    ENOENT yet the file exists within the Magic Mirror folder
    Scheduled Pinned Locked Moved Solved Bug Hunt
    15 Posts 4 Posters 4.9k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @Chrisflex
      @Chrisflex Have you looked into the log file? Should be more specific. Maybe a permission problem?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        Chrisflex
        Hi this is what I find there
        1 verbose cli [
        1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
        1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
        1 verbose cli ‘start’
        1 verbose cli ]
        2 info using npm@6.14.4
        3 info using node@v12.16.3
        4 verbose config Skipping project config: C:\Users\Dell Server/.npmrc. (matches userconfig)
        5 verbose stack Error: ENOENT: no such file or directory, open ‘C:\Users\Dell Server\package.json’
        6 verbose cwd C:\Users\Dell Server
        7 verbose Windows_NT 10.0.18363
        8 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
        9 verbose node v12.16.3
        10 verbose npm v6.14.4
        11 error code ENOENT
        12 error syscall open
        13 error path C:\Users\Dell Server\package.json
        14 error errno -4058
        15 error enoent ENOENT: no such file or directory, open ‘C:\Users\Dell Server\package.json’
        16 error enoent This is related to npm not being able to find a file.
        17 verbose exit [ -4058, true ]
        • lavolp3L Offline
          @Chrisflex YOu seem to be in the wrong directory.
          when you type in npm start, npm is looking for a package.json file in the directory you are running it.
          When there is no package.json, npm does not know what to do.
            Chrisflex
            thanks how do I access that directory?
            • lavolp3L Offline
              @Chrisflex
              Well… What have you done until now?
              Have you installed MagicMirror on your dellserver?
              Where have you done the git clone command?
              You need to enter that directory before doing npm start
              cd MagicMirror
              npm start
              Maybe have a look at the documentation again?
              https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
                Chrisflex
                thanks I have used this since I am trying to do this on a Windows PC.
                https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
                It is installed on my Dell Server.
                I have not done git clone yet
                It asks that I clone a repository
                Not sure which depository it wants me to clone and how do I point it to that repository.
                  Chrisflex
                    Chrisflex @Chrisflex
                    Got this now I read somewhere that this is what needs to change for the display to work.
                    `DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                    needs to be removed, I just can’t remember where to access this setting.
                    $ npm start
                    magicmirror@2.11.0 start C:\Users\Dell Server\MagicMirror
                    ‘DISPLAY’ is not recognized as an internal or external command,
                    operable program or batch file.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! magicmirror@2.11.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.11.0 start script.
                    npm ERR! C:\Users\Dell Server\AppData\Roaming\npm-cache_logs\2020-04-29T08_02_47_846Z-debug.log
                      Chrisflex
                      Found and sorted !
                      Now to load custom modules for news weather quote of the day etc.
                        sdetweil @Chrisflex
                        @Chrisflex also, check , the install process is written for linux…
                        the two last steps need to be done manually
                        cd MagicMirror
                        cd vendor
                        npm install
                        cd ..\fonts
                        npm install
