    Touch Screen
    11 Posts 7 Posters 6.4k Views 8 Watching
      Cetax
      I have a touch screen as MagicMirror and I want to use it to switch.
      I always want to see the standard page and switch to other modules with the button.
      It would be great if only that could be changed in the middle_center.
      What modules do I need?
      Are there any instructions? Surely someone has done it before …
      I found 17 repositories, but which is the right one?
      Sorry for so many questions :-)
      But I’m new and totally delighted with the many things you can do with the MM …
      Thanks a lot
      greeting
      Stefan
        Cetax
        Nobody a idea ?
        Wich module i need ?
        With wich Module can i toggle other modeule ?
        Now i have “MMM-Modulebar” install, but this don´t toggle.
        it only shows an additional module, But the other is not hidden.
        please Help
          MMM-Pages gives you multiple display spaces
            Cetax
            Ok, thanks, I look at. :thumbs_up:
            • cowboysdudeC Offline
              There’s a magic button in the upper right hand of the forum… try starting there ;)
              Mykle1M S 2 Replies Last reply Reply Quote 1
                @cowboysdude
                What is that?
                  sdetweil @cowboysdude
                  @cowboysdude no way!
                    cyberphox
                    I clicked on it once…still wanted me to type in stuff… ;)
                      Matty600
                      Sorry, bit late to the party but I’ve done something that may help.
                      I’ve got a touch frame and I use the MMM-Modulebar to show/hide modules (the long list).Show hide modules.jpg
                      I’ve also copied the MMM-Modulebar folder and renamed any instances of the module name in any js and css files, copy called MMM-ModulebarHide, and now have a single button that shows/hide the list of modules.
                      The idea came from someone else in the forum, can’t remember the name but here’s a shout out to you.
                      Matty
                      KamiSchamiK 1 Reply Last reply Reply Quote 0
                      • KamiSchamiK Offline
                        KamiSchami
                        … the modules fade out by themselves after a while?
                        Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
                          KamiSchami @Matty600
                          @Matty600 … i do the same with MMM-Touchnavigation. Rename and edit the js and css :-)
