No numbers in analog watch face
see documentation: https://docs.magicmirror.builders/modules/clock.html#configuration-options
there are no fonts, are svg images, scalable vector graphics.analogFace Specific to the analog clock. Specifies which clock face to use. Possible values: simple for a simple border, none for no face or border, or face-### (where ### is currently a value between 001 and 012, inclusive) Default value: simple
these are faces
I know i set face-003 and didn’t change anything. No watchface is working since the update.
OK then set in config face to none and put in clock_styles.css
.clockCircle { margin: 0 auto; position: relative; border-radius: 50%; background-size: 100%; background: transparent url("faces/face-003.svg") center no-repeat; }
or in custom.css
.clockCircle { background: transparent url("../modules/default/clock/faces/face-003.svg") center no-repeat; }
Tried both, the watch remains without numbers :-(
@JoeFranz I have the same issue. Also trying ‘face-003’. Have not tried another one yet.
@lavolp3
Changing the face (tried face-004 and face-005) does not solve the issue.
Links to svgs seem correct… -
Same happens to me, after 2.12.0 MM update, only the clock hands are shown.
I’ve got it too. The faces are all missing. No big for me, I’ve gone back to digital only on that one to make room for another module.
All new 2.12.0 verison svg files in clock faces folder are invalid svg format, use the old ones.
I think replacing unsecure links with https ones make format invalid. -
Thats it, it works, thank you :thumbs_up:
