    Remote control
    19 Posts 6 Posters 7.4k Views 7 Watching
    • H
      hawkeye
      i tried that still no joy
      what i want to do is to be able to add and remove modules from my phone and having no luck
        sdetweil @hawkeye
        @hawkeye u need a comma at the end of each line… the one at the front is for the line before, but after has no ,
        also, check the actual text in config.js, the quote marcks, both single and double are the wrong kind, they are the word processing app type… (as they lean)… u need the text kind, straight up and down
        	module: 'MMM-Remote-Control',
        	position: 'bottom_left',
        		customCommand: {}, 		 // Optional, See "Using Custom Commands" below
        		customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
        		showModuleApiMenu: true, // Optional, Enable the Module Controls menu
        		apiKey: "", 			 // Optional, See API/README.md for details
        H 1 Reply Last reply
          concep86
          • H
            hawkeye @sdetweil
            @sdetweil said in Remote control:
            module: ‘MMM-Remote-Control’,
            position: ‘bottom_left’,
            customCommand: {}, // Optional, See “Using Custom Commands” below
            customMenu: “custom_menu.json”, // Optional, See “Custom Menu Items” below
            apiKey: “”, // Optional, See API/README.md for details
            You rock that fixed that part now i just need to make it show modules so i can turn them off
              sdetweil @hawkeye
              @hawkeye there is a bug on 2.11 tgat stops remote control from working.
              search the forum for the fix
              • H
                hawkeye @sdetweil
                @sdetweil yeah I’m no programmer
                i need an idiots guide to things
                  sdetweil @hawkeye
                  @hawkeye you are replacing one file, no programming required
                  • H
                    hawkeye @sdetweil
                    @sdetweil you have been a grate help so far and yes i know i am annoying but i cant find what i am to do
                      sdetweil @hawkeye
                      @hawkeye you are replacing the contents of ~/MagicMirror/js/socketclient.js
                      see this post for the (old) contents to put IN the file
                      https://forum.magicmirror.builders/topic/12485/has-anyone-got-mmm-remote-control-working-on-mm-2-11/10?page=1
                      • H
                        hawkeye @sdetweil
                        @sdetweil see your totally awesome that’s fixed now wahoo
                        with your help im sure you could help me get this working awsome
                          sdetweil @hawkeye
                          @hawkeye i just searched in the forum on 2.11 remote control, that was the top result
                          • H
                            hawkeye
                            I deleted every thing in the socketclient.js file and replaced with the following now the remote works like a charm
                            var MMSocket = function(moduleName) {
                            var self = this;
                            if (typeof moduleName !== "string") {
                            	throw new Error("Please set the module name for the MMSocket.");
                            self.moduleName = moduleName;
                            // Private Methods
                            self.socket = io("/" + self.moduleName);
                            var notificationCallback = function() {};
                            var onevent = self.socket.onevent;
                            self.socket.onevent = function(packet) {
                            	var args = packet.data || [];
                            	onevent.call(this, packet);    // original call
                            	packet.data = ["*"].concat(args);
                            	onevent.call(this, packet);      // additional call to catch-all
                            // register catch all.
                            self.socket.on("*", function(notification, payload) {
                            	if (notification !== "*") {
                            		notificationCallback(notification, payload);
                            // Public Methods
                            this.setNotificationCallback = function(callback) {
                            	notificationCallback = callback;
                            this.sendNotification = function(notification, payload) {
                            	if (typeof payload === "undefined") {
                            		payload = {};
                            	self.socket.emit(notification, payload);
                              shawnlane
                              @hawkeye Thank you for posting. This corrected my problem! I have so much to learn. Off to my next issue with getting the Google Photos module to work.
                                sdetweil @shawnlane
                                @shawnlane said in Remote control:
                                there was a bug in 2.11 for that file… fixes only come every 3 months… so the workaround it to put the old file back
                                • H
                                  hawkeye
                                  its solved
                                  • V
                                    videogame95
                                    Hi l see your having a similar problem as when add the script into my config file it stops l also remove the //
                                    To position it a the left bottom but it still didn’t work
                                    I set the IP. 0.0.0.0 and closed brackets []
                                    Set up any one on my IP address
                                    But it still no working.
                                    I know we should get a IP address on bottom of the mirror to type into our phone which open up app controller.
                                    If any can help us both please reply.
                                      sdetweil @videogame95
                                      @videogame95 show the config for his module and aove/below it
                                      a module is
                                         module:"name",
                                         position:"something",
                                            module specifc values
                                      note that whre u add this MAY reqire a trailing comma on the last line of the prior module, meaning, more coming
                                      keep the braces and brackets aligned up and down,
