    MMM-Tado not working.
    15 Posts 3 Posters 5.9k Views 3 Watching
    • W Offline
      Wrangler
      I updated using you’re update script ;-)
        sdetweil @Wrangler
        @Wrangler i don’t know what that means… just now or before?
        show me the ~/MagicMirror/installers/upgrade.log
        • W Offline
          Wrangler @sdetweil
          First time I used you’re script, everything was working fine except the MMM-Tado module after the update.
          then I did a fresh install using you’re install script and started from scratch so I don’t think the log will give you the info you need but here it is:
          pi@MagicMirror:~/MagicMirror/installers $ nano upgrade.log
            GNU nano 3.2        upgrade.log
             installers/mm.sh
             package-lock.json
          save/restore files selection = n
          restoring installers/mm.sh from repo
          restoring package-lock.json from repo
          test merge result rc='' , if empty, no conflicts
          executing merge, apply specified
          merge result rc= 0
           Already up to date.
          processor architecture is armv7l
          > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
          > node install.js
          Downloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
          [>                                            ] 0.0% (0 B/s)
          ^[[1000D^[[0K^[[1A^[[1000D^[[0K^[[1A^[[1000D^[[0KDownloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
          ^[[1000D^[[0K^[[1A^[[1000D^[[0K^[[1A^[[1000D^[[0KDownloading tmp-2885-1-SHASUMS256.txt-6.1.7
          [============================================>] 100.0% of 5.56 kB (5.56 kB/s)
          > magicmirror@2.11.0 install /home/pi/MagicMirror
          " && cd vendor && npm install --loglevel=error
          audited 150 packages in 6.864s
          found 8 vulnerabilities (7 low, 1 high)
            run `npm audit fix` to fix them, or `npm audit` for details
          > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
          > npm run install-fonts && echo "MagicMirror installation finished successfully!
          > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
          > echo "Installing fonts ...
          " && cd fonts && npm install --loglevel=error
          audited 1 package in 0.877s
          found 0 vulnerabilities
          added 3 packages from 39 contributors, removed 1 package, updated 30 packages and audited 1031 packages in 136.887s
          11 packages are looking for funding
            run `npm fund` for details
          found 27 vulnerabilities (24 low, 3 moderate)
          npm install completed - do mei 14 20:53:51 CEST 2020 on base
          fixing sandbox permissions
          downloading dumpactivemodules script
          processing for module MMM-Buienradar please wait
          npm notice created a lockfile as package-lock.json. You should commit this file.
          npm WARN MMM-Buienradar@1.0.1 No repository field.
          up to date in 1.353s
          processing complete for module MMM-Buienradar
          processing for module MMM-NewPIR please wait
          > epoll@3.0.0 install /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
          > node-gyp rebuild
          make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt binnengegaan
            CXX(target) Release/obj.target/epoll/src/epoll.o
            SOLINK_MODULE(target) Release/obj.target/epoll.node
            COPY Release/epoll.node
          make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt verlaten
          > MMM-NewPIR@2.3.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
          > scripts/installer.sh
          + electron-rebuild@1.11.0
          updated 1 package and audited 171 packages in 28.741s
          - Searching dependency tree
          ✔ Rebuild Complete
          added 171 packages from 120 contributors and audited 171 packages in 127.848s
          2 packages are looking for funding
          processing complete for module MMM-NewPIR
          processing for module MMM-NOAA3 please wait
          added 83 packages from 74 contributors and audited 83 packages in 11.955s
          processing complete for module MMM-NOAA3
          processing for module MMM-SystemStats please wait
          added 1 package from 1 contributor and audited 1 package in 1.621s
          processing complete for module MMM-SystemStats
          restoring custom.css
          removing git alias
          Upgrade ended - do mei 14 20:57:27 CEST 2020
          Upgrade started - do mei 14 21:02:17 CEST 2020
          system is Linux MagicMirror 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
          user requested to force apply changes
          doing test run = false
          saving custom.css
          remote name = origin
          upgrading from version 2.11.0 to 2.11.0
          fetching latest revisions
          git fetch rc=0
          current branch = master
          On branch master
          Your branch is up to date with 'origin/master'.
            (use "git add <file>..." to update what will be committed)
            (use "git checkout -- <file>..." to discard changes in working directory)
                  modified:   package-lock.json
                  modified:   package.json
          Untracked files:
            (use "git add <file>..." to include in what will be committed)
                  css/save_custom.css
                  installers/pm2_MagicMirror.json
                  run-start.sh
          no changes added to commit (use "git add" and/or "git commit -a")
          there are 2 local files that are different than the master repo
             package-lock.json
             package.json
          restoring package.json from repo
          merge result rc= 0
           Already up to date.
          audited 150 packages in 7.296s
          audited 1 package in 0.849s
          added 3 packages from 3 contributors, removed 20 packages, updated 3 packages and audited 1031 packages in 59.72s
          npm install completed - do mei 14 21:03:28 CEST 2020 on base
          up to date in 1.384s
          > node-gyp rebuild
          updated 1 package and audited 171 packages in 23.5s
          ✔ Rebuild Complete
          added 171 packages from 120 contributors and audited 171 packages in 84.616s
          added 83 packages from 74 contributors and audited 83 packages in 12.286s
          added 1 package from 1 contributor and audited 1 package in 3.883s
          removing git alias
          Upgrade ended - do mei 14 21:06:07 CEST 2020
          Upgrade started - zo mei 17 08:02:04 CEST 2020
          user requested to apply changes
          saving custom.css
          local version 2.11.0 already same as master 2.11.0
          removing git alias
          Upgrade ended - zo mei 17 08:02:05 CEST 2020
          Upgrade started - do mei 21 08:02:38 CEST 2020
          saving custom.css
          removing git alias
          Upgrade ended - do mei 21 08:02:39 CEST 2020
          Upgrade started - za mei 23 07:56:26 CEST 2020
          saving custom.css
          removing git alias
          Upgrade ended - za mei 23 07:56:27 CEST 2020
          Upgrade started - vr mei 29 23:01:44 CEST 2020
          saving custom.css
          removing git alias
          Upgrade ended - vr mei 29 23:01:45 CEST 2020
            sdetweil @Wrangler
            @Wrangler ok, got it…
            MMM-Tado has a bug really… it USES stuff but doesn’t document them
            const TadoClient = require(“tado-client”);
            const logger = require(“mocha-logger”);
            but there is no package.json, and he loads a previous copy of node_modules in his folder which is now out of synch
            so, you need to do these updates manually
            cd MMM-Tado
            rm -rf node_modules
            rm package-lock.json
            npm install tado-client --save
            npm install mocha-logger --save
            then you can restart MM and it should work…
            my script looks for package.json, and there isn’t one…
            • W Offline
              Wrangler @sdetweil
              @sdetweil said in MMM-Tado not working.:
              No luck ```
              pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install tado-client --save
              npm ERR! code E404
              npm ERR! 404 Not Found - GET https://registry.npmjs.org/tado-client - Not found
              npm ERR! 404
              npm ERR! 404  'tado-client@latest' is not in the npm registry.
              npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
              npm ERR! 404
              npm ERR! 404 Note that you can also install from a
              npm ERR! 404 tarball, folder, http url, or git url.
              npm ERR!     /home/pi/.npm/_logs/2020-05-30T14_54_13_631Z-debug.log
              pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install mocha-logger --save
              npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              + mocha-logger@1.0.6
              removed 3 packages, updated 1 package and audited 1120 packages in 37.011s
              74 packages are looking for funding
              found 3 low severity vulnerabilities
                sdetweil @Wrangler
                @Wrangler yep, looks like he used a private tado-client module… there is a public node-tado-client , but some of the code would have to change…
                sorry…
                • W Offline
                  Wrangler @sdetweil
                  Thanks for the effort, I wait for a update or try to live with it :confused_face:
                    sdetweil @Wrangler
                    @Wrangler I added this topic to the issue already open on the node-modules libraries
                    https://github.com/WouterEekhout/MMM-Tado/issues/8
                    • W Offline
                      Wrangler @sdetweil
                      :thumbs_up:
                      • W Offline
                        WouterEekhout
                        Thanks for the feedback. The master-branch has been updated. After git pull, do a npm install.
