    Getting MMM to open on the second monitor and correctly size
    24 Posts 3 Posters 8.0k Views 3 Watching
      sdetweil @Chrisflex
      @Chrisflex on my machine, height and width don’t do anything, as the fullscreen takes over
      you might also add fullscreen:false to the options above
      that made mine use the sizes specified
      I am on linux
      if there is an error in the config. it will open on the primary display
      look at the output of npm start
        Chrisflex
        @sdetweil said in Getting MMM to open on the second monitor and correctly size:
        electronOptions:{x:1920 }
        I have entered the information like this
             this does not work      {electronOptions:{fullscreen:false ,x:1920 },
                                                     {electronOptions:{x:1920,fullscreen:false }
        This works
        {electronOptions:{fullscreen:false }
        It brings up a small screen but not sized correctly.
        it shows Electron in the top left corner
        this screen can be dragged to the second monitor.
        here is the start up log
        [2020-05-03 18:34:52.838] [LOG] Starting MagicMirror: v2.11.0
        [2020-05-03 18:34:52.840] [LOG] Loading config …
        [2020-05-03 18:34:52.844] [LOG] Loading module helpers …
        [2020-05-03 18:34:52.845] [LOG] No helper found for module: alert.
        [2020-05-03 18:34:52.881] [LOG] Initializing new module helper …
        [2020-05-03 18:34:52.881] [LOG] Module helper loaded: updatenotification
        [2020-05-03 18:34:52.881] [LOG] No helper found for module: clock.
        [2020-05-03 18:34:53.145] [LOG] Initializing new module helper …
        [2020-05-03 18:34:53.146] [LOG] Module helper loaded: calendar
        [2020-05-03 18:34:53.146] [LOG] No helper found for module: compliments.
        [2020-05-03 18:34:53.146] [LOG] No helper found for module: on-this-day.
        [2020-05-03 18:34:53.147] [LOG] No helper found for module: random_quotes.
        [2020-05-03 18:34:53.147] [LOG] No helper found for module: currentweather.
        [2020-05-03 18:34:53.147] [LOG] No helper found for module: weatherforecast.
        [2020-05-03 18:34:53.167] [LOG] Initializing new module helper …
        [2020-05-03 18:34:53.167] [LOG] Module helper loaded: newsfeed
        [2020-05-03 18:34:53.167] [LOG] All module helpers loaded.
        [2020-05-03 18:34:53.269] [LOG] Starting server on port 8080 …
        [2020-05-03 18:34:53.287] [LOG] Server started …
        [2020-05-03 18:34:53.289] [LOG] Connecting socket for: updatenotification
        [2020-05-03 18:34:53.289] [LOG] Connecting socket for: calendar
        [2020-05-03 18:34:53.290] [LOG] Starting node helper for: calendar
        [2020-05-03 18:34:53.290] [LOG] Connecting socket for: newsfeed
        [2020-05-03 18:34:53.291] [LOG] Starting module: newsfeed
        [2020-05-03 18:34:53.291] [LOG] Sockets connected & modules started …
        [2020-05-03 18:34:53.362] [LOG] Launching application.
        [2020-05-03 18:34:55.366] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/chris.flekas%40gmail.com/public/basic.ics - Interval: 300000
        [2020-05-03 18:34:55.395] [LOG] Create new news fetcher for url: http://feeds.news24.com/articles/News24/TopStories/rss - Interval: 300000
        [2020-05-03 18:34:55.806] [ERROR] fatal: not a git repository (or any of the parent directories): .git
        thank you very much for you help
          its like this
          var config= {
          electronOptions:{fullscreen:false, x:1920, width: 600, height:800 }, // note the trailing comma (which means more to come
            Chrisflex
            Thank you I will try it tomorrow.
              Chrisflex
              If I hover over the Electron icon in the taskbar I can see it must be open somewhere but not visible on one of the screens.
              information entered like this
              var config = {electronOptions:{fullscreen:false, x:1920, width: 600, height:800 },
              alt text
                sdetweil @Chrisflex
                @Chrisflex i haven’t tried on windows… may boot over there today
                  Chrisflex @sdetweil
                  @sdetweil Thanks I appreciate your help.
                    sdetweil @Chrisflex
                    @Chrisflex
                    this did what we were talking about
                    var config = {
                    	electronOptions: { x:1920,fullscreen:false , width: 600, height:800},
                    	address: "localhost",
                    alt text
                    this did on second screen not full screen (MM default size is 800x600)
                    var config = {
                    	electronOptions: { x:1920,fullscreen:false },
                    alt text
                    and this did second screen full screen
                    var config = {
                    	electronOptions: { x:1920},
                    alt text
                      Chrisflex
                      the first option gives me this error
                      var config = {
                      WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: C:\Users\Dell Server\MagicMirror\config\config.js:11
                      var config = {electronOptions:electronOptions: {x:1920,fullscreen:false , width: 600, height:800},
                      SyntaxError: Unexpected token :
                      at Module._compile (internal/modules/cjs/loader.js:722:23)
                      at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32)
                      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at loadConfig (C:\Users\Dell Server\MagicMirror\js\app.js:69:12)
                      at App.start (C:\Users\Dell Server\MagicMirror\js\app.js:210:3)
                      at Object. (C:\Users\Dell Server\MagicMirror\js\electron.js:115:7)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                      The second option
                      var config = {
                      address: “localhost”,
                      gives me this error
                      var config = {electronOptions:electronOptions: {x:1920,fullscreen:false},
                      the last option
                      starts MM in a window that can be dragged across to the second monitor but is not sized correctly.
                      It is the size of the normal full screen
                      S B 2 Replies Last reply Reply Quote 0
                        sdetweil @Chrisflex
                        @Chrisflex u are adding just the electronOptions line
                        I was just showing where it went
                          Chrisflex
                          Copied from my config js file
                          var config = {electronOptions:{x:1920 },
                          // - “0.0.0.0”, “::” to listen on any interface
                          // Default, when address config is left out or empty, is “localhost”
                          Is that correct?
                            sdetweil @Chrisflex
                            @Chrisflex better when on separate lines
                            That looks ok
                            Should be full screen on second display
                              sdetweil @Chrisflex
                              @Chrisflex posted pics above
                                bhepler Module Developer @Chrisflex
                                @Chrisflex - Please use the markdown features of the forum when posting code or logs.
                                  Chrisflex @bhepler
                                  @bhepler Thanks I will try
                                    sdetweil @Chrisflex
                                    @Chrisflex ant progress?
                                      Chrisflex
                                      Hi apologies I have tried but no luck.
                                      I will try again.
                                        Chrisflex @Chrisflex
                                        @sdetweil The first two options give me a window that I can drag and drop to the second vertical screen
                                        Unfortunately the scaling is still a problem.
                                        alt text
