    MMM-GoogleMapsTraffic : black screen by copying the code in config.js
    16 Posts 4 Posters 3.9k Views 4 Watching
      RIKKO14
      it’s the same problem… :
      						title: "Le Monde, Culture",
      						url: "https://www.lemonde.fr/culture/rss_full.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true,
                  module: 'MMM-GoogleMapsTraffic',
                  position: 'top_left',
                      key: 'AIzaSyBQnp-WYA1IdK9sZr0lfvrtUcQ5Qu02sNw',
                      lat: 49.182863,
                      lng: -0.370679,
                      height: '300px',
                      width: '300px'
                      styledMapType: "transparent",
                      disableDefaultUI: true,
                      backgroundColor: 'hsla(0, 0%, 0%, 0)',
                      markers: [
                              lat: 49.182863,
                              lng: -0.370679,
                              fillColor: '#9966ff'
        MadScientist
        @RIKKO14 said in MMM-GoogleMapsTraffic : black screen by copying the code in config.js:
        width: ‘300px’
        I think you missed a comma at the end of that line.
          RIKKO14
          modified, but still the same problem …
                          lat: 49.182863,
                          lng: -0.370679,
                          height: '300px',
                          width: '300px',
                          markers: [
                                  lat: 49.182863,
                                  lng: -0.370679,
          ![0_1593336531621_2020-06-28-112809_1920x1080_scrot.png](Uploading 100%)
            sdetweil @RIKKO14
            @RIKKO14 https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1593192855121
            take out the addtional stuff u added and read the above post and try again
              @RIKKO14 also, the GoogleMapsTraffic module has a bug, which I fixed, but th e author has not taken,
              you can use my repo instead of the original
              https://github.com/sdetweil/MMM-GoogleMapsTraffic
                RIKKO14
                II have read the post : https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1593192855121
                I don’t anderstand what you say : "take out the addtional stuff u added ", I added nothing…
                And I d’ont anderstand what is your “repo instead”,
                and this my config.js, I had already installed modules where I had encountered the problem of} and not}, but there everything seems good, I do not see the error … :
                  RIKKO14
                    sdetweil @RIKKO14
                    @RIKKO14 the last thing you said was
                    you added a new module definition (that is additional stuff)
                    repo, the site on github is a repository, repo for short
                    the original u are trying to use is
                    https://github.com/vicmora/MMM-GoogleMapsTraffic
                    mine is
                    note that the userids are different.
                    so, instead of git cloning vic’s repo, do that with mine (instead)
                      RIKKO14
                        sdetweil @RIKKO14
                        @RIKKO14 thats why I suggested the link on modules for beginners, you have too many braces {} and brackets []
                        just cutting and pasting what the author gives you is trouble if you don’t understand what ytou are supposed to do
                        module entries no not HAVE to have a trailing , (comma) UNLESS there are more entries after
                        and showing the module in that whole list is bad, cause people just copy… and boom you have TWO config entries and two module lists… not good…
                          RIKKO14
                          ça y’est le module s’affiche enfin mais nouveau bug… la carte s’affiche et aussitot après un écran “problem” s’affiche… Pfff
                          this the config.js modified :
                          module: ‘MMM-GoogleMapsTraffic’,
                          position: ‘top_right’,
                          key: ‘AIzaSyBQnp-WYA1IdK9sZr0lfvrtUcQ5Qu02sNw’,
                          lat: 49.182863,
                          lng: -0.370679,
                          height: ‘300px’,
                          width: ‘300px’,
                          styledMapType: “transparent”,
                          backgroundColor: ‘hsla(0, 0%, 0%, 0)’,
                          markers: [
                          lat: 49.182863,
                          lng: -0.370679,
                          fillColor: ‘#9966ff’
                            RIKKO14
                                        position: 'top_right',
                                            lat: 49.182863,
                                            lng: -0.370679,
                                            height: '300px',
                                            width: '300px',
                                            markers: [
                                                    lat: 49.182863,
                                                    lng: -0.370679,
                              RIKKO14
                                RIKKO14
                                that’s it the module finally appears but new bug … the map appears and immediately after a “problem” screen appears … Pfff
