    Cowboysdude's Mirror
    49 Posts 9 Posters 61.8k Views 9 Watching
      bibi @cowboysdude
      @cowboysdude oh that’s really really awesome!
      so what i have done is git Pir-Sensor & wiringPi into root? =>
      edit with nano pir.py =>
      chmod all 3 files at pi@raspberrypi:~ $
      and crontab also at pi@raspberrypi:~ $
      the jumper on PIR sensor in on H and the knobs are both set at minimum level
      • cowboysdudeC
        First make sure your wiring is correct… use the pin in the pir.py…
        Then…
        I put the pir.py and both sh files in the pi root directly
        pi/pir.py
        pi/monitor_off.sh
        pi/monitor_on.sh
        sudo chmod +x pir.py
        sudo chmod +x monitor_off.sh
        sudo chmod +x monitor_on.sh
        Then…
        sudo crontab -e
        On the last line enter:
        @reboot python /home/pi/pir.py &
        Hit CRTL-O to save then exit
        Reboot your pi
        B 2 Replies Last reply
          bibi @cowboysdude
            bibi @cowboysdude
            @cowboysdude that’s exactly what i did all 3 files are located in Pi home directory as well as wiringPi.
            sudo chmod there too & crontab too…
            but not working… there should be something else.
            i try to run your .sh file so the outcome is that monitor_off file works well but the monitor_on file displays the following message:
            would you mind to share with me YOUR following files plssssss =>
            thx you!
            • cowboysdudeC
              cowboysdude Module Developer @bibi
              @bibi go here:
              https://github.com/cowboysdude/Pir-Sensor
              download the monitor_on.sh and try running it again.
              B 1 Reply Last reply
                bibi @cowboysdude
                @cowboysdude Apperently i could get ride off this xset message now the monitor is turning on but the screen stays black… screensaver issue maybe.
                • cowboysdudeC
                  @bibi said in Cowboysdude's Mirror:
                  Yes that’s why I gave you the new one to try… I believe you’re having a screen saver issue.
                  The way I handled mine was to install xscreensaver and disable it :)
                    bibi @cowboysdude
                    @cowboysdude aha ok I will check install xscreensaver this evening. Any specific options or settings that I should apply?
                    cowboysdudeC B 2 Replies Last reply
                    • cowboysdudeC
                      Yes “Disable” :)
                        bhepler Module Developer @bibi
                        @bibi This thread may help you.
                          bibi
                          @cowboysdude @bhepler Thx for spending time to help me. i understand if you can’t help anymore.
                          but here my update : i installed Xscreensaver and disabled it but it’s working. the monitor switches off with /opt/vc/bin/tvservice -o properly but with
                          /opt/vc/bin/tvservice -p the screen stays black (backlight)
                          just for info im doing all this via SSH… maybe something to do with X forwarding and this message : xset: unable to open display “”…
                          Edit: i have found a command that allows to bring back the screen ! sudo chvt 9 && sudo chvt 7. :)))
                          i have to check out how to implement this in an elegant way
                          • cowboysdudeC
                            Open up the monitor_on.sh and delete everything add:
                            Save it and that should work for you :)
                              bibi @cowboysdude
                              @cowboysdude said in Cowboysdude's Mirror:
                              yep that’s exactly what i wanted to later today :))
                              nevertheless, I found on the forum another way to avoid using sudo… i assume it’s better practice but i am not able to confirm this.
                              fyi:
                              the link : https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/64
                                bibi @bibi
                                @cowboysdude Cool! my modified .sh files are working well in interactive mode :) but… there is always a but lol, when .py file is run it switches well the screen off after the amount of time set and wakes up when hand is waved BUT suddently and without detection the screen wakes up again! this is really irrating… so close to my goal :(
                                i believe it’s the physical settings on the sensor itself making this behavior… would you mind to send me a pic or tell me how your sensor is set? => jumper and the knobs? thx mate for this (i hope) final demand! :)))
                                • cowboysdudeC
                                  Mine is set just like this right out of the box…
                                  The sensitivity sensor is set to half way as is the Time Delay Adjust so what you do is turn it all the way to the right then back 1/2 turn on both :)
                                  The Jumper is L Single trigger…
                                  OH by the way PIR sensors and the Pi 3 sometimes don’t get along - if you’re having false triggers, make sure the PIR Sensor is far away from the Pi 3… So get it as far away as you can :) I would try that first before making anymore adjustments!
                                    bibi @cowboysdude
                                    @cowboysdude oh so cool for sharing! let’s try this! wow that’s a thing i should have thought about before lol but currently i can’t put it too much far away as my cables are only few cm long…
                                    • 3 / 3
