    ENOENT yet the file exists within the Magic Mirror folder
    Scheduled Pinned Locked Moved Solved Bug Hunt
    15 Posts 4 Posters 5.8k Views 4 Watching
    • lavolp3L
      lavolp3 Module Developer @Chrisflex
      @Chrisflex YOu seem to be in the wrong directory.
      when you type in npm start, npm is looking for a package.json file in the directory you are running it.
      When there is no package.json, npm does not know what to do.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        Chrisflex
        thanks how do I access that directory?
        lavolp3L 1 Reply Last reply
        • lavolp3L
          @Chrisflex
          Well… What have you done until now?
          Have you installed MagicMirror on your dellserver?
          Where have you done the git clone command?
          You need to enter that directory before doing npm start
          cd MagicMirror
          npm start
          Maybe have a look at the documentation again?
          https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
            Chrisflex
            thanks I have used this since I am trying to do this on a Windows PC.
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
            It is installed on my Dell Server.
            I have not done git clone yet
            It asks that I clone a repository
            Not sure which depository it wants me to clone and how do I point it to that repository.
            C:\Users\Dell Server\
              Chrisflex
              C 1 Reply Last reply
                Chrisflex @Chrisflex
                Got this now I read somewhere that this is what needs to change for the display to work.
                `DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                needs to be removed, I just can’t remember where to access this setting.
                $ npm start
                magicmirror@2.11.0 start C:\Users\Dell Server\MagicMirror
                ‘DISPLAY’ is not recognized as an internal or external command,
                operable program or batch file.
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.11.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.11.0 start script.
                npm ERR! C:\Users\Dell Server\AppData\Roaming\npm-cache_logs\2020-04-29T08_02_47_846Z-debug.log
                  Chrisflex
                  Found and sorted !
                  Now to load custom modules for news weather quote of the day etc.
                    sdetweil @Chrisflex
                    @Chrisflex also, check , the install process is written for linux…
                    the two last steps need to be done manually
                    cd MagicMirror
                    cd vendor
                    npm install
                    cd ..\fonts
                    npm install
                    • bheplerB
                      bhepler Module Developer
                      @Chrisflex - Please use the markdown features of the forum when posting logs and code.
                      That aside, I’m glad you got it sorted out.
                        Chrisflex
                        Now to add modules…
                        https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners/2
                        The link shows instructions for the Pi and not Windows.
                        bheplerB 1 Reply Last reply
                        • bheplerB
                          bhepler Module Developer @Chrisflex
                          @Chrisflex - They’re pretty much one and the same. You already have git installed. Open a terminal in the modules folder, clone the module repository into it, follow the module’s instructions on installing & configuring.
                          Reply Quote 2
                            Chrisflex
                            @bhepler said in ENOENT yet the file exists within the Magic Mirror folder:
                            Thank for the advice.
