    MMM-SoccerLiveScore
    187 Posts 37 Posters 328.3k Views 35 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      Hi @LukeCodewalker I’d like to use and probably contribute to the module a bit.
      Do you think it’s possible to show the goals and scorers of a current running game?
      Is there an endpoint in the api for that?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • G Offline
        Galaras7
        Hi guys please I need your help …
        ID Number Greece soccer please.
        For My magicmirror livescore modul…
          master117 @Galaras7
          @Galaras7
          if you are using my module, you can check ids here:
          http://api.football-data.org/v2/competitions/
          Greece ID: 2093
          Greece sadly is not covered in the APIs free tier. So you would have to pay for it.
          https://www.football-data.org/coverage
          • F Offline
            frankturban
            I am viewing the results of the 2nd Bundesliga. Unfortunately I don’t get any icons here. Is this a bug? It works for other leagues … Thank you very much …
            • StoffbeuteluweS Offline
              Stoffbeuteluwe Project Sponsor @frankturban
              @frankturban same problem after MM new start or refresh browser?
              • F Offline
                frankturban @Stoffbeuteluwe
                @Stoffbeuteluwe yes - but DFB-Pokal shows icons
                  dawookie1979
                  i cant find the file to download
                  • Feedy88F Offline
                    Feedy88
                    Looks like the Original Creator had removed the repo or his github account. Found this one, looks like it is still working: https://github.com/massi1990/MMM-SoccerLiveScore
                      dawookie1979 @Feedy88
                      @Feedy88 hello, i have the files and npm installed them into the module directory, but the module isnt showing up? i have it in the config file too :)
                      • Feedy88F Offline
                        Feedy88
                        @dawookie1979 mh, just tried again and it works for me (takes some time to load though, maybe limit it to one league for now). Nonetheless, I removed it again and moved on with MMM-soccer as this module has the same features and more and is still being maintained by the original creator.
                        Nonetheless, if you want tot get MMM-SoccerLiveScore running, can you post your config? I just copied the sample and it works fine.
                          dawookie1979
                          hello, i will remove soccerlivescore, and try MMM-soccer. Thank you for your help
                            dave_ @Feedy88
                            @Feedy88 hey i was wondering if u could help me setup MMM-soccer I’m having a really hard time figuring it out plzzz
                            Feedy88F 1 Reply Last reply Reply Quote 0
                            • Feedy88F Offline
                              Feedy88 @dave_
                              @dave_ Hey there,
                              would be happy to help. What is your issue currently? Also would help to post a snippet of the config you are using.+
                              • 0m4r0 Offline
                                0m4r Module Developer
                                I have forked the repository and fixed a few bugs as I noticed it is not maintained for 4 years. I have now reduced the numbers of API calls needed to fetch the team logos (that are now directly obtained by the HTML code) and reduced the number of API calls to fetch the table and the scores.
                                The table APIs does not include a “refresh” time (as they maybe did return times ago) and this causes an infinite number of call to it.
                                The forked repo is here: https://github.com/0m4r/MMM-SoccerLiveScore
                                I have not made a PR as I d believe the original one is abandoned.
                                E 1 Reply Last reply Reply Quote 1
                                • E Offline
                                  Egnos @0m4r
                                  @0m4r thank you for solving the problems of this module.
                                  I have only one problem: I don’t see the Juventus football team logo (it’s my favorite team … what luck!😔)
                                  As you can see in the following photo:
                                  alt text
                                  How can i solve?
                                  Many thanks.
                                  0m4r0 1 Reply Last reply Reply Quote 0
                                  • 0m4r0 Offline
                                    Juventus logo is black with a transparent background, so it is black on black and you will not be able to see it! :) I spent some time thinking it did not work… but then I realized the black on black problem :)
                                    • E Offline
                                      Egnos @0m4r
                                      @0m4r I’m not sure both a problem of color, otherwise I would still see a logo of the logo or in part. As you can see in the picture in detail the pixels do not show any change …
                                      alt text
                                      • 0m4r0 Offline
                                        yes, I guess it is correct, black is rendered on screen by non turning on the pixel of the screen, why should they if they are supposed to be all black?
                                        this is the link t the image for the logo of Juventus:
                                        https://www.toralarm.com/api/proxy/images/ta/images/teams/30000991/64
                                        this is how it would look on a non-black background.
                                        • Feedy88F Offline
                                          Feedy88
                                          @0m4r much appreciated.
                                          I would like to make a feature request if I may.
                                          • Give the option to put the focus on a team any only show results from this team
                                          Cheers,
                                          Feedy
                                          • 0m4r0 Offline
                                            0m4r Module Developer @Feedy88
                                            @Feedy88 would you be so kind to add a feature request to the github repo: https://github.com/0m4r/MMM-SoccerLiveScore/issues? thanks!
                                            • 10
                                            • 4 / 10
