    MMM-SunRiseSet
    Scheduled Pinned Locked Moved Education
    51 Posts 10 Posters 37.3k Views 10 Watching
      For those that be using MMM-SunRiseSet, please forgive the outage of the API. You can still use the module, albeit without the animated images. You can still use the module without the image by adding this to your custom.css file. This will remove the broken link from appearing.
      .MMM-SunRiseSet .img {
        display: none;
      Example along with MMM-EyeCandy. Animation is seamless loop in the module
      • cowboysdudeC Offline
        What is that a brain sucker starving to death? LOL
          @cowboysdude
          Yessir. :-)
            Unfortunately, the api for this module is down for at least a few more months along with MMM-Lunartic. MMM-Lunartic continues to work with a temporary workaround.
            • uros76U Offline
              uros76
              Hi. Is there a way to show 24hr format of sunrise and sunset times?
              By the way, it still works great without images.
                Mykle1 Project Sponsor Module Developer @uros76
                @uros76
                I added a config option timeFormat: "H:mm", // "h:mm a". However, I cannot push the files to github at the moment. github is acting weird. As soon as github cooperates I’ll upload the files. You can use any format you like now. Thanks for the suggestion and the kind words.
                  Mykle1 Project Sponsor Module Developer @Mykle1
                  @Mykle1
                  Ok, I beat github into submission. Do a git pull in the MMM-SunRiseSet directory to get the new files. Take note of the new config option.
                    @Mykle1
                    Hopefully, the api will be up and running this summer. That is the api’s current projection.
                    • uros76U Offline
                      uros76
                      Excellent stuff @Mykle1!!! Thanks for adding 24hr time config option.
                        @uros76
                        It was your idea. So, thank you. :thumbsup:
                        • K Offline
                          killing joke
                          Does anybody know if the api running again or has further information about it? it have still the mini icon for pictures on my screen :- (
                          • uros76U Offline
                            uros76
                            For me, it works fine without images or icons, just text.
                              Mykle1 Project Sponsor Module Developer @killing joke
                              @killing-joke @uros76
                              The USNO api is still down.
                              “This US Naval Observatory Website is undergoing modernization and will be offline starting Thursday, 24 October 2019. The expected completion of work and return of service is estimated to be spring, 2021, subject to change due to potential impacts of COVID-19. Please visit usno.navy.mil and submit a Requirements Form to the USNO PAO if the information you are seeking is not accessible via another means.”
                              • K Offline
                                killing joke
                                Thanks @ Mykle1. I hope it will work again in spring 2021.
                                  @killing-joke
                                  Yeah, so do I. (fingers crossed)
                                  • W Offline
                                    Wenike
                                    I’ve hidden the image as that is not something I’m interested in (this module works fabulously alongside ones that display a picture of Earth), but I’m assuming the API being down (and me not using it before) is why it has my sunrise/sunset times off (sunrise at ~2AM and sunset at noon)? My lat/long is accurate, double-checked on Google Maps.
                                      Mykle1 Project Sponsor Module Developer @Wenike
                                      @Wenike
                                      Can you give me your lat and long, or something close to it, or a city nearby, so I can see what’s going on?
                                      • W Offline
                                        Wenike @Mykle1
                                        @Mykle1 latitude: “39.161999”,
                                        longitude: “-84.456886”,
                                          sdetweil @Wenike
                                          @Wenike dont need quotes for numbers
                                          Mykle1M W 2 Replies Last reply Reply Quote 0
                                            @sdetweil said in MMM-SunRiseSet:
                                            In this case, they are a string
                                            • 2 / 3
