    602 Posts 67 Posters 2.2m Views 68 Watching
      dwburger
      OK…I’ve got it displaying my Wyze rtsp live stream on the screen while MM2 is running. The live stream seems to start and stop so I’ll work on that. Also, I need to position it in the correct place (lower-right corner).
      • BKeyportB Offline
        BKeyport Module Developer @dwburger
        @dwburger Looks like you’re on the way. Good luck to you!
          dwburger @BKeyport
          @BKeyport Yes, making good progress thanks to those of you who’ve helped. I’m having a difficult time with placing the window. I can get it in the upper-left of the screen using --win “0 0 600 300”, but I can’t seem to manipulate those coordinates to get the window to the lower-right. Can you point me to information that will help me understand this?
          • BKeyportB Offline
            @dwburger
            Here’s how to do that.
            The coordinates are Top Left Bottom Right, assuming the monitor is in NORMAL mode (no rotation)
            So, if your monitor is 1920×1080. say, that’s your bottom and right coordinate to get it into the bottom right corner.
            top would be 1920 - WindowHeight
            left would be 1080 - WindowWidth
            using your example window size, and my example monitor size it would be, “1320 780 1920 1080”
            If you’d like to make the window bigger or smaller, you can refer to https://bneijt.nl/pr/resolution-scale-calculator/ to compute different sizes that won’t distort the image.
            Note: if you rotate your monitor, the normal/no rotation resolution is used for the calculations. so, in addition to adding “rotate” to the string, you’ll need to recalculate the sides to match.
              dwburger @BKeyport
              @BKeyport Yep, that did it…thanks! Your explanation was so clear and concise (and simple). I don’t understand why I didn’t find a similar explanation on the web somewhere. I appreciate the help very much!
                dwburger
                Please pardon the rant…I got started down this path today since I was having stability issues with vlc inside the MMM-RTSPStream module. Now that I’ve gotten my Wyze RTSP stream working outside MM2 using omxplayer (with lots of expert help), I’m still having stability issues. The stream lasts for a few seconds to a few minutes and then vanishes. When I look at the RPi4 console, omxplayer has stopped giving me the “have a nice day” message. That’s cute and all, but It’s starting to annoy me. One advantage to the use of omxplayer is that I can easily automate restarting it. But, that doesn’t really address what seems to be a core issue with my Wyze camera or wifi ecosystem or ??? I don’t know enough about IP cams or streaming video or video players to know whether this is technically difficult to do or not, but it sure seems like all this should work way better than it does. Just sayin’.
                BKeyportB twosquirrelsT 2 Replies Last reply Reply Quote 0
                • BKeyportB Offline
                  @dwburger You’re right of course. It should be a ton easier. But, we’re at the mercy of people who know how to program this ((#%#% to understand what the average user wants, and that’s usually barking up the tree at a cat that’s long gone…
                    dwburger
                    Maybe I’m just a glutton for punishment, but I’d really like to get this to work. I went online looking for other RTSP players and found ContaCam (https://www.contaware.com/contacam.html). It’s Windows donateware and getting my Wyze RTSP stream up and viewing was simple. It’s been going for several hours. During the time the stream has been running on ContaCam I also accessed the stream with omxplayer on my Rpi4 and VLC on my Windows 10 machine. Both the omxplayer and VLC player stopped displaying live video after only a short time; the live stream on ContaCam is still going strong. Just wondering…are there settings in the ContaCam set-up that might be helpful in stabilizing the livestream video on the omxplayer? It seems apparent that the Wyze camera is working and my wifi network is OK, the weak link seems to be the player. Any suggestions on how to proceed down this path will be much appreciated.
                      dwburger
                      I thought I would put a close to my efforts here with the following:
                      I believe I’ve found a solution. I decided to use ffmpeg from the RPi4 command line to save an image from the RTSP stream every 5 minutes. Every 5 minutes the new image overwrites the previous one, thus using the same filename. Then, I’m using mykle1’s MMM-EyeCandy module to display that sole image that’s housed in the /pix folder for that module. So, after several hours, ffmpeg continues to run (although it throws lots of “missed packet” errors), but it doesn’t abort. I’ll put ffmpeg under pm2 control next. Now, using MMM-EyeCandy, I’m getting a new image from my Wyze camera in the lower-right corner of my MM2 every 5 minutes. This is all I needed to stay reasonably up-to-date with what’s happening in front of that camera.
                      • Cr4z33C Offline
                        Cr4z33
                        @shbatm I’ve moved MagicMIrror to a brand new RPI 4.
                        Can you see any reason why 1080i/1080p streams are not showing into your module?
                        I can hear them, but not see them. :confused_face:
                        This happens both if using omxplayer and VLC.
                        Standard resolution streams show up normally.
                        @evroom what about your experience?
                        Did you get a RPI 4 too?
                        • BKeyportB Offline
                          That’s sounding like you’re plugged into the wrong HDMI port - make sure you’re using the port closest to the power supply.
                          • Cr4z33C Offline
                            Cr4z33 @BKeyport
                            @BKeyport it is already connected there. :D
                            Fact is that 1080p videos, streams, etc. work perfectly if running in VLC as standalone.
                            The same does NOT happen when using VLC (or OMXplayer) in this module.
                            • BKeyportB Offline
                              OK, that’s weird (but expected)
                              I never could get VLC to work. I can’t recall if OMX was working or not in the last public release, the developer branch was opposite.
                              I use OMX independently now, using @evroom 's method, however, that requires the may 2020 update to fix a number of bugs in my case.
                              • Cr4z33C Offline
                                Cr4z33 @BKeyport
                                @BKeyport could you please share the link here?
                                I would like to give it a try because right now OMXplayer embedded streams are playing in a wrong resize (almost full screen lol). :D
                                • BKeyportB Offline
                                  BKeyport Module Developer @Cr4z33
                                  @Cr4z33 It’s sprinkled throughout this post. This will take you to where I talk about it, Evroom’s convo is earlier, but there’s a link in my post about it. Feel free to use this post for help on this.
                                  https://forum.magicmirror.builders/post/69779
                                  • twosquirrelsT Offline
                                    twosquirrels @dwburger
                                      • Cr4z33C Offline
                                        Cr4z33
                                        I am trying to have this module running succesfully in Ubuntu Desktop, but it doesn’t work right now.
                                        I ran the bash setup command and choosed the master build (dev build gave the same errors).
                                        [2020-07-14 16:46:29.279] [LOG]    Starting MagicMirror: v2.12.0
                                        [2020-07-14 16:46:29.282] [LOG]    Loading config ...
                                        [2020-07-14 16:46:29.284] [LOG]    Loading module helpers ...
                                        [2020-07-14 16:46:29.286] [LOG]    Initializing new module helper ...
                                        [2020-07-14 16:46:29.286] [LOG]    Module helper loaded: MMM-WatchDog
                                        [2020-07-14 16:46:29.335] [LOG]    Initializing new module helper ...
                                        [2020-07-14 16:46:29.335] [LOG]    Module helper loaded: MMM-Remote-Control
                                        [2020-07-14 16:46:29.339] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-rtsp-stream-es6'
                                        Require stack:
                                        - /home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js
                                        - /home/cr4z33/MagicMirror/js/app.js
                                        - /home/cr4z33/MagicMirror/js/electron.js
                                        - /home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                        [2020-07-14 16:46:29.340] [LOG]    Loading module helpers ...
                                        [2020-07-14 16:46:29.340] [LOG]    Initializing new module helper ...
                                        [2020-07-14 16:46:29.340] [LOG]    Module helper loaded: MMM-WatchDog
                                        [2020-07-14 16:46:29.341] [LOG]    Module helper loaded: MMM-Remote-Control
                                        [2020-07-14 16:46:29.342] [ERROR]  App threw an error during load
                                        [2020-07-14 16:46:29.342] [ERROR]  Error: Cannot find module 'node-rtsp-stream-es6'
                                        Require stack:
                                            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                            at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                            at Function.Module._resolveFilename (/home/cr4z33/MagicMirror/node_modules/module-alias/index.js:49:29)
                                            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                            at Module.require (internal/modules/cjs/loader.js:685:19)
                                            at require (internal/modules/cjs/helpers.js:16:16)
                                            at Object.<anonymous> (/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js:10:14)
                                            at Module._compile (internal/modules/cjs/loader.js:786:30)
                                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                            at Module.load (internal/modules/cjs/loader.js:645:32)
                                        [2020-07-14 16:46:29.343] [ERROR]  Whoops! There was an uncaught exception...
                                        [2020-07-14 16:46:29.343] [ERROR]  Error: Cannot find module 'node-rtsp-stream-es6'
                                        Require stack:
                                            at Module.load (internal/modules/cjs/loader.js:645:32) {
                                          code: 'MODULE_NOT_FOUND',
                                          requireStack: [
                                            '/home/cr4z33/MagicMirror/modules/MMM-RTSPStream/node_helper.js',
                                            '/home/cr4z33/MagicMirror/js/app.js',
                                            '/home/cr4z33/MagicMirror/js/electron.js',
                                            '/home/cr4z33/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                            undefined
                                        [2020-07-14 16:46:29.345] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        [2020-07-14 16:46:29.346] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        [2020-07-14 16:46:29.414] [LOG]    Launching application.
                                          sdetweil @Cr4z33
                                          @Cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          Error: Cannot find module ‘node-rtsp-stream-es6’
                                          did u do npm install in the “/home/cr4z33/MagicMirror/modules/MMM-RTSPStream” folder?
                                          • Cr4z33C Offline
                                            Cr4z33 @sdetweil
                                            @sdetweil yep.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 27 / 31
