    602 Posts 67 Posters 2.4m Views 68 Watching
    • evroomE
      evroom
      You can try adding this line to the config:
      omxRestart: 1,
      Automatically restart the OMX Stream every X hours.
      Default: 24 (hours).
      Btw. Assuming you use omxplayer. Do not have experience with other players.
      localPlayer: 'omxplayer',
      But getting rid of the root cause of connection dropping and image freezing after a few minutes seems better time invested.
      MagicMirror version: 2.37.0
      evroomE D 2 Replies Last reply
      • evroomE
        evroom @evroom
        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        I use omxplayer ‘standalone’, not within MM, but under control of pm2.
        When I restart my camera, the omxplayer is connecting to the stream automatically.
        No restart of the omxplayer stream needed.
        Just FYI.
          dwburger @evroom
          @evroom Thanks! I haven’t been able to get OMXplayer to work, only VLC. However, if I can’t get the auto-restart to work with VLC, I’ll see if I can’t get OMXplayer to work.
          • BKeyportB
            BKeyport Module Developer @dwburger
            @dwburger I was having a ton of trouble streaming anything on my Pi 4. if you’re on a Pi 4, make sure to install the May 2020 update. Streaming is rock solid now.
            https://www.raspberrypi.org/documentation/raspbian/updating.md
            I will note, I’m also using OMX Player independently from MM - the last releases of RTSPStream broke everything, and I couldn’t bother to get things working again. I wrote a little module I kept private because it’s not configurable to cut the desired space out of the MM workspace.
            S D BKeyportB 3 Replies Last reply
              sdetweil @BKeyport
              @BKeyport that link is for PI OS… does it apply to raspian buster?
              BKeyportB 1 Reply Last reply
                dwburger @BKeyport
                @BKeyport Yes, I’m using an RPi4. Thanks for the link for updating!
                • BKeyportB
                  @sdetweil If you read it, They’re renaming the OS.
                    sdetweil @BKeyport
                    @BKeyport yes, I knew they were renaming… but also that s mostly applied tot he 64 bit version.
                    whatever, commands in progress on my 4
                    • BKeyportB
                      @sdetweil I read it as “Going forward” - meaning all releases after the date of announcement. But, as it’s still debian based under the hood, the commands would be the same (Or apt-get instead)
                      • BKeyportB
                        You know, it figures… I say it’s stable, and it’s back to pre-PI 4 tricks. It’ll run for about two days before crashing, but that’s a lot better than pre-may2020 Buster - which was 5 minutes at the most.
                          sdetweil @BKeyport
                          @BKeyport wow… my pi4 has been booted solid for weeks… (last manual update boot)
                            dwburger
                            Updating didn’t solve the problem. Just wondering…I’ve seen recent references to using OMXplayer independent of MM2. Does this mean that the OMXplayer window is on top of the MM2 screen or somehow incorporated into it. Could someone give me a little push into understanding this?
                            • evroomE
                              evroom
                              @dwburger said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              When using the module or not, omxplayer always will be an overlay on top of your MM display.
                              Test if it works at all (example for an Axis IP camera):
                              $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 625 590 957" rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                              With log:
                              $ omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 640 360" rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                              The positioning of the stream can be a bit of a pain.
                              Size of video stream:
                              (x2 - x1) x (y2 - y1) = 640 x 360
                              To use it under control of pm2 (iso of vi you also can use nano):
                              $ cd /home/pi
                              $ vi axis.sh
                              #!/bin/bash
                              echo "Starting Axis stream ..."
                              # No rotation
                              $ pm2 start axis.sh
                              $ pm2 save
                              To see it run:
                              $pm2 status
                              To restart it:
                              $ pm2 restart axis
                              To stop it:
                              $ pm2 stop axis
                              To remove it from pm2:
                              $ pm2 delete axis
                              D 1 Reply Last reply
                                dwburger @evroom
                                omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win “0 0 640 360” rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                                I’m just getting the “have a nice day” error. What would the most basic omxplayer command be? I just want to see the Wyze rtsp stream anywhere on the RPi 4 screen. I’ve tried: omxplayer rtsp://:@IP address and I get the “have a nice day” error.
                                • evroomE
                                  evroom
                                  Can you see if the omxplayer.log gives a clue?
                                  And what would your VLC url look like?
                                  It can be that your cam or codec is not supported.
                                  • BKeyportB
                                    @dwburger Try this:
                                    https://www.ispyconnect.com/man.aspx?n=Wyzecam
                                    get a URL from them, then use that URL directly in OMXPlayer…
                                    omxplayer [URL]
                                    No other options, YET.
                                    once you get that going, you can position and set FPS, etc.
                                      dwburger @evroom
                                      @evroom I ran the following command via SSH to a headless RPi 4. I stopped MM2 via PM2 so the RPi4 GUI desktop is all I see.
                                      omxplayer -g rtsp://admin:admin@192.168.1.20/live
                                      The omxplayer.log file looks like this:
                                      23:13:40 T:18446744072105597939 DEBUG: DllBcm: Using omx system library
                                      23:13:40 T:18446744072105599016 DEBUG: DllOMX: Using omx system library
                                      23:13:40 T:18446744072105599609 DEBUG: DllAvFormat: Using libavformat system library
                                      23:13:40 T:18446744072105600891 DEBUG: DBus connection succeeded
                                      23:13:40 T:18446744072105601616 DEBUG: Keyboard: DBus connection succeeded
                                      23:13:40 T:18446744072105601755 DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                      23:13:40 T:18446744072105601853 DEBUG: DllAvUtilBase: Using libavutil system library
                                      23:13:40 T:18446744072105601872 DEBUG: DllAvCodec: Using libavcodec system library
                                      23:13:40 T:18446744072105601888 DEBUG: DllAvFormat: Using libavformat system library
                                      23:13:40 T:18446744072105602188 DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:admin@192.168.1.20/live
                                      23:13:43 T:18446744072108706892 DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                                      23:13:43 T:18446744072108707062 ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:admin@192.168.1.20/live
                                      23:13:43 T:18446744072108717572 DEBUG: OMXThread::Run - Exited thread with id -1387290944
                                      23:13:43 T:18446744072108718100 DEBUG: OMXThread::StopThread - Thread stopped
                                        dwburger @dwburger
                                        I see I made an error with the rtsp URL. Here’s the correct one for my Wyze cam masking the username and password:
                                        rtsp://d____:b____@192.168.1.117/live
                                          dwburger @dwburger
                                          @dwburger It took several seconds, but entering the correct rtsp URL got my camera’s video stream onto the RPi4 screen (full-screen). I’ll follow it a while to see how stable it is.
                                            dwburger
                                            OK…I’ve got it displaying my Wyze rtsp live stream on the screen while MM2 is running. The live stream seems to start and stop so I’ll work on that. Also, I need to position it in the correct place (lower-right corner).
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 26 / 31
