    MMM-SoccerLiveScore
    187 Posts 37 Posters 334.7k Views 35 Watching
      Joeysface
      I have been messing around with this module and it is working really well. I love the way its laid out but I do have a few questions.
      • Is there anyway to not display the table for certain leagues? Someone asked already but the Champions League table only seems to be showing Group A.
      • Is there a way to change the display date format? I would like to change the format to something like MM-DD instead of DD.MM.
      • Is there maybe a way to highlight certain teams on the table and schedule? For example, If I follow a few PL teams and want their games to pop out more so that the text is bolded or highlighted for the team name.
      Thanks again for any help
      • Alex2020A
        Alex2020
        Ma per creare un “tavolo” per la classifica di serie “A” Italiana cè un modo ?Grazie.
        • lavolp3L
          lavolp3 Module Developer
          Hi @LukeCodewalker I’d like to use and probably contribute to the module a bit.
          Do you think it’s possible to show the goals and scorers of a current running game?
          Is there an endpoint in the api for that?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • G
            Galaras7
            Hi guys please I need your help …
            ID Number Greece soccer please.
            For My magicmirror livescore modul…
              master117 @Galaras7
              @Galaras7
              if you are using my module, you can check ids here:
              http://api.football-data.org/v2/competitions/
              Greece ID: 2093
              Greece sadly is not covered in the APIs free tier. So you would have to pay for it.
              https://www.football-data.org/coverage
              • F
                frankturban
                I am viewing the results of the 2nd Bundesliga. Unfortunately I don’t get any icons here. Is this a bug? It works for other leagues … Thank you very much …
                • StoffbeuteluweS
                  Stoffbeuteluwe Project Sponsor @frankturban
                  @frankturban same problem after MM new start or refresh browser?
                  • F
                    frankturban @Stoffbeuteluwe
                    @Stoffbeuteluwe yes - but DFB-Pokal shows icons
                      dawookie1979
                      i cant find the file to download
                      • Feedy88F
                        Feedy88
                        Looks like the Original Creator had removed the repo or his github account. Found this one, looks like it is still working: https://github.com/massi1990/MMM-SoccerLiveScore
                          dawookie1979 @Feedy88
                          @Feedy88 hello, i have the files and npm installed them into the module directory, but the module isnt showing up? i have it in the config file too :)
                          • Feedy88F
                            Feedy88
                            @dawookie1979 mh, just tried again and it works for me (takes some time to load though, maybe limit it to one league for now). Nonetheless, I removed it again and moved on with MMM-soccer as this module has the same features and more and is still being maintained by the original creator.
                            Nonetheless, if you want tot get MMM-SoccerLiveScore running, can you post your config? I just copied the sample and it works fine.
                              dawookie1979
                              hello, i will remove soccerlivescore, and try MMM-soccer. Thank you for your help
                                dave_ @Feedy88
                                @Feedy88 hey i was wondering if u could help me setup MMM-soccer I’m having a really hard time figuring it out plzzz
                                Feedy88F 1 Reply Last reply Reply Quote 0
                                • Feedy88F
                                  Feedy88 @dave_
                                  @dave_ Hey there,
                                  would be happy to help. What is your issue currently? Also would help to post a snippet of the config you are using.+
                                  • 0m4r0
                                    0m4r Module Developer
                                    I have forked the repository and fixed a few bugs as I noticed it is not maintained for 4 years. I have now reduced the numbers of API calls needed to fetch the team logos (that are now directly obtained by the HTML code) and reduced the number of API calls to fetch the table and the scores.
                                    The table APIs does not include a “refresh” time (as they maybe did return times ago) and this causes an infinite number of call to it.
                                    The forked repo is here: https://github.com/0m4r/MMM-SoccerLiveScore
                                    I have not made a PR as I d believe the original one is abandoned.
                                    E 1 Reply Last reply Reply Quote 1
                                    • E
                                      Egnos @0m4r
                                      @0m4r thank you for solving the problems of this module.
                                      I have only one problem: I don’t see the Juventus football team logo (it’s my favorite team … what luck!😔)
                                      As you can see in the following photo:
                                      alt text
                                      How can i solve?
                                      Many thanks.
                                      0m4r0 1 Reply Last reply Reply Quote 0
                                      • 0m4r0
                                        Juventus logo is black with a transparent background, so it is black on black and you will not be able to see it! :) I spent some time thinking it did not work… but then I realized the black on black problem :)
                                        • E
                                          Egnos @0m4r
                                          @0m4r I’m not sure both a problem of color, otherwise I would still see a logo of the logo or in part. As you can see in the picture in detail the pixels do not show any change …
                                          alt text
                                          • 0m4r0
                                            yes, I guess it is correct, black is rendered on screen by non turning on the pixel of the screen, why should they if they are supposed to be all black?
                                            this is the link t the image for the logo of Juventus:
                                            https://www.toralarm.com/api/proxy/images/ta/images/teams/30000991/64
                                            this is how it would look on a non-black background.
                                            • 10
                                            • 4 / 10
