    Remote control
    19 Posts 6 Posters 7.2k Views 7 Watching
      concep86
      • H
        hawkeye @sdetweil
        @sdetweil said in Remote control:
        module: ‘MMM-Remote-Control’,
        position: ‘bottom_left’,
        customCommand: {}, // Optional, See “Using Custom Commands” below
        customMenu: “custom_menu.json”, // Optional, See “Custom Menu Items” below
        showModuleApiMenu: true, // Optional, Enable the Module Controls menu
        apiKey: “”, // Optional, See API/README.md for details
        You rock that fixed that part now i just need to make it show modules so i can turn them off
          sdetweil @hawkeye
          @hawkeye there is a bug on 2.11 tgat stops remote control from working.
          search the forum for the fix
          • H
            hawkeye @sdetweil
            @sdetweil yeah I’m no programmer
            i need an idiots guide to things
              sdetweil @hawkeye
              @hawkeye you are replacing one file, no programming required
              • H
                hawkeye @sdetweil
                @sdetweil you have been a grate help so far and yes i know i am annoying but i cant find what i am to do
                  sdetweil @hawkeye
                  @hawkeye you are replacing the contents of ~/MagicMirror/js/socketclient.js
                  see this post for the (old) contents to put IN the file
                  https://forum.magicmirror.builders/topic/12485/has-anyone-got-mmm-remote-control-working-on-mm-2-11/10?page=1
                  • H
                    hawkeye @sdetweil
                    @sdetweil see your totally awesome that’s fixed now wahoo
                    with your help im sure you could help me get this working awsome
                      sdetweil @hawkeye
                      @hawkeye i just searched in the forum on 2.11 remote control, that was the top result
                      • H
                        hawkeye
                        I deleted every thing in the socketclient.js file and replaced with the following now the remote works like a charm
                        var MMSocket = function(moduleName) {
                        var self = this;
                        if (typeof moduleName !== "string") {
                        	throw new Error("Please set the module name for the MMSocket.");
                        self.moduleName = moduleName;
                        // Private Methods
                        self.socket = io("/" + self.moduleName);
                        var notificationCallback = function() {};
                        var onevent = self.socket.onevent;
                        self.socket.onevent = function(packet) {
                        	var args = packet.data || [];
                        	onevent.call(this, packet);    // original call
                        	packet.data = ["*"].concat(args);
                        	onevent.call(this, packet);      // additional call to catch-all
                        // register catch all.
                        self.socket.on("*", function(notification, payload) {
                        	if (notification !== "*") {
                        		notificationCallback(notification, payload);
                        // Public Methods
                        this.setNotificationCallback = function(callback) {
                        	notificationCallback = callback;
                        this.sendNotification = function(notification, payload) {
                        	if (typeof payload === "undefined") {
                        		payload = {};
                        	self.socket.emit(notification, payload);
                          shawnlane
                          @hawkeye Thank you for posting. This corrected my problem! I have so much to learn. Off to my next issue with getting the Google Photos module to work.
                            sdetweil @shawnlane
                            @shawnlane said in Remote control:
                            there was a bug in 2.11 for that file… fixes only come every 3 months… so the workaround it to put the old file back
                            • H
                              hawkeye
                              its solved
                              • V
                                videogame95
                                Hi l see your having a similar problem as when add the script into my config file it stops l also remove the //
                                To position it a the left bottom but it still didn’t work
                                I set the IP. 0.0.0.0 and closed brackets []
                                Set up any one on my IP address
                                But it still no working.
                                I know we should get a IP address on bottom of the mirror to type into our phone which open up app controller.
                                If any can help us both please reply.
                                  sdetweil @videogame95
                                  @videogame95 show the config for his module and aove/below it
                                  a module is
                                     module:"name",
                                     position:"something",
                                        module specifc values
                                  note that whre u add this MAY reqire a trailing comma on the last line of the prior module, meaning, more coming
                                  keep the braces and brackets aligned up and down,
