    MMM-Tado not working.
    15 Posts 3 Posters 7.0k Views 3 Watching
      sdetweil @Wrangler
      @Wrangler ok, got it…
      MMM-Tado has a bug really… it USES stuff but doesn’t document them
      const TadoClient = require(“tado-client”);
      const logger = require(“mocha-logger”);
      but there is no package.json, and he loads a previous copy of node_modules in his folder which is now out of synch
      so, you need to do these updates manually
      cd MMM-Tado
      rm -rf node_modules
      rm package-lock.json
      npm install tado-client --save
      npm install mocha-logger --save
      then you can restart MM and it should work…
      my script looks for package.json, and there isn’t one…
      W 1 Reply Last reply
      • W
        Wrangler @sdetweil
        @sdetweil said in MMM-Tado not working.:
        No luck ```
        pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install tado-client --save
        npm ERR! code E404
        npm ERR! 404 Not Found - GET https://registry.npmjs.org/tado-client - Not found
        npm ERR! 404
        npm ERR! 404  'tado-client@latest' is not in the npm registry.
        npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        npm ERR!     /home/pi/.npm/_logs/2020-05-30T14_54_13_631Z-debug.log
        pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ npm install mocha-logger --save
        npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + mocha-logger@1.0.6
        removed 3 packages, updated 1 package and audited 1120 packages in 37.011s
        74 packages are looking for funding
          run `npm fund` for details
        found 3 low severity vulnerabilities
          run `npm audit fix` to fix them, or `npm audit` for details
          sdetweil @Wrangler
          @Wrangler yep, looks like he used a private tado-client module… there is a public node-tado-client , but some of the code would have to change…
          sorry…
          • W
            Wrangler @sdetweil
            Thanks for the effort, I wait for a update or try to live with it :confused_face:
              sdetweil @Wrangler
              @Wrangler I added this topic to the issue already open on the node-modules libraries
              https://github.com/WouterEekhout/MMM-Tado/issues/8
              • W
                Wrangler @sdetweil
                :thumbs_up:
                • W
                  WouterEekhout
                  Thanks for the feedback. The master-branch has been updated. After git pull, do a npm install.
                  • W
                    Wrangler @WouterEekhout
                    @WouterEekhout
                    Thanks,
                    Git pull dit not work.
                    pi@MagicMirror:~/MagicMirror/modules/MMM-Tado $ git pull
                    remote: Enumerating objects: 20, done.
                    remote: Counting objects: 100% (20/20), done.
                    remote: Compressing objects: 100% (9/9), done.
                    remote: Total 14 (delta 8), reused 9 (delta 5), pack-reused 0
                    Unpacking objects: 100% (14/14), done.
                    From https://github.com/WouterEekhout/MMM-Tado
                       7e91b79..59a7fc1  master     -> origin/master
                     * [new branch]      2020-june  -> origin/2020-june
                    Updating 7e91b79..59a7fc1
                    error: Your local changes to the following files would be overwritten by merge:
                    	MMM-Tado.js
                    Please commit your changes or stash them before you merge.
                    Aborting
                    But after removing MMM-Tado and reinstalling it works.
                    Thanks.
                    • W
                      WouterEekhout
                      @Wrangler It looks like you’ve made some changes to the MMM-Tado.js file.
                      Try:
                      git checkout MMM-Tado.js
                      git pull
                      • W
                        @WouterEekhout
                        Already did a new install of the module, and it is working now.
