    602 Posts 67 Posters 2.4m Views 68 Watching
      costascontis @BKeyport
      @BKeyport i dont have any problem with vlc as local player ,my issue is with remote player,ffmpeg.I am trying to see the feed from windows pc with chrome.Every other module is working fine ,the live feed is starting but i only see black,no camera image.
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @costascontis
        @costascontis oh, sorry, I misunderstood.
        • Z
          zzricezz
          I’m assuming if i just have 1 stream, it will most likely cause a burn-in issue? any good idea? like transition between a black backgroup ever minute or so for couple of seconds?
          Thanks,
          • BKeyportB
            BKeyport Module Developer @zzricezz
            @zzricezz burn in is mostly a non-issue in modern screens, however, I severely doubt a stream isn’t gonna do anything like that, unless you’re streaming a closet… there’s enough movement on most streams that even things that are locked into place move around (due to encoding bugs, etc)
              dwburger
              I’ve got this module working with my Wyze camera, but the connection drops and the image freezes after a few minutes. Is there a way to automatically reconnect to the camera from within the module? I can do it by stopping and starting MM2 using PM2, but I’d rather not have to do that every few minutes. Thanks for any help or guidance!
              BKeyportB twosquirrelsT 2 Replies Last reply
              • evroomE
                evroom
                You can try adding this line to the config:
                omxRestart: 1,
                Automatically restart the OMX Stream every X hours.
                Default: 24 (hours).
                Btw. Assuming you use omxplayer. Do not have experience with other players.
                localPlayer: 'omxplayer',
                But getting rid of the root cause of connection dropping and image freezing after a few minutes seems better time invested.
                MagicMirror version: 2.37.0
                evroomE D 2 Replies Last reply
                • evroomE
                  evroom @evroom
                  @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  I use omxplayer ‘standalone’, not within MM, but under control of pm2.
                  When I restart my camera, the omxplayer is connecting to the stream automatically.
                  No restart of the omxplayer stream needed.
                  Just FYI.
                    dwburger @evroom
                    @evroom Thanks! I haven’t been able to get OMXplayer to work, only VLC. However, if I can’t get the auto-restart to work with VLC, I’ll see if I can’t get OMXplayer to work.
                    • BKeyportB
                      BKeyport Module Developer @dwburger
                      @dwburger I was having a ton of trouble streaming anything on my Pi 4. if you’re on a Pi 4, make sure to install the May 2020 update. Streaming is rock solid now.
                      https://www.raspberrypi.org/documentation/raspbian/updating.md
                      I will note, I’m also using OMX Player independently from MM - the last releases of RTSPStream broke everything, and I couldn’t bother to get things working again. I wrote a little module I kept private because it’s not configurable to cut the desired space out of the MM workspace.
                      S D BKeyportB 3 Replies Last reply
                        sdetweil @BKeyport
                        @BKeyport that link is for PI OS… does it apply to raspian buster?
                          dwburger @BKeyport
                          @BKeyport Yes, I’m using an RPi4. Thanks for the link for updating!
                          • BKeyportB
                            @sdetweil If you read it, They’re renaming the OS.
                              sdetweil @BKeyport
                              @BKeyport yes, I knew they were renaming… but also that s mostly applied tot he 64 bit version.
                              whatever, commands in progress on my 4
                              • BKeyportB
                                @sdetweil I read it as “Going forward” - meaning all releases after the date of announcement. But, as it’s still debian based under the hood, the commands would be the same (Or apt-get instead)
                                • BKeyportB
                                  You know, it figures… I say it’s stable, and it’s back to pre-PI 4 tricks. It’ll run for about two days before crashing, but that’s a lot better than pre-may2020 Buster - which was 5 minutes at the most.
                                    sdetweil @BKeyport
                                    @BKeyport wow… my pi4 has been booted solid for weeks… (last manual update boot)
                                      dwburger
                                      Updating didn’t solve the problem. Just wondering…I’ve seen recent references to using OMXplayer independent of MM2. Does this mean that the OMXplayer window is on top of the MM2 screen or somehow incorporated into it. Could someone give me a little push into understanding this?
                                      • evroomE
                                        evroom
                                        @dwburger said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                        When using the module or not, omxplayer always will be an overlay on top of your MM display.
                                        Test if it works at all (example for an Axis IP camera):
                                        $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 625 590 957" rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                                        With log:
                                        $ omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 640 360" rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                                        The positioning of the stream can be a bit of a pain.
                                        Size of video stream:
                                        (x2 - x1) x (y2 - y1) = 640 x 360
                                        To use it under control of pm2 (iso of vi you also can use nano):
                                        $ cd /home/pi
                                        $ vi axis.sh
                                        #!/bin/bash
                                        echo "Starting Axis stream ..."
                                        # No rotation
                                        $ pm2 start axis.sh
                                        $ pm2 save
                                        To see it run:
                                        $pm2 status
                                        To restart it:
                                        $ pm2 restart axis
                                        To stop it:
                                        $ pm2 stop axis
                                        To remove it from pm2:
                                        $ pm2 delete axis
                                        D 1 Reply Last reply
                                          dwburger @evroom
                                          omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win “0 0 640 360” rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                                          I’m just getting the “have a nice day” error. What would the most basic omxplayer command be? I just want to see the Wyze rtsp stream anywhere on the RPi 4 screen. I’ve tried: omxplayer rtsp://:@IP address and I get the “have a nice day” error.
                                          • evroomE
                                            evroom
                                            Can you see if the omxplayer.log gives a clue?
                                            And what would your VLC url look like?
                                            It can be that your cam or codec is not supported.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 26 / 31
