    Remote control
    19 Posts 6 Posters 7.1k Views 7 Watching
    • H Offline
      hawkeye
      When i add this to my config my mirror stops working soon as i delete it starts again
      if i put my ip addy in for the pi with ports 8080 into my phone i can see the mirror but no remote control options where am i going wrong please
      module: ‘MMM-Remote-Control’
      , position: ‘bottom_left’
      customCommand: {}, // Optional, See “Using Custom Commands” below
      customMenu: “custom_menu.json”, // Optional, See “Custom Menu Items” below
      showModuleApiMenu: true, // Optional, Enable the Module Controls menu
      apiKey: “”, // Optional, See API/README.md for details
      Only thing i have working with my pi is kodi and thats on a spare i am a total NOOB and in need of a lot of help
        JohnBachini
        @hawkeye I dont use this module, but it looks like you have , position: ‘bottom_left’ You need to remove the comma at start of line.
        • H Offline
          hawkeye
          i tried that still no joy
          what i want to do is to be able to add and remove modules from my phone and having no luck
            sdetweil @hawkeye
            @hawkeye u need a comma at the end of each line… the one at the front is for the line before, but after has no ,
            also, check the actual text in config.js, the quote marcks, both single and double are the wrong kind, they are the word processing app type… (as they lean)… u need the text kind, straight up and down
            	module: 'MMM-Remote-Control',
            	position: 'bottom_left',
            		customCommand: {}, 		 // Optional, See "Using Custom Commands" below
            		customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
            		apiKey: "", 			 // Optional, See API/README.md for details
              concep86
              • H Offline
                hawkeye @sdetweil
                @sdetweil said in Remote control:
                module: ‘MMM-Remote-Control’,
                position: ‘bottom_left’,
                You rock that fixed that part now i just need to make it show modules so i can turn them off
                  sdetweil @hawkeye
                  @hawkeye there is a bug on 2.11 tgat stops remote control from working.
                  search the forum for the fix
                  • H Offline
                    hawkeye @sdetweil
                    @sdetweil yeah I’m no programmer
                    i need an idiots guide to things
                      sdetweil @hawkeye
                      @hawkeye you are replacing one file, no programming required
                      • H Offline
                        hawkeye @sdetweil
                        @sdetweil you have been a grate help so far and yes i know i am annoying but i cant find what i am to do
                          sdetweil @hawkeye
                          @hawkeye you are replacing the contents of ~/MagicMirror/js/socketclient.js
                          see this post for the (old) contents to put IN the file
                          https://forum.magicmirror.builders/topic/12485/has-anyone-got-mmm-remote-control-working-on-mm-2-11/10?page=1
                          • H Offline
                            hawkeye @sdetweil
                            @sdetweil see your totally awesome that’s fixed now wahoo
                            with your help im sure you could help me get this working awsome
                              sdetweil @hawkeye
                              @hawkeye i just searched in the forum on 2.11 remote control, that was the top result
                              • H Offline
                                hawkeye
                                I deleted every thing in the socketclient.js file and replaced with the following now the remote works like a charm
                                var MMSocket = function(moduleName) {
                                var self = this;
                                if (typeof moduleName !== "string") {
                                	throw new Error("Please set the module name for the MMSocket.");
                                self.moduleName = moduleName;
                                // Private Methods
                                self.socket = io("/" + self.moduleName);
                                var notificationCallback = function() {};
                                var onevent = self.socket.onevent;
                                self.socket.onevent = function(packet) {
                                	var args = packet.data || [];
                                	onevent.call(this, packet);    // original call
                                	packet.data = ["*"].concat(args);
                                	onevent.call(this, packet);      // additional call to catch-all
                                // register catch all.
                                self.socket.on("*", function(notification, payload) {
                                	if (notification !== "*") {
                                		notificationCallback(notification, payload);
                                // Public Methods
                                this.setNotificationCallback = function(callback) {
                                	notificationCallback = callback;
                                this.sendNotification = function(notification, payload) {
                                	if (typeof payload === "undefined") {
                                		payload = {};
                                	self.socket.emit(notification, payload);
                                  shawnlane
                                  @hawkeye Thank you for posting. This corrected my problem! I have so much to learn. Off to my next issue with getting the Google Photos module to work.
                                    sdetweil @shawnlane
                                    @shawnlane said in Remote control:
                                    there was a bug in 2.11 for that file… fixes only come every 3 months… so the workaround it to put the old file back
                                    • H Offline
                                      hawkeye
                                      its solved
                                      • V Offline
                                        videogame95
                                        Hi l see your having a similar problem as when add the script into my config file it stops l also remove the //
                                        To position it a the left bottom but it still didn’t work
                                        I set the IP. 0.0.0.0 and closed brackets []
                                        Set up any one on my IP address
                                        But it still no working.
                                        I know we should get a IP address on bottom of the mirror to type into our phone which open up app controller.
                                        If any can help us both please reply.
                                          sdetweil @videogame95
                                          @videogame95 show the config for his module and aove/below it
                                          a module is
                                             module:"name",
                                             position:"something",
                                                module specifc values
                                          note that whre u add this MAY reqire a trailing comma on the last line of the prior module, meaning, more coming
                                          keep the braces and brackets aligned up and down,
