    mmm assistant mk2
    112 Posts 12 Posters 73.7k Views 11 Watching
      dvbit @sdmydbr9
      @sdmydbr9 this happened to me too. It’s just that the error that is happening has a side effect the deletion of the index file. repull it.
      After fixing the main problem this will not happen anymore
        dvbit @Chris
        @Chris said in mmm assistant mk2:
        Small feedback after installation and use:
        it works very well.
        • I find it more fluid than the previous version. when invoked, it responds almost instantly. Before I used MMM-Hotword. I went on the integrated snowboy. Perhaps the speed of response comes from there.
        • I have multi task. I can play a youtube clip on the mirror and at the same time ask the assistant for a home automation or other command. Before that did not work.
        • I go through the Sony PS3 eye for the listening part. I did not have a problem with this one after the update.
        In short, that happiness.
        @Bugsounet
        The work you have done is truly superb. Congratulations to you all.
        Regards,
        Hi One question: were you successful with the sound wizard setup?
        Could you share the asoundrc file (hidden file located in your home directory)?
        I agree the plugin is just perfect (had it working but then I broke something)
          A Former User
          to regenerate it:
          go to desktop of the RPI
          • Right click in the sound icon
            -> select your prefered Output device
            -> select your prefered Input device
          Maybe reboot is needed after this (for MagicMirror app)
            A Former User
            Tips For all
            Don’t Forget to activate hardware acceleration of rpi in raspi-config (OPEN GL)
            needed for YT video / cast / weblinks in fullscreen and for have more reactive mirror
              dvbit @Guest
              @Bugsounet So I have "Output Device Settings " item greyed out in desktop sound menu.
              entries:
              • Analog
              • HDMI
              • USB Kinect Audio
              • Output Audio Device Settings : Greyed out
              Edit:
              Before sending Firmware to Kinect after boot (to enable it) the Ouput Device Settings Option is NOT there (also no Kinect Audio available)
              After sending it both Kinect and Output Deive Settings Appear
              trying to play the response using cvlc works but there is a PulseAudio error:
              VLC media player 3.0.8 Vetinari (revision 3.0.8-0-gf350b6b5a7)
              [01cb1d60] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
              [01cd0fc8] dummy interface: using the dummy interface module...
              Now rebooting and trying the plugin without uploading kinect audio firmware.
              By the way the Pulseaudio refuse seems to me consistent with the failed audio for the plugin
              DOH! I cannot try the plugin without the kinect audio firmware pushed (no other mic is attacched)
                dvbit @dvbit
                @dvbit said in mmm assistant mk2:
                HDMI
                One little Step ahead.
                Disabling Audio Output gives no audio feedback but then the mirrorr goes back into waiting state.
                So it get’s stuck in “Spinning State” because the audio fails.
                Maybe it’s obvious but I think it is interesting.
                and this from the log is also useful:
                [2020-06-01 19:27:11.533] [LOG]    [SNOWBOY] Retry restarting...
                [2020-06-01 19:27:13.588] [LOG]    [LPCM16] WARN: arecord: main:828: audio open error: Device or resource busy
                [2020-06-01 19:27:13.589] [LOG]    [SNOWBOY] Retry restarting...
                So my audio ouput device is "owned " by some other process I guess
                aplay -l gives:
                pi@MagicMirror:~/MagicMirror $ aplay -l
                **** List of PLAYBACK Hardware Devices ****
                card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
                  Subdevices: 4/4
                  Subdevice #0: subdevice #0
                  Subdevice #1: subdevice #1
                  Subdevice #2: subdevice #2
                  Subdevice #3: subdevice #3
                card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
                  Subdevices: 4/4
                  sdetweil @dvbit
                  @dvbit do
                  ps -ef | grep aplay
                  and see if its still running…
                    dvbit @sdetweil
                    @sdetweil nope I just grep my grep :-D
                      reddyman
                      Hmmm sorry to go a bit off topic but has anyone tried the new Assistant2Display module with the new GoogleAssistant? I can’t get it to work but I suspect I am missing something very obvious. I just don’t know what.
                      I can’t get the screen, briefToday, or Pir to work. I don’t get any errors, just nothing happens.
                      Config file:
                        module: "MMM-GoogleAssistant",
                        position: "fullscreen_above",
                         A2DServer: {
                            useA2D: true,
                          assistantConfig: {
                            //latitude: 51.508530,
                            //longitude: -0.076132,
                          micConfig: { // put there configuration generated by auto-installer
                            recorder: "arecord",
                            device: "plughw:2",
                          snowboy: {
                            Model: "smart_mirror",
                        module: "MMM-Assistant2Display",
                          debug:true,
                        pir: {
                            usePir: true,
                            pin: 4,
                            reverseValue: false
                        screen: {
                        useScreen: true,
                        delay: 1 * 60 * 1000,
                        turnOffDisplay: true,
                        ecoMode: true,
                        displayCounter: true,
                        text: "Auto Turn Off Screen:",
                        detectorSleeping: false,
                        governorSleeping: false,
                        rpi4: false
                      briefToday: {
                            useBriefToday: true,
                            welcome: "brief Today"
                      I don’t see the debug working either? Nothing generated on the terminal while the mirror is running at least.
                      [2020-06-01 16:51:49.870] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.0.0
                      [2020-06-01 16:51:49.885] [LOG]    [SNOWBOY] Model selected: smart_mirror
                      [2020-06-01 16:51:49.893] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
                      [2020-06-01 16:51:49.902] [LOG]    [ASSISTANT] Assistant2Display Server Started
                      [2020-06-01 16:51:49.908] [LOG]    [ASSISTANT] Google Assistant is initialized.
                      [2020-06-01 16:51:49.916] [LOG]    [A2D] MMM-Assistant2Display Version: 2.0.0
                      [2020-06-01 16:51:49.928] [LOG]    [A2D] Assistant2Display is initialized.
                      Anyone see what I’m missing? I suspect it’s something super simple but I can’t figure out what.
                        well, I though i’d give it a try… see what all the fuss is about!
                        1. on the install y/n prompts, the protocol is the Uppercased letter is the default, so whn you hit enter is does the default
                          it doesn’t do anything, have to enter Y or N (and then it takes off without waiting??)
                        2. audio doesn’t work for me…
                          and none of the choices match the system config (and none of them work)
                          system config, sounds fine, music, web sounds, system sounds.
                        aplay -l info
                          dvbit
                          A big thank You to @Bugsounet for his help in troubleshooting.
                          It was nothing to do with the modules but with my asoundrc config.
                          the ouput card/device were not correct.
                          Thanks again!
                            A Former User
                            @dvbit: no problem ! with pleasure ;)
                              A Former User
                              @reddyman : turn on modules. just YouTube by default is turn on
                              link / photo is disabled by default
                                  debug:true,
                                  // make you config there !
                               // not there
                                reddyman @Guest
                                @Bugsounet said in mmm assistant mk2:
                                    debug:true,
                                 // not there
                                …I am an idiot. Hahaha, I knew it was something super simple. Smh, thanks for putting up with idiots like me :p
                                  A Former User
                                  @reddyman : don’t worry, it’s arrive to me too sometime !
                                    James Farmer
                                    First, I say thanks to @Bugsounet , I only started my mirror a few weeks and have had Assistant working. Upgraded to GoogleAssistant and it is much quicker.
                                    Unfortunately I have a few problems with it now, one is sound, but im 99.99% sure because i have sound config wrong. Nothing to do with module. !
                                    The only other issue i have is i use pages and when googleAssisatnt comes on screen part of it is still hidden by the modules on screen.
                                    Just wondering if anyone have this problem. ?
                                    Ive set it to fullscreen_above in GoogleAssistant so thought this wouldnt be a problem. it worked ok with AssistantMK.
                                    Thankyou
                                      A Former User
                                      hi,
                                      1. what the problem ?
                                      2. for pages:
                                        I don’t know what this developer means …
                                        edit pages.css
                                        change it to:
                                      .fullscreen.above {
                                          z-index: 9999
                                      page should now works correctly
                                        James Farmer @Guest
                                        @Bugsounet Thanks that has fixed it, I need to have another go at learning css to try and sort out all the positions.
                                        Ill get back to trying to sort out sound.
                                        Thanks again
                                          JohnBachini
                                          @Bugsounet
                                          HI, Amazing work with GoogleAssist, it seems to be more responsive and accurate than AssistantMK2.
                                          Have an issue with the display of the googleAssistant banner. My Mirror is full screen, ie in custom.css i have :-
                                           body {
                                               margin: 0px;
                                               position: absolute;
                                               height: 100%;
                                               width: 100%;
                                          Which i hope is correct, im struggling with css side of things !! :-)
                                          But when the banner appears i have this issue,
                                          As top of banner is missing and width
                                          I looked at GoogleAssistant.css, but couldnt work out what needs to change.
                                            A Former User
                                            @JohnBachini :
                                            don’t work with this position ?
                                            Edit : Ah yes don’t work
                                            • 5 / 6
