    Getting MMM to open on the second monitor and correctly size
    24 Posts 3 Posters 8.5k Views 3 Watching
      sdetweil @Chrisflex
      @Chrisflex how wide is the 1st display?
      did u try that 1st?
      just move to the second display and see what happens?
      highlighted in red by what?
        sdetweil @Chrisflex
        @Chrisflex on my machine, height and width don’t do anything, as the fullscreen takes over
        you might also add fullscreen:false to the options above
        that made mine use the sizes specified
        I am on linux
        if there is an error in the config. it will open on the primary display
        look at the output of npm start
          Chrisflex
          @sdetweil said in Getting MMM to open on the second monitor and correctly size:
          electronOptions:{x:1920 }
          I have entered the information like this
               this does not work      {electronOptions:{fullscreen:false ,x:1920 },
                                                       {electronOptions:{x:1920,fullscreen:false }
          This works
          {electronOptions:{fullscreen:false }
          It brings up a small screen but not sized correctly.
          it shows Electron in the top left corner
          this screen can be dragged to the second monitor.
          here is the start up log
          [2020-05-03 18:34:52.838] [LOG] Starting MagicMirror: v2.11.0
          [2020-05-03 18:34:52.840] [LOG] Loading config …
          [2020-05-03 18:34:52.844] [LOG] Loading module helpers …
          [2020-05-03 18:34:52.845] [LOG] No helper found for module: alert.
          [2020-05-03 18:34:52.881] [LOG] Initializing new module helper …
          [2020-05-03 18:34:52.881] [LOG] Module helper loaded: updatenotification
          [2020-05-03 18:34:52.881] [LOG] No helper found for module: clock.
          [2020-05-03 18:34:53.145] [LOG] Initializing new module helper …
          [2020-05-03 18:34:53.146] [LOG] Module helper loaded: calendar
          [2020-05-03 18:34:53.146] [LOG] No helper found for module: compliments.
          [2020-05-03 18:34:53.146] [LOG] No helper found for module: on-this-day.
          [2020-05-03 18:34:53.147] [LOG] No helper found for module: random_quotes.
          [2020-05-03 18:34:53.147] [LOG] No helper found for module: currentweather.
          [2020-05-03 18:34:53.147] [LOG] No helper found for module: weatherforecast.
          [2020-05-03 18:34:53.167] [LOG] Initializing new module helper …
          [2020-05-03 18:34:53.167] [LOG] Module helper loaded: newsfeed
          [2020-05-03 18:34:53.167] [LOG] All module helpers loaded.
          [2020-05-03 18:34:53.269] [LOG] Starting server on port 8080 …
          [2020-05-03 18:34:53.287] [LOG] Server started …
          [2020-05-03 18:34:53.289] [LOG] Connecting socket for: updatenotification
          [2020-05-03 18:34:53.289] [LOG] Connecting socket for: calendar
          [2020-05-03 18:34:53.290] [LOG] Starting node helper for: calendar
          [2020-05-03 18:34:53.290] [LOG] Connecting socket for: newsfeed
          [2020-05-03 18:34:53.291] [LOG] Starting module: newsfeed
          [2020-05-03 18:34:53.291] [LOG] Sockets connected & modules started …
          [2020-05-03 18:34:53.362] [LOG] Launching application.
          [2020-05-03 18:34:55.366] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/chris.flekas%40gmail.com/public/basic.ics - Interval: 300000
          [2020-05-03 18:34:55.395] [LOG] Create new news fetcher for url: http://feeds.news24.com/articles/News24/TopStories/rss - Interval: 300000
          [2020-05-03 18:34:55.806] [ERROR] fatal: not a git repository (or any of the parent directories): .git
          thank you very much for you help
            its like this
            var config= {
            electronOptions:{fullscreen:false, x:1920, width: 600, height:800 }, // note the trailing comma (which means more to come
              Chrisflex
              Thank you I will try it tomorrow.
                Chrisflex
                If I hover over the Electron icon in the taskbar I can see it must be open somewhere but not visible on one of the screens.
                information entered like this
                var config = {electronOptions:{fullscreen:false, x:1920, width: 600, height:800 },
                alt text
                  sdetweil @Chrisflex
                  @Chrisflex i haven’t tried on windows… may boot over there today
                    Chrisflex @sdetweil
                    @sdetweil Thanks I appreciate your help.
                      sdetweil @Chrisflex
                      @Chrisflex
                      this did what we were talking about
                      var config = {
                      	electronOptions: { x:1920,fullscreen:false , width: 600, height:800},
                      	address: "localhost",
                      alt text
                      this did on second screen not full screen (MM default size is 800x600)
                      var config = {
                      	electronOptions: { x:1920,fullscreen:false },
                      alt text
                      and this did second screen full screen
                      var config = {
                      	electronOptions: { x:1920},
                      alt text
                        Chrisflex
                        the first option gives me this error
                        var config = {
                        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: C:\Users\Dell Server\MagicMirror\config\config.js:11
                        var config = {electronOptions:electronOptions: {x:1920,fullscreen:false , width: 600, height:800},
                        SyntaxError: Unexpected token :
                        at Module._compile (internal/modules/cjs/loader.js:722:23)
                        at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                        at Module.load (internal/modules/cjs/loader.js:645:32)
                        at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                        at Module.require (internal/modules/cjs/loader.js:685:19)
                        at require (internal/modules/cjs/helpers.js:16:16)
                        at loadConfig (C:\Users\Dell Server\MagicMirror\js\app.js:69:12)
                        at App.start (C:\Users\Dell Server\MagicMirror\js\app.js:210:3)
                        at Object. (C:\Users\Dell Server\MagicMirror\js\electron.js:115:7)
                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                        The second option
                        var config = {
                        address: “localhost”,
                        gives me this error
                        var config = {electronOptions:electronOptions: {x:1920,fullscreen:false},
                        the last option
                        starts MM in a window that can be dragged across to the second monitor but is not sized correctly.
                        It is the size of the normal full screen
                        S B 2 Replies Last reply Reply Quote 0
                          sdetweil @Chrisflex
                          @Chrisflex u are adding just the electronOptions line
                          I was just showing where it went
                            Chrisflex
                            Copied from my config js file
                            var config = {electronOptions:{x:1920 },
                            // - “0.0.0.0”, “::” to listen on any interface
                            // Default, when address config is left out or empty, is “localhost”
                            Is that correct?
                              sdetweil @Chrisflex
                              @Chrisflex better when on separate lines
                              That looks ok
                              Should be full screen on second display
                                sdetweil @Chrisflex
                                @Chrisflex posted pics above
                                  bhepler Module Developer @Chrisflex
                                  @Chrisflex - Please use the markdown features of the forum when posting code or logs.
                                    Chrisflex @bhepler
                                    @bhepler Thanks I will try
                                      sdetweil @Chrisflex
                                      @Chrisflex ant progress?
                                        Chrisflex
                                        Hi apologies I have tried but no luck.
                                        I will try again.
                                          Chrisflex @Chrisflex
                                          @sdetweil The first two options give me a window that I can drag and drop to the second vertical screen
                                          Unfortunately the scaling is still a problem.
                                          alt text
