    MMM-Tado not working.
    15 Posts 3 Posters 7.0k Views 3 Watching
    • W
      Wrangler @sdetweil
      First time I used you’re script, everything was working fine except the MMM-Tado module after the update.
      then I did a fresh install using you’re install script and started from scratch so I don’t think the log will give you the info you need but here it is:
      pi@MagicMirror:~/MagicMirror/installers $ nano upgrade.log
        GNU nano 3.2        upgrade.log
         installers/mm.sh
         package-lock.json
      save/restore files selection = n
      restoring installers/mm.sh from repo
      restoring package-lock.json from repo
      test merge result rc='' , if empty, no conflicts
      executing merge, apply specified
      merge result rc= 0
       Already up to date.
      processor architecture is armv7l
      > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      Downloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
      [>                                            ] 0.0% (0 B/s)
      ^[[1000D^[[0K^[[1A^[[1000D^[[0K^[[1A^[[1000D^[[0KDownloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
      ^[[1000D^[[0K^[[1A^[[1000D^[[0K^[[1A^[[1000D^[[0KDownloading tmp-2885-1-SHASUMS256.txt-6.1.7
      [============================================>] 100.0% of 5.56 kB (5.56 kB/s)
      > magicmirror@2.11.0 install /home/pi/MagicMirror
      " && cd vendor && npm install --loglevel=error
      audited 150 packages in 6.864s
      found 8 vulnerabilities (7 low, 1 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
      > npm run install-fonts && echo "MagicMirror installation finished successfully!
      > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
      > echo "Installing fonts ...
      " && cd fonts && npm install --loglevel=error
      audited 1 package in 0.877s
      found 0 vulnerabilities
      added 3 packages from 39 contributors, removed 1 package, updated 30 packages and audited 1031 packages in 136.887s
      11 packages are looking for funding
        run `npm fund` for details
      found 27 vulnerabilities (24 low, 3 moderate)
      npm install completed - do mei 14 20:53:51 CEST 2020 on base
      fixing sandbox permissions
      downloading dumpactivemodules script
      processing for module MMM-Buienradar please wait
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN MMM-Buienradar@1.0.1 No repository field.
      up to date in 1.353s
      processing complete for module MMM-Buienradar
      processing for module MMM-NewPIR please wait
      > epoll@3.0.0 install /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
      > node-gyp rebuild
      make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt binnengegaan
        CXX(target) Release/obj.target/epoll/src/epoll.o
        SOLINK_MODULE(target) Release/obj.target/epoll.node
        COPY Release/epoll.node
      make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt verlaten
      > MMM-NewPIR@2.3.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
      > scripts/installer.sh
      + electron-rebuild@1.11.0
      updated 1 package and audited 171 packages in 28.741s
      - Searching dependency tree
      ✔ Rebuild Complete
      added 171 packages from 120 contributors and audited 171 packages in 127.848s
      2 packages are looking for funding
      processing complete for module MMM-NewPIR
      processing for module MMM-NOAA3 please wait
      added 83 packages from 74 contributors and audited 83 packages in 11.955s
      processing complete for module MMM-NOAA3
      processing for module MMM-SystemStats please wait
      added 1 package from 1 contributor and audited 1 package in 1.621s
      processing complete for module MMM-SystemStats
      restoring custom.css
      removing git alias
      Upgrade ended - do mei 14 20:57:27 CEST 2020
      Upgrade started - do mei 14 21:02:17 CEST 2020
      system is Linux MagicMirror 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      user requested to force apply changes
      doing test run = false
      saving custom.css
      remote name = origin
      upgrading from version 2.11.0 to 2.11.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is up to date with 'origin/master'.
        (use "git add <file>..." to update what will be committed)
        (use "git checkout -- <file>..." to discard changes in working directory)
              modified:   package-lock.json
              modified:   package.json
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
              css/save_custom.css
              installers/pm2_MagicMirror.json
              run-start.sh
      no changes added to commit (use "git add" and/or "git commit -a")
      there are 2 local files that are different than the master repo
         package-lock.json
         package.json
      restoring package.json from repo
      merge result rc= 0
       Already up to date.
      audited 150 packages in 7.296s
      audited 1 package in 0.849s
      added 3 packages from 3 contributors, removed 20 packages, updated 3 packages and audited 1031 packages in 59.72s
      npm install completed - do mei 14 21:03:28 CEST 2020 on base
      up to date in 1.384s
      > node-gyp rebuild
      updated 1 package and audited 171 packages in 23.5s
      ✔ Rebuild Complete
      added 171 packages from 120 contributors and audited 171 packages in 84.616s
      added 83 packages from 74 contributors and audited 83 packages in 12.286s
      added 1 package from 1 contributor and audited 1 package in 3.883s
      removing git alias
      Upgrade ended - do mei 14 21:06:07 CEST 2020
      Upgrade started - zo mei 17 08:02:04 CEST 2020
      user requested to apply changes
      saving custom.css
      local version 2.11.0 already same as master 2.11.0
      removing git alias
      Upgrade ended - zo mei 17 08:02:05 CEST 2020
      Upgrade started - do mei 21 08:02:38 CEST 2020
      saving custom.css
      removing git alias
      Upgrade ended - do mei 21 08:02:39 CEST 2020
      Upgrade started - za mei 23 07:56:26 CEST 2020
      saving custom.css
      removing git alias
      Upgrade ended - za mei 23 07:56:27 CEST 2020
      Upgrade started - vr mei 29 23:01:44 CEST 2020
      saving custom.css
      removing git alias
      Upgrade ended - vr mei 29 23:01:45 CEST 2020
        sdetweil @Wrangler
        @Wrangler ok, got it…
        MMM-Tado has a bug really… it USES stuff but doesn’t document them
        const TadoClient = require(“tado-client”);
        const logger = require(“mocha-logger”);
        but there is no package.json, and he loads a previous copy of node_modules in his folder which is now out of synch
        so, you need to do these updates manually
        cd MMM-Tado
        rm -rf node_modules
        rm package-lock.json
        npm install tado-client --save
        npm install mocha-logger --save
        then you can restart MM and it should work…
        my script looks for package.json, and there isn’t one…
        W 1 Reply Last reply
        • W
          Wrangler @sdetweil
          @sdetweil said in MMM-Tado not working.:
          No luck ```
          pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install tado-client --save
          npm ERR! code E404
          npm ERR! 404 Not Found - GET https://registry.npmjs.org/tado-client - Not found
          npm ERR! 404
          npm ERR! 404  'tado-client@latest' is not in the npm registry.
          npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
          npm ERR! 404
          npm ERR! 404 Note that you can also install from a
          npm ERR! 404 tarball, folder, http url, or git url.
          npm ERR!     /home/pi/.npm/_logs/2020-05-30T14_54_13_631Z-debug.log
          pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install mocha-logger --save
          npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          + mocha-logger@1.0.6
          removed 3 packages, updated 1 package and audited 1120 packages in 37.011s
          74 packages are looking for funding
          found 3 low severity vulnerabilities
            sdetweil @Wrangler
            @Wrangler yep, looks like he used a private tado-client module… there is a public node-tado-client , but some of the code would have to change…
            sorry…
            • W
              Wrangler @sdetweil
              Thanks for the effort, I wait for a update or try to live with it :confused_face:
                sdetweil @Wrangler
                @Wrangler I added this topic to the issue already open on the node-modules libraries
                https://github.com/WouterEekhout/MMM-Tado/issues/8
                • W
                  Wrangler @sdetweil
                  :thumbs_up:
                  • W
                    WouterEekhout
                    Thanks for the feedback. The master-branch has been updated. After git pull, do a npm install.
                    • W
                      Wrangler @WouterEekhout
                      @WouterEekhout
                      Thanks,
                      Git pull dit not work.
                      pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ git pull
                      remote: Enumerating objects: 20, done.
                      remote: Counting objects: 100% (20/20), done.
                      remote: Compressing objects: 100% (9/9), done.
                      remote: Total 14 (delta 8), reused 9 (delta 5), pack-reused 0
                      Unpacking objects: 100% (14/14), done.
                      From https://github.com/WouterEekhout/MMM-Tado
                         7e91b79..59a7fc1  master     -> origin/master
                       * [new branch]      2020-june  -> origin/2020-june
                      Updating 7e91b79..59a7fc1
                      error: Your local changes to the following files would be overwritten by merge:
                      	MMM-Tado.js
                      Please commit your changes or stash them before you merge.
                      Aborting
                      But after removing MMM-Tado and reinstalling it works.
                      Thanks.
                      • W
                        WouterEekhout
                        @Wrangler It looks like you’ve made some changes to the MMM-Tado.js file.
                        Try:
                        git checkout MMM-Tado.js
                        git pull
                        • W
                          @WouterEekhout
                          Already did a new install of the module, and it is working now.
