    Moving modules
    8 Posts 3 Posters 2.5k Views 3 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @gwiz
      @gwiz try
      .weatherforecast
      instead of .MMM-weatherforecast.
      Odd, but that’s how it is referenced in the module css
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • G Offline
        gwiz
        @lavolp3 thanks again for the help, I changed it how you said but the module still did not move. Here is what I have now:
        .weatherforecast {
              margin-right: -40px;
        But still no movement :frowning_face: not sure where to go from here
          @gwiz
          That SHOULD work. Odd. So, instead of pulling it from the right, try pushing it from the left. I just tested it. Unless there is a css conflict somewhere.
          .weatherforecast {
            margin-left: 40px;
          • G Offline
            gwiz
            Hi @Mykle1 thanks for the help,
            I tried putting that exact clip into custom.css but still nothing changed. Could there be something else somewhere preventing it from moving?
            Thanks again
              Mykle1 Project Sponsor Module Developer @gwiz
              @gwiz
              Sure, but troubleshooting will have to be done to determine the cause. I suggest you try the following:
              1. Disable all modules except the weatherforecast module in your config.js file.
              2. Disable all entries in your custom.css file except the one for weatherforecast.
              Now see if the css entry for weatherforecast works.
