    Remote control
    19 Posts 6 Posters 7.1k Views 7 Watching
    • H Offline
      hawkeye @sdetweil
      @sdetweil said in Remote control:
      module: ‘MMM-Remote-Control’,
      position: ‘bottom_left’,
      customCommand: {}, // Optional, See “Using Custom Commands” below
      customMenu: “custom_menu.json”, // Optional, See “Custom Menu Items” below
      showModuleApiMenu: true, // Optional, Enable the Module Controls menu
      apiKey: “”, // Optional, See API/README.md for details
      You rock that fixed that part now i just need to make it show modules so i can turn them off
        sdetweil @hawkeye
        @hawkeye there is a bug on 2.11 tgat stops remote control from working.
        search the forum for the fix
        • H Offline
          hawkeye @sdetweil
          @sdetweil yeah I’m no programmer
          i need an idiots guide to things
            sdetweil @hawkeye
            @hawkeye you are replacing one file, no programming required
            • H Offline
              hawkeye @sdetweil
              @sdetweil you have been a grate help so far and yes i know i am annoying but i cant find what i am to do
                sdetweil @hawkeye
                @hawkeye you are replacing the contents of ~/MagicMirror/js/socketclient.js
                see this post for the (old) contents to put IN the file
                https://forum.magicmirror.builders/topic/12485/has-anyone-got-mmm-remote-control-working-on-mm-2-11/10?page=1
                • H Offline
                  hawkeye @sdetweil
                  @sdetweil see your totally awesome that’s fixed now wahoo
                  with your help im sure you could help me get this working awsome
                    sdetweil @hawkeye
                    @hawkeye i just searched in the forum on 2.11 remote control, that was the top result
                    • H Offline
                      hawkeye
                      I deleted every thing in the socketclient.js file and replaced with the following now the remote works like a charm
                      var MMSocket = function(moduleName) {
                      var self = this;
                      if (typeof moduleName !== "string") {
                      	throw new Error("Please set the module name for the MMSocket.");
                      self.moduleName = moduleName;
                      // Private Methods
                      self.socket = io("/" + self.moduleName);
                      var notificationCallback = function() {};
                      var onevent = self.socket.onevent;
                      self.socket.onevent = function(packet) {
                      	var args = packet.data || [];
                      	onevent.call(this, packet);    // original call
                      	packet.data = ["*"].concat(args);
                      	onevent.call(this, packet);      // additional call to catch-all
                      // register catch all.
                      self.socket.on("*", function(notification, payload) {
                      	if (notification !== "*") {
                      		notificationCallback(notification, payload);
                      // Public Methods
                      this.setNotificationCallback = function(callback) {
                      	notificationCallback = callback;
                      this.sendNotification = function(notification, payload) {
                      	if (typeof payload === "undefined") {
                      		payload = {};
                      	self.socket.emit(notification, payload);
                        shawnlane
                        @hawkeye Thank you for posting. This corrected my problem! I have so much to learn. Off to my next issue with getting the Google Photos module to work.
                          sdetweil @shawnlane
                          @shawnlane said in Remote control:
                          there was a bug in 2.11 for that file… fixes only come every 3 months… so the workaround it to put the old file back
                          • H Offline
                            hawkeye
                            its solved
                            • V Offline
                              videogame95
                              Hi l see your having a similar problem as when add the script into my config file it stops l also remove the //
                              To position it a the left bottom but it still didn’t work
                              I set the IP. 0.0.0.0 and closed brackets []
                              Set up any one on my IP address
                              But it still no working.
                              I know we should get a IP address on bottom of the mirror to type into our phone which open up app controller.
                              If any can help us both please reply.
                                sdetweil @videogame95
                                @videogame95 show the config for his module and aove/below it
                                a module is
                                   module:"name",
                                   position:"something",
                                      module specifc values
                                note that whre u add this MAY reqire a trailing comma on the last line of the prior module, meaning, more coming
                                keep the braces and brackets aligned up and down,
