    ENOENT yet the file exists within the Magic Mirror folder
    Scheduled Pinned Locked Moved Solved Bug Hunt
    15 Posts 4 Posters 5.7k Views 4 Watching
      Chrisflex
      Dell Server@DellServer MINGW64 ~
      $ npm start
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! path C:\Users\Dell Server\package.json
      npm ERR! errno -4058
      npm ERR! enoent ENOENT: no such file or directory, open ‘C:\Users\Dell Server\package.json’
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! C:\Users\Dell Server\AppData\Roaming\npm-cache_logs\2020-04-29T05_59_08_412Z-debug.log
      • lavolp3L Offline
        lavolp3 Module Developer @Chrisflex
        @Chrisflex Have you looked into the log file? Should be more specific. Maybe a permission problem?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          Chrisflex
          Hi this is what I find there
          1 verbose cli [
          1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
          1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
          1 verbose cli ‘start’
          1 verbose cli ]
          2 info using npm@6.14.4
          3 info using node@v12.16.3
          4 verbose config Skipping project config: C:\Users\Dell Server/.npmrc. (matches userconfig)
          5 verbose stack Error: ENOENT: no such file or directory, open ‘C:\Users\Dell Server\package.json’
          6 verbose cwd C:\Users\Dell Server
          7 verbose Windows_NT 10.0.18363
          8 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
          9 verbose node v12.16.3
          10 verbose npm v6.14.4
          11 error code ENOENT
          12 error syscall open
          13 error path C:\Users\Dell Server\package.json
          14 error errno -4058
          15 error enoent ENOENT: no such file or directory, open ‘C:\Users\Dell Server\package.json’
          16 error enoent This is related to npm not being able to find a file.
          17 verbose exit [ -4058, true ]
          • lavolp3L Offline
            @Chrisflex YOu seem to be in the wrong directory.
            when you type in npm start, npm is looking for a package.json file in the directory you are running it.
            When there is no package.json, npm does not know what to do.
              Chrisflex
              thanks how do I access that directory?
              • lavolp3L Offline
                @Chrisflex
                Well… What have you done until now?
                Have you installed MagicMirror on your dellserver?
                Where have you done the git clone command?
                You need to enter that directory before doing npm start
                cd MagicMirror
                npm start
                Maybe have a look at the documentation again?
                https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
                  Chrisflex
                  thanks I have used this since I am trying to do this on a Windows PC.
                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
                  It is installed on my Dell Server.
                  I have not done git clone yet
                  It asks that I clone a repository
                  Not sure which depository it wants me to clone and how do I point it to that repository.
                    Chrisflex
                      Chrisflex @Chrisflex
                      Got this now I read somewhere that this is what needs to change for the display to work.
                      `DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                      needs to be removed, I just can’t remember where to access this setting.
                      $ npm start
                      magicmirror@2.11.0 start C:\Users\Dell Server\MagicMirror
                      ‘DISPLAY’ is not recognized as an internal or external command,
                      operable program or batch file.
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.11.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.11.0 start script.
                      npm ERR! C:\Users\Dell Server\AppData\Roaming\npm-cache_logs\2020-04-29T08_02_47_846Z-debug.log
                        Chrisflex
                        Found and sorted !
                        Now to load custom modules for news weather quote of the day etc.
                          sdetweil @Chrisflex
                          @Chrisflex also, check , the install process is written for linux…
                          the two last steps need to be done manually
                          cd MagicMirror
                          cd vendor
                          npm install
                          cd ..\fonts
                          npm install
                            bhepler Module Developer
                            @Chrisflex - Please use the markdown features of the forum when posting logs and code.
                            That aside, I’m glad you got it sorted out.
                              Chrisflex
                              Now to add modules…
                              https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners/2
                              The link shows instructions for the Pi and not Windows.
                                bhepler Module Developer @Chrisflex
                                @Chrisflex - They’re pretty much one and the same. You already have git installed. Open a terminal in the modules folder, clone the module repository into it, follow the module’s instructions on installing & configuring.
                                  Chrisflex
                                  @bhepler said in ENOENT yet the file exists within the Magic Mirror folder:
                                  Thank for the advice.
