    MMM-Tado not working.
    15 Posts 3 Posters 6.9k Views 3 Watching
    • W
      Wrangler
      Hello.
      I need some help, after updating to V2.11.0 the MMM-Tado module is not working, if I set module to “disable: False” everything is working ok, and after setting “Disable: true” I get a black screen with a cursor??
      No errors just a black screen.
      what dit I do;
      Reinstalling the MMM-Tado module.
      recreating config.js.
      and even did a complete fresh install of MM.
      still no luck.
      Running MM on Raspberry pi 3 Model b+
      MMM-Buienradar, works perfect
      MMM-NewPIR, works perfect
      MMM-NOAA3, works perfect
      MMM-SimpleLogo, works perfect
      MMM-SystemStats, works perfect
      MMM-Tado, Not working
      MMM-TomTomTrafficIncidents, works perfect.
      Can someone tell me where to start looking??
      Thanks, wrangler.
        sdetweil @Wrangler
        @Wrangler how did u update to 2.11? there were dependency changes that force you to find each module with a package.json file and do an npm install in each such module folder
        if u had used the new upgrade script, this would have been done for you
        see https://github.com/sdetweil/MagicMirror_scripts
        • W
          Wrangler
          I updated using you’re update script ;-)
            sdetweil @Wrangler
            @Wrangler i don’t know what that means… just now or before?
            show me the ~/MagicMirror/installers/upgrade.log
            • W
              Wrangler @sdetweil
              First time I used you’re script, everything was working fine except the MMM-Tado module after the update.
              then I did a fresh install using you’re install script and started from scratch so I don’t think the log will give you the info you need but here it is:
              pi@MagicMirror:~/MagicMirror/installers $ nano upgrade.log
                GNU nano 3.2        upgrade.log
                 installers/mm.sh
                 package-lock.json
              save/restore files selection = n
              restoring installers/mm.sh from repo
              restoring package-lock.json from repo
              test merge result rc='' , if empty, no conflicts
              executing merge, apply specified
              merge result rc= 0
               Already up to date.
              processor architecture is armv7l
              > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              Downloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
              [>                                            ] 0.0% (0 B/s)
              ^[[1000D^[[0K^[[1A^[[1000D^[[0K^[[1A^[[1000D^[[0KDownloading tmp-2885-0-electron-v6.1.7-linux-armv7l.zip
              ^[[1000D^[[0K^[[1A^[[1000D^[[0K^[[1A^[[1000D^[[0KDownloading tmp-2885-1-SHASUMS256.txt-6.1.7
              [============================================>] 100.0% of 5.56 kB (5.56 kB/s)
              > magicmirror@2.11.0 install /home/pi/MagicMirror
              " && cd vendor && npm install --loglevel=error
              audited 150 packages in 6.864s
              found 8 vulnerabilities (7 low, 1 high)
                run `npm audit fix` to fix them, or `npm audit` for details
              > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
              > npm run install-fonts && echo "MagicMirror installation finished successfully!
              > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
              > echo "Installing fonts ...
              " && cd fonts && npm install --loglevel=error
              audited 1 package in 0.877s
              found 0 vulnerabilities
              added 3 packages from 39 contributors, removed 1 package, updated 30 packages and audited 1031 packages in 136.887s
              11 packages are looking for funding
                run `npm fund` for details
              found 27 vulnerabilities (24 low, 3 moderate)
              npm install completed - do mei 14 20:53:51 CEST 2020 on base
              fixing sandbox permissions
              downloading dumpactivemodules script
              processing for module MMM-Buienradar please wait
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN MMM-Buienradar@1.0.1 No repository field.
              up to date in 1.353s
              processing complete for module MMM-Buienradar
              processing for module MMM-NewPIR please wait
              > epoll@3.0.0 install /home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll
              > node-gyp rebuild
              make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt binnengegaan
                CXX(target) Release/obj.target/epoll/src/epoll.o
                SOLINK_MODULE(target) Release/obj.target/epoll.node
                COPY Release/epoll.node
              make: Map '/home/pi/MagicMirror/modules/MMM-NewPIR/node_modules/epoll/build' wordt verlaten
              > MMM-NewPIR@2.3.1 install /home/pi/MagicMirror/modules/MMM-NewPIR
              > scripts/installer.sh
              + electron-rebuild@1.11.0
              updated 1 package and audited 171 packages in 28.741s
              - Searching dependency tree
              ✔ Rebuild Complete
              added 171 packages from 120 contributors and audited 171 packages in 127.848s
              2 packages are looking for funding
              processing complete for module MMM-NewPIR
              processing for module MMM-NOAA3 please wait
              added 83 packages from 74 contributors and audited 83 packages in 11.955s
              processing complete for module MMM-NOAA3
              processing for module MMM-SystemStats please wait
              added 1 package from 1 contributor and audited 1 package in 1.621s
              processing complete for module MMM-SystemStats
              restoring custom.css
              removing git alias
              Upgrade ended - do mei 14 20:57:27 CEST 2020
              Upgrade started - do mei 14 21:02:17 CEST 2020
              system is Linux MagicMirror 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              user requested to force apply changes
              doing test run = false
              saving custom.css
              remote name = origin
              upgrading from version 2.11.0 to 2.11.0
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up to date with 'origin/master'.
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
                      modified:   package-lock.json
                      modified:   package.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
                      css/save_custom.css
                      installers/pm2_MagicMirror.json
                      run-start.sh
              no changes added to commit (use "git add" and/or "git commit -a")
              there are 2 local files that are different than the master repo
                 package-lock.json
                 package.json
              restoring package.json from repo
              merge result rc= 0
               Already up to date.
              audited 150 packages in 7.296s
              audited 1 package in 0.849s
              added 3 packages from 3 contributors, removed 20 packages, updated 3 packages and audited 1031 packages in 59.72s
              npm install completed - do mei 14 21:03:28 CEST 2020 on base
              up to date in 1.384s
              > node-gyp rebuild
              updated 1 package and audited 171 packages in 23.5s
              ✔ Rebuild Complete
              added 171 packages from 120 contributors and audited 171 packages in 84.616s
              added 83 packages from 74 contributors and audited 83 packages in 12.286s
              added 1 package from 1 contributor and audited 1 package in 3.883s
              removing git alias
              Upgrade ended - do mei 14 21:06:07 CEST 2020
              Upgrade started - zo mei 17 08:02:04 CEST 2020
              user requested to apply changes
              saving custom.css
              local version 2.11.0 already same as master 2.11.0
              removing git alias
              Upgrade ended - zo mei 17 08:02:05 CEST 2020
              Upgrade started - do mei 21 08:02:38 CEST 2020
              saving custom.css
              removing git alias
              Upgrade ended - do mei 21 08:02:39 CEST 2020
              Upgrade started - za mei 23 07:56:26 CEST 2020
              saving custom.css
              removing git alias
              Upgrade ended - za mei 23 07:56:27 CEST 2020
              Upgrade started - vr mei 29 23:01:44 CEST 2020
              saving custom.css
              removing git alias
              Upgrade ended - vr mei 29 23:01:45 CEST 2020
                sdetweil @Wrangler
                @Wrangler ok, got it…
                MMM-Tado has a bug really… it USES stuff but doesn’t document them
                const TadoClient = require(“tado-client”);
                const logger = require(“mocha-logger”);
                but there is no package.json, and he loads a previous copy of node_modules in his folder which is now out of synch
                so, you need to do these updates manually
                cd MMM-Tado
                rm -rf node_modules
                rm package-lock.json
                npm install tado-client --save
                npm install mocha-logger --save
                then you can restart MM and it should work…
                my script looks for package.json, and there isn’t one…
                • W
                  Wrangler @sdetweil
                  @sdetweil said in MMM-Tado not working.:
                  No luck ```
                  pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install tado-client --save
                  npm ERR! code E404
                  npm ERR! 404 Not Found - GET https://registry.npmjs.org/tado-client - Not found
                  npm ERR! 404
                  npm ERR! 404  'tado-client@latest' is not in the npm registry.
                  npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                  npm ERR! 404
                  npm ERR! 404 Note that you can also install from a
                  npm ERR! 404 tarball, folder, http url, or git url.
                  npm ERR!     /home/pi/.npm/_logs/2020-05-30T14_54_13_631Z-debug.log
                  pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install mocha-logger --save
                  npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  + mocha-logger@1.0.6
                  removed 3 packages, updated 1 package and audited 1120 packages in 37.011s
                  74 packages are looking for funding
                  found 3 low severity vulnerabilities
                    sdetweil @Wrangler
                    @Wrangler yep, looks like he used a private tado-client module… there is a public node-tado-client , but some of the code would have to change…
                    sorry…
                    • W
                      Wrangler @sdetweil
                      Thanks for the effort, I wait for a update or try to live with it :confused_face:
                        sdetweil @Wrangler
                        @Wrangler I added this topic to the issue already open on the node-modules libraries
                        https://github.com/WouterEekhout/MMM-Tado/issues/8
                        • W
                          Wrangler @sdetweil
                          :thumbs_up:
                          • W
                            WouterEekhout
                            Thanks for the feedback. The master-branch has been updated. After git pull, do a npm install.
                            • W
                              Wrangler @WouterEekhout
                              @WouterEekhout
                              Thanks,
                              Git pull dit not work.
                              pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ git pull
                              remote: Enumerating objects: 20, done.
                              remote: Counting objects: 100% (20/20), done.
                              remote: Compressing objects: 100% (9/9), done.
                              remote: Total 14 (delta 8), reused 9 (delta 5), pack-reused 0
                              Unpacking objects: 100% (14/14), done.
                              From https://github.com/WouterEekhout/MMM-Tado
                                 7e91b79..59a7fc1  master     -> origin/master
                               * [new branch]      2020-june  -> origin/2020-june
                              Updating 7e91b79..59a7fc1
                              error: Your local changes to the following files would be overwritten by merge:
                              	MMM-Tado.js
                              Please commit your changes or stash them before you merge.
                              Aborting
                              But after removing MMM-Tado and reinstalling it works.
                              Thanks.
                              • W
                                WouterEekhout
                                @Wrangler It looks like you’ve made some changes to the MMM-Tado.js file.
                                Try:
                                git checkout MMM-Tado.js
                                git pull
                                • W
                                  @WouterEekhout
                                  Already did a new install of the module, and it is working now.
