    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 34.8k Views 7 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Linas123
      @Linas123
      You tried to run it? What was the result?
      If you run arecord test.wav in a terminal window does it record a sound file?
      • Mykle1M
        @Linas123
        Your config entry is fine. I just tried it with my microphone setting and it works fine
        • L
          Linas123
          Yes I tried it to run, but lucy say only “Hello Michael, what would you like to see” and on the top of the Mirror is a crossed-out green flashing microphone and “Command Please:”.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            @Linas123
            OK, the module is loading. That’s good.
            L 1 Reply Last reply
            • L
              Linas123 @Mykle1
              @Mykle1 said in Hello-Lucy Module Microphone not working:
              arecord test.wav
              No it doesn’t work , there is yet the error “arecord: main:828:…”. I just noticed that my USB micro is now suddenly displayed as card 1. I change yet my /.asoundrc file again. Do I have to download the module again?
              Thank you for you fast replays.
              • Mykle1M
                @Linas123
                arecord test.wav MUST work for Lucy to work.
                If you can get that to work then run arecord -l again to get your card and device numbers,
                Then enter those in the microphone config entry and run MM again
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @Mykle1
                  @Mykle1
                  You do NOT have to download the module again
                  • L
                    Linas123 @Mykle1
                    @Mykle1
                    It’s still the same as earlier. At the top is still the crossed-out green flashing microphone.
                    • Mykle1M
                      @Linas123
                      Did you get arecord test.wav to record a sound file?
                      I’m confused. Is it still reporting card 1?
                      Did you make the changes to your config microphone option?
                      How long are you waiting before quitting MM when you see thecrossed-out green flashing microphone?
                      • L
                        Linas123 @Mykle1
                        @Mykle1
                        I’am confused too. It’s still card 1, when I enter “arecord -l”. When the Magic Mirror runs in the background and I enter “arecord test.wav” the Error “arecord: main:828: audio open error: Device or resource busy” appears. But, when I stop the Magic Mirror with pm2, record works. After reboot the Magic Mirror is yet on the top a micro icon and "Ready, “Hello Lucy”. But when I try to ask she, nothing happens. To you have a answer for this?
                          sdetweil @Linas123
                          @Linas123 said in Hello-Lucy Module Microphone not working:
                          and you say
                          ‘Hello Lucy’
                          right?
                          • L
                            Linas123 @sdetweil
                            Yes, of course. I tried it again. I shouted into the microphone, although “ERROR” was displayed and Lucy reacted. But when I tried to hide the news, it took a very long time. When I tried to continue, Lucy reacted once out of 10 and in between she always showed ERROR. Can I do something that she understand me better and that the delay is not so long.
                              sdetweil @Linas123
                              @Linas123 I don’t know. Was just trying to help.
                              Lots of times users didn’t know to say hello Lucy.
                              What language do you speak? Sometimes the language model cannot detect the intonation
                              • L
                                Linas123 @sdetweil
                                I speak with a german accent.
                                • L
                                  Linas123
                                  Thank you for all your help and your fast replays. Now it finally works with long charging times, but it works. Whenever I stop the Magic Mirror with pm2, the card for the microphone changes, but I can live with that because soon it will hang on the wall and then I won’t stop pm2.
                                    sdetweil @Linas123
                                    do you mean response times? (time from speak to action)
                                    charging in english applies to batteries.
                                    what pi device are you using?
                                    • L
                                      Linas123 @sdetweil
                                      Sorry, I’am only just 16 years old and not so good in english. I mean response time and use the RPI 3b+.
                                        sdetweil @Linas123
                                        a LOT better than my german!!
                                        wonder what else is running. 3b+ is usually pretty good
                                        do you use SSH to connect to pi?
                                        if so, can you do top command to see what is running?
                                        • L
                                          Linas123 @sdetweil
                                          I use realVNC to see what is on my Mirror.
                                            sdetweil @Linas123
                                            @Linas123 can u minimize mirror (alt-spacebar, n)
                                            and then run top in a terminal window (ctrl-alt-t)
                                            ctrl-c to exit top
                                            • 2 / 3
