    Getting MMM to open on the second monitor and correctly size
    24 Posts 3 Posters 8.5k Views 3 Watching
      sdetweil @Chrisflex
      @Chrisflex well, to the right is ‘easy’
      in config.js u need to tell it where (left/right) to position the monitor in the display space.
      add this to config.js
      var config = {
      	electronOptions:{x:1920 },       // add this line, where x is the width of your 1st display
      now orientation… you MAY be able to use also width and height… altho it says to fullscreen on that montitor, so it should work
      electronOptions:{x:1920, width:xx,  height: yy },
        Chrisflex @sdetweil
        @sdetweil said in Getting MMM to open on the second monitor and correctly size:
        var config = {
        Great thank you for the advice I will try it later.
          sdetweil @Chrisflex
          @Chrisflex i have two monitors and have MM open on the second display
            Chrisflex
            I have entered the information as it is below
            var config = {electronOptions:{x:1920, width:768, height: 1360 },
            It still only opens on the primary screen.
            1920, 768, and 1360 are highlighted red
            I am not sure what that means.
            This is all being done in Windows 10 with Note+ as the editor.
              sdetweil @Chrisflex
              @Chrisflex how wide is the 1st display?
              did u try that 1st?
              just move to the second display and see what happens?
              highlighted in red by what?
                sdetweil @Chrisflex
                @Chrisflex on my machine, height and width don’t do anything, as the fullscreen takes over
                you might also add fullscreen:false to the options above
                that made mine use the sizes specified
                I am on linux
                if there is an error in the config. it will open on the primary display
                look at the output of npm start
                  Chrisflex
                  I have entered the information like this
                       this does not work      {electronOptions:{fullscreen:false ,x:1920 },
                                                               {electronOptions:{x:1920,fullscreen:false }
                  This works
                  {electronOptions:{fullscreen:false }
                  It brings up a small screen but not sized correctly.
                  it shows Electron in the top left corner
                  this screen can be dragged to the second monitor.
                  here is the start up log
                  [2020-05-03 18:34:52.838] [LOG] Starting MagicMirror: v2.11.0
                  [2020-05-03 18:34:52.840] [LOG] Loading config …
                  [2020-05-03 18:34:52.844] [LOG] Loading module helpers …
                  [2020-05-03 18:34:52.845] [LOG] No helper found for module: alert.
                  [2020-05-03 18:34:52.881] [LOG] Initializing new module helper …
                  [2020-05-03 18:34:52.881] [LOG] Module helper loaded: updatenotification
                  [2020-05-03 18:34:52.881] [LOG] No helper found for module: clock.
                  [2020-05-03 18:34:53.145] [LOG] Initializing new module helper …
                  [2020-05-03 18:34:53.146] [LOG] Module helper loaded: calendar
                  [2020-05-03 18:34:53.146] [LOG] No helper found for module: compliments.
                  [2020-05-03 18:34:53.146] [LOG] No helper found for module: on-this-day.
                  [2020-05-03 18:34:53.147] [LOG] No helper found for module: random_quotes.
                  [2020-05-03 18:34:53.147] [LOG] No helper found for module: currentweather.
                  [2020-05-03 18:34:53.147] [LOG] No helper found for module: weatherforecast.
                  [2020-05-03 18:34:53.167] [LOG] Initializing new module helper …
                  [2020-05-03 18:34:53.167] [LOG] Module helper loaded: newsfeed
                  [2020-05-03 18:34:53.167] [LOG] All module helpers loaded.
                  [2020-05-03 18:34:53.269] [LOG] Starting server on port 8080 …
                  [2020-05-03 18:34:53.287] [LOG] Server started …
                  [2020-05-03 18:34:53.289] [LOG] Connecting socket for: updatenotification
                  [2020-05-03 18:34:53.289] [LOG] Connecting socket for: calendar
                  [2020-05-03 18:34:53.290] [LOG] Starting node helper for: calendar
                  [2020-05-03 18:34:53.290] [LOG] Connecting socket for: newsfeed
                  [2020-05-03 18:34:53.291] [LOG] Starting module: newsfeed
                  [2020-05-03 18:34:53.291] [LOG] Sockets connected & modules started …
                  [2020-05-03 18:34:53.362] [LOG] Launching application.
                  [2020-05-03 18:34:55.366] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/chris.flekas%40gmail.com/public/basic.ics - Interval: 300000
                  [2020-05-03 18:34:55.395] [LOG] Create new news fetcher for url: http://feeds.news24.com/articles/News24/TopStories/rss - Interval: 300000
                  [2020-05-03 18:34:55.806] [ERROR] fatal: not a git repository (or any of the parent directories): .git
                  thank you very much for you help
                    its like this
                    var config= {
                    electronOptions:{fullscreen:false, x:1920, width: 600, height:800 }, // note the trailing comma (which means more to come
                      Chrisflex
                      Thank you I will try it tomorrow.
                        Chrisflex
                        If I hover over the Electron icon in the taskbar I can see it must be open somewhere but not visible on one of the screens.
                        information entered like this
                        var config = {electronOptions:{fullscreen:false, x:1920, width: 600, height:800 },
                        alt text
                          sdetweil @Chrisflex
                          @Chrisflex i haven’t tried on windows… may boot over there today
                            Chrisflex @sdetweil
                            @sdetweil Thanks I appreciate your help.
                              sdetweil @Chrisflex
                              @Chrisflex
                              this did what we were talking about
                              var config = {
                              	electronOptions: { x:1920,fullscreen:false , width: 600, height:800},
                              	address: "localhost",
                              alt text
                              this did on second screen not full screen (MM default size is 800x600)
                              var config = {
                              	electronOptions: { x:1920,fullscreen:false },
                              alt text
                              and this did second screen full screen
                              var config = {
                              	electronOptions: { x:1920},
                              alt text
                                Chrisflex
                                the first option gives me this error
                                var config = {
                                WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: C:\Users\Dell Server\MagicMirror\config\config.js:11
                                var config = {electronOptions:electronOptions: {x:1920,fullscreen:false , width: 600, height:800},
                                SyntaxError: Unexpected token :
                                at Module._compile (internal/modules/cjs/loader.js:722:23)
                                at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                                at Module.load (internal/modules/cjs/loader.js:645:32)
                                at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                at Module.require (internal/modules/cjs/loader.js:685:19)
                                at require (internal/modules/cjs/helpers.js:16:16)
                                at loadConfig (C:\Users\Dell Server\MagicMirror\js\app.js:69:12)
                                at App.start (C:\Users\Dell Server\MagicMirror\js\app.js:210:3)
                                at Object. (C:\Users\Dell Server\MagicMirror\js\electron.js:115:7)
                                at Module._compile (internal/modules/cjs/loader.js:786:30)
                                The second option
                                var config = {
                                address: “localhost”,
                                gives me this error
                                var config = {electronOptions:electronOptions: {x:1920,fullscreen:false},
                                the last option
                                starts MM in a window that can be dragged across to the second monitor but is not sized correctly.
                                It is the size of the normal full screen
                                S B 2 Replies Last reply Reply Quote 0
                                  sdetweil @Chrisflex
                                  @Chrisflex u are adding just the electronOptions line
                                  I was just showing where it went
                                    Chrisflex
                                    Copied from my config js file
                                    var config = {electronOptions:{x:1920 },
                                    // - “0.0.0.0”, “::” to listen on any interface
                                    // Default, when address config is left out or empty, is “localhost”
                                    Is that correct?
                                      sdetweil @Chrisflex
                                      @Chrisflex better when on separate lines
                                      That looks ok
                                      Should be full screen on second display
                                        sdetweil @Chrisflex
                                        @Chrisflex posted pics above
                                          bhepler Module Developer @Chrisflex
                                          @Chrisflex - Please use the markdown features of the forum when posting code or logs.
                                            Chrisflex @bhepler
                                            @bhepler Thanks I will try
