    Getting MMM to open on the second monitor and correctly size
    24 Posts 3 Posters 8.9k Views 3 Watching
      its like this
      var config= {
      electronOptions:{fullscreen:false, x:1920, width: 600, height:800 }, // note the trailing comma (which means more to come
        Chrisflex
        Thank you I will try it tomorrow.
          Chrisflex
          If I hover over the Electron icon in the taskbar I can see it must be open somewhere but not visible on one of the screens.
          information entered like this
          var config = {electronOptions:{fullscreen:false, x:1920, width: 600, height:800 },
          alt text
            sdetweil @Chrisflex
            @Chrisflex i haven’t tried on windows… may boot over there today
            C 1 Reply Last reply
              Chrisflex @sdetweil
              @sdetweil Thanks I appreciate your help.
                sdetweil @Chrisflex
                @Chrisflex
                this did what we were talking about
                var config = {
                	electronOptions: { x:1920,fullscreen:false , width: 600, height:800},
                	address: "localhost",
                alt text
                this did on second screen not full screen (MM default size is 800x600)
                var config = {
                	electronOptions: { x:1920,fullscreen:false },
                alt text
                and this did second screen full screen
                var config = {
                	electronOptions: { x:1920},
                alt text
                  Chrisflex
                  @sdetweil said in Getting MMM to open on the second monitor and correctly size:
                  the first option gives me this error
                  var config = {
                  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: C:\Users\Dell Server\MagicMirror\config\config.js:11
                  var config = {electronOptions:electronOptions: {x:1920,fullscreen:false , width: 600, height:800},
                  SyntaxError: Unexpected token :
                  at Module._compile (internal/modules/cjs/loader.js:722:23)
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                  at Module.load (internal/modules/cjs/loader.js:645:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                  at Module.require (internal/modules/cjs/loader.js:685:19)
                  at require (internal/modules/cjs/helpers.js:16:16)
                  at loadConfig (C:\Users\Dell Server\MagicMirror\js\app.js:69:12)
                  at App.start (C:\Users\Dell Server\MagicMirror\js\app.js:210:3)
                  at Object. (C:\Users\Dell Server\MagicMirror\js\electron.js:115:7)
                  at Module._compile (internal/modules/cjs/loader.js:786:30)
                  The second option
                  var config = {
                  address: “localhost”,
                  gives me this error
                  var config = {electronOptions:electronOptions: {x:1920,fullscreen:false},
                  the last option
                  starts MM in a window that can be dragged across to the second monitor but is not sized correctly.
                  It is the size of the normal full screen
                  S bheplerB 2 Replies Last reply
                    sdetweil @Chrisflex
                    @Chrisflex u are adding just the electronOptions line
                    I was just showing where it went
                      Chrisflex
                      Copied from my config js file
                      var config = {electronOptions:{x:1920 },
                      // - “0.0.0.0”, “::” to listen on any interface
                      // Default, when address config is left out or empty, is “localhost”
                      Is that correct?
                      S 2 Replies Last reply
                        sdetweil @Chrisflex
                        @Chrisflex better when on separate lines
                        That looks ok
                        Should be full screen on second display
                          sdetweil @Chrisflex
                          @Chrisflex posted pics above
                          • bheplerB
                            bhepler Module Developer @Chrisflex
                            @Chrisflex - Please use the markdown features of the forum when posting code or logs.
                              Chrisflex @bhepler
                              @bhepler Thanks I will try
                                sdetweil @Chrisflex
                                @Chrisflex ant progress?
                                  Chrisflex
                                  Hi apologies I have tried but no luck.
                                  I will try again.
                                    Chrisflex @Chrisflex
                                    @sdetweil The first two options give me a window that I can drag and drop to the second vertical screen
                                    Unfortunately the scaling is still a problem.
                                    alt text
