    602 Posts 67 Posters 2.4m Views 68 Watching
      sdetweil @BKeyport
      @BKeyport that link is for PI OS… does it apply to raspian buster?
      BKeyportB 1 Reply Last reply
        dwburger @BKeyport
        @BKeyport Yes, I’m using an RPi4. Thanks for the link for updating!
        • BKeyportB
          @sdetweil If you read it, They’re renaming the OS.
            sdetweil @BKeyport
            @BKeyport yes, I knew they were renaming… but also that s mostly applied tot he 64 bit version.
            whatever, commands in progress on my 4
            • BKeyportB
              @sdetweil I read it as “Going forward” - meaning all releases after the date of announcement. But, as it’s still debian based under the hood, the commands would be the same (Or apt-get instead)
              • BKeyportB
                You know, it figures… I say it’s stable, and it’s back to pre-PI 4 tricks. It’ll run for about two days before crashing, but that’s a lot better than pre-may2020 Buster - which was 5 minutes at the most.
                  sdetweil @BKeyport
                  @BKeyport wow… my pi4 has been booted solid for weeks… (last manual update boot)
                    dwburger
                    Updating didn’t solve the problem. Just wondering…I’ve seen recent references to using OMXplayer independent of MM2. Does this mean that the OMXplayer window is on top of the MM2 screen or somehow incorporated into it. Could someone give me a little push into understanding this?
                    • evroomE
                      evroom
                      @dwburger said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      When using the module or not, omxplayer always will be an overlay on top of your MM display.
                      Test if it works at all (example for an Axis IP camera):
                      $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 625 590 957" rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                      With log:
                      $ omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 640 360" rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                      The positioning of the stream can be a bit of a pain.
                      Size of video stream:
                      (x2 - x1) x (y2 - y1) = 640 x 360
                      To use it under control of pm2 (iso of vi you also can use nano):
                      $ cd /home/pi
                      $ vi axis.sh
                      #!/bin/bash
                      echo "Starting Axis stream ..."
                      # No rotation
                      $ pm2 start axis.sh
                      $ pm2 save
                      To see it run:
                      $pm2 status
                      To restart it:
                      $ pm2 restart axis
                      To stop it:
                      $ pm2 stop axis
                      To remove it from pm2:
                      $ pm2 delete axis
                      MagicMirror version: 2.37.0
                      D 1 Reply Last reply
                        dwburger @evroom
                        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win “0 0 640 360” rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360
                        I’m just getting the “have a nice day” error. What would the most basic omxplayer command be? I just want to see the Wyze rtsp stream anywhere on the RPi 4 screen. I’ve tried: omxplayer rtsp://:@IP address and I get the “have a nice day” error.
                        • evroomE
                          evroom
                          Can you see if the omxplayer.log gives a clue?
                          And what would your VLC url look like?
                          It can be that your cam or codec is not supported.
                          • BKeyportB
                            @dwburger Try this:
                            https://www.ispyconnect.com/man.aspx?n=Wyzecam
                            get a URL from them, then use that URL directly in OMXPlayer…
                            omxplayer [URL]
                            No other options, YET.
                            once you get that going, you can position and set FPS, etc.
                              dwburger @evroom
                              @evroom I ran the following command via SSH to a headless RPi 4. I stopped MM2 via PM2 so the RPi4 GUI desktop is all I see.
                              omxplayer -g rtsp://admin:admin@192.168.1.20/live
                              The omxplayer.log file looks like this:
                              23:13:40 T:18446744072105597939 DEBUG: DllBcm: Using omx system library
                              23:13:40 T:18446744072105599016 DEBUG: DllOMX: Using omx system library
                              23:13:40 T:18446744072105599609 DEBUG: DllAvFormat: Using libavformat system library
                              23:13:40 T:18446744072105600891 DEBUG: DBus connection succeeded
                              23:13:40 T:18446744072105601616 DEBUG: Keyboard: DBus connection succeeded
                              23:13:40 T:18446744072105601755 DEBUG: OMXThread::Create - Thread with id -1387290944 started
                              23:13:40 T:18446744072105601853 DEBUG: DllAvUtilBase: Using libavutil system library
                              23:13:40 T:18446744072105601872 DEBUG: DllAvCodec: Using libavcodec system library
                              23:13:40 T:18446744072105601888 DEBUG: DllAvFormat: Using libavformat system library
                              23:13:40 T:18446744072105602188 DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:admin@192.168.1.20/live
                              23:13:43 T:18446744072108706892 DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                              23:13:43 T:18446744072108707062 ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:admin@192.168.1.20/live
                              23:13:43 T:18446744072108717572 DEBUG: OMXThread::Run - Exited thread with id -1387290944
                              23:13:43 T:18446744072108718100 DEBUG: OMXThread::StopThread - Thread stopped
                                dwburger @dwburger
                                I see I made an error with the rtsp URL. Here’s the correct one for my Wyze cam masking the username and password:
                                rtsp://d____:b____@192.168.1.117/live
                                  dwburger @dwburger
                                  @dwburger It took several seconds, but entering the correct rtsp URL got my camera’s video stream onto the RPi4 screen (full-screen). I’ll follow it a while to see how stable it is.
                                    dwburger
                                    OK…I’ve got it displaying my Wyze rtsp live stream on the screen while MM2 is running. The live stream seems to start and stop so I’ll work on that. Also, I need to position it in the correct place (lower-right corner).
                                    • BKeyportB
                                      BKeyport Module Developer @dwburger
                                      @dwburger Looks like you’re on the way. Good luck to you!
                                        dwburger @BKeyport
                                        @BKeyport Yes, making good progress thanks to those of you who’ve helped. I’m having a difficult time with placing the window. I can get it in the upper-left of the screen using --win “0 0 600 300”, but I can’t seem to manipulate those coordinates to get the window to the lower-right. Can you point me to information that will help me understand this?
                                        • BKeyportB
                                          @dwburger
                                          Here’s how to do that.
                                          The coordinates are Top Left Bottom Right, assuming the monitor is in NORMAL mode (no rotation)
                                          So, if your monitor is 1920×1080. say, that’s your bottom and right coordinate to get it into the bottom right corner.
                                          top would be 1920 - WindowHeight
                                          left would be 1080 - WindowWidth
                                          using your example window size, and my example monitor size it would be, “1320 780 1920 1080”
                                          If you’d like to make the window bigger or smaller, you can refer to https://bneijt.nl/pr/resolution-scale-calculator/ to compute different sizes that won’t distort the image.
                                          Note: if you rotate your monitor, the normal/no rotation resolution is used for the calculations. so, in addition to adding “rotate” to the string, you’ll need to recalculate the sides to match.
                                            dwburger @BKeyport
                                            @BKeyport Yep, that did it…thanks! Your explanation was so clear and concise (and simple). I don’t understand why I didn’t find a similar explanation on the web somewhere. I appreciate the help very much!
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 26 / 31
