting down server...
                    [2020-04-28 14:26:54.725] [LOG]    Stopping module helper: updatenotification
                    [2020-04-28 14:26:54.726] [LOG]    Stopping module helper: MMM-Tools
                    [2020-04-28 14:26:54.726] [LOG]    Stopping module helper: mmm-hue-lights
                    [2020-04-28 14:26:54.727] [LOG]    Stopping module helper: MMM-homeassistant-sensors
                    [2020-04-28 14:26:54.728] [LOG]    Stopping module helper: MMM-Hotword
                    [2020-04-28 14:26:54.728] [LOG]    Stopping module helper: MMM-AssistantMk2
                    [2020-04-28 14:26:54.729] [LOG]    Stopping module helper: MMM-Assistant2Display
                    [2020-04-28 14:26:54.730] [LOG]    Stopping module helper: MMM-Parcel
                    [2020-04-28 14:26:54.730] [LOG]    Stopping module helper: updatenotification
                    [2020-04-28 14:26:54.731] [LOG]    Stopping module helper: MMM-Tools
                    [2020-04-28 14:26:54.731] [LOG]    Stopping module helper: mmm-hue-lights
                    [2020-04-28 14:26:54.732] [LOG]    Stopping module helper: MMM-homeassistant-sensors
                    [2020-04-28 14:26:54.733] [LOG]    Stopping module helper: MMM-Hotword
                    [2020-04-28 14:26:54.733] [LOG]    Stopping module helper: MMM-AssistantMk2
                    [2020-04-28 14:26:54.734] [LOG]    Stopping module helper: MMM-Assistant2Display
                    [2020-04-28 14:26:54.734] [LOG]    Stopping module helper: MMM-Parcel
                      @JohnBachini what a pain
                      try this
                      cd ~/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic
                      # force rebuild to the version of node electron is running
                      ~/MagicMirror/node_modules/.bin/electron-rebuild
                      try again
                      Reply Quote 2
                        Wow… you got it working… thanks a lot for that.!! :thumbs_up:
                        Think there were a few people who couldn’t get this module working so hopefully this will of solved it for them as well.
                          @JohnBachini thanks for the feedback… looks like you gotta go ALL the way into the failing folder. sheesh…
                            I updated the two issues in this module on github that reference this problem with the fix instructions here
                            so eventually the google search will link them together
                              I bet you thought you’d heard the last of this, so you know how you managed to get it all working. Well the problem now is the complete opposite. In that now it doesn’t work node servermode. ?
                              I thought i was going mad and must have been running it incorrectly :thinking_face:
                              Any ideas ?
                              pi@MagicMirror:~ $ cd MagicMirror/
                              pi@MagicMirror:~/MagicMirror $ node serveronly
                              [2020-04-29 14:24:42.858] [LOG]    Starting MagicMirror: v2.11.0
                              [2020-04-29 14:24:42.868] [LOG]    Loading config ...
                              [2020-04-29 14:24:42.873] [LOG]    Loading module helpers ...
                              [2020-04-29 14:24:42.874] [LOG]    No helper found for module: MMM-Logging.
                              [2020-04-29 14:24:42.875] [LOG]    No helper found for module: alert.
                              [2020-04-29 14:24:42.911] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:42.912] [LOG]    Module helper loaded: updatenotification
                              [2020-04-29 14:24:42.912] [LOG]    No helper found for module: clock.
                              [2020-04-29 14:24:42.913] [LOG]    No helper found for module: MMM-OpenmapWeather.
                              [2020-04-29 14:24:42.913] [LOG]    No helper found for module: weatherforecast.
                              [2020-04-29 14:24:43.238] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:43.238] [LOG]    Module helper loaded: MMM-Tools
                              [2020-04-29 14:24:43.239] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                              [2020-04-29 14:24:43.240] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:43.241] [LOG]    Module helper loaded: mmm-hue-lights
                              [2020-04-29 14:24:43.243] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:43.243] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                              [2020-04-29 14:24:43.366] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:43.367] [LOG]    Module helper loaded: MMM-Hotword
                              [2020-04-29 14:24:44.467] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.468] [LOG]    Module helper loaded: MMM-AssistantMk2
                              [2020-04-29 14:24:44.470] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.470] [LOG]    Module helper loaded: MMM-Assistant2Display
                              [2020-04-29 14:24:44.849] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.850] [LOG]    Module helper loaded: MMM-Parcel
                              [2020-04-29 14:24:44.899] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                              NODE_MODULE_VERSION 73. This version of Node.js requires
                              NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                              [2020-04-29 14:24:44.900] [LOG]    Loading module helpers ...
                              [2020-04-29 14:24:44.901] [LOG]    No helper found for module: MMM-Logging.
                              [2020-04-29 14:24:44.902] [LOG]    No helper found for module: alert.
                              [2020-04-29 14:24:44.902] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.903] [LOG]    Module helper loaded: updatenotification
                              [2020-04-29 14:24:44.903] [LOG]    No helper found for module: clock.
                              [2020-04-29 14:24:44.904] [LOG]    No helper found for module: MMM-OpenmapWeather.
                              [2020-04-29 14:24:44.904] [LOG]    No helper found for module: weatherforecast.
                              [2020-04-29 14:24:44.905] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.906] [LOG]    Module helper loaded: MMM-Tools
                              [2020-04-29 14:24:44.906] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                              [2020-04-29 14:24:44.907] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.907] [LOG]    Module helper loaded: mmm-hue-lights
                              [2020-04-29 14:24:44.908] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.908] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                              [2020-04-29 14:24:44.909] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.910] [LOG]    Module helper loaded: MMM-Hotword
                              [2020-04-29 14:24:44.910] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.911] [LOG]    Module helper loaded: MMM-AssistantMk2
                              [2020-04-29 14:24:44.911] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.912] [LOG]    Module helper loaded: MMM-Assistant2Display
                              [2020-04-29 14:24:44.912] [LOG]    Initializing new module helper ...
                              [2020-04-29 14:24:44.913] [LOG]    Module helper loaded: MMM-Parcel
                              [2020-04-29 14:24:44.920] [LOG]    Whoops! There was an uncaught exception...
                              [2020-04-29 14:24:44.920] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                                  at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                                  at Module.require (internal/modules/cjs/loader.js:692:17)
                                  at require (internal/modules/cjs/helpers.js:25:18)
                              [2020-04-29 14:24:44.924] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [2020-04-29 14:24:44.925] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
