    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 288.8k Views 35 Watching
      ruudvddries @ianperrin
      @ianperrin Is it possible to shrink the radial display from the current 500px width to something smaller. Like 300px?
      The radial display for strava is awesome. With its default size it somewhat messes up my MagicMirror layout.
      I already tried some CSS and JS adaptions but it not yet helped to achieve what I wanted. Any help is welcome!
      Greetings,
      Ruud
      • thymonT
        thymon
        Hello
        Today I have an error message on display :
        502 - undefined
        Any idea for this ?
          ctatos
          Hey Ian, are you aware if the recent changes in API will affect the module? For non-paying Strava users, it seems like the API request goes through but no data is fetched…
          From Strava: “We realize these API changes could be especially challenging for some developers, so they’ll be non-breaking for 30 days, returning empty data during that time so they can make necessary adjustments. After June 18th, those endpoints will either omit the data or return an error message.”
          lavolp3L 1 Reply Last reply
          • lavolp3L
            lavolp3 Module Developer @ctatos
            @ctatos said in MMM-Strava:
            From Strava: “We realize these API changes could be especially challenging for some developers, so they’ll be non-breaking for > 30 days, returning empty data during that time so they can make necessary adjustments. After June 18th, those endpoints will
            That’s only valid for segment leaderboards which are not used in this module.
            This module only calls user statistics which will still work with the changes.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            C 1 Reply Last reply
              ctatos @lavolp3
              @lavolp3 Oh OK that’s good news. Do you know why the YTD stats stopped working from June 1st? or maybe it’s only on my side…
                daymo87
                Hi is there a way to display units in imperial for just the strava module & not the whole magic mirror?
                Damon
                • L
                  Lagmin
                  I can’t get this step:
                  Authenticate the module to allow access to the Strava API.
                  Browse to the Strava authentication page: http://localhost:8080/MMM-Strava/auth/ - the exact URL may vary depending on your configuration.
                  Simply it doesn’t connect to my local host which is 192.168.0.177 (I am replacing with it the “localhost” in page adress).
                  It is saying that page is not existing… Any ideas?
                  Arek
                  I 1 Reply Last reply
                  • I
                    ianperrin @Lagmin
                    @Lagmin where are you accessing the MagicMirror from?
                    If you are doing this from the Raspberry Pi, the url will probably start with http://localhost:8080
                    If you are doing this from another computer on your network, the url will start with the IP address, http://192.168.0.177:8080 - though you will need to set the ipWhitelist option in the configuration file first.
                    “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                    • L
                      Lagmin
                      I am trying to do it from Raspberry directly. Still no success :/
                        @Lagmin u must provide the port
                        • L
                          Lagmin @sdetweil
                          @sdetweil where can I find the port?
                            sdetweil @Lagmin
                            @Lagmin it’s the value of port: in config.js
                            B 1 Reply Last reply
                              bachoo786 @sdetweil
                                bachoo786
                                  bachoo786
                                  Hi @ianperrin is it possible to show the strava stats of the people you are following?
                                  • karsten13K
                                    karsten13
                                    everything you find here is possible: http://developers.strava.com/docs/reference/
                                      bachoo786 @karsten13
                                      @karsten13 Thanks for your answer but is it possible to show the strava stats of the people you are following on this particular module?
                                      • I
                                        ianperrin @bachoo786
                                        @bachoo786 - you can add multiple instances of the module and link them to different athletes, but this is expected to be for other members of the household as you would need to authenticate the respective module as them so not intended for “remote” athletes you follow.
                                          jawinemiller
                                          I am new to the whole MM thing and I am trying to setup my first project and I am struggling to get the MMM-Strava to work. When I launch MM I just see the following message on the mirror.
                                          Client id unauthorized - please visit /MMM-Strava/auth/
                                          So i went back and check my Stava API CLient id and it looks to be correct as well as the secret code. I am wondering if my Authorization Callback domain is incorrect on Strava’s website.
                                          Also when i try to use a web browser to remotely access my raspberryPi I get the following error. Not sure if both are tied to each other
                                          This device is not allowed to access your mirror.
                                          Please check your config.js or config.js.sample to change this.
                                          Anybody have any thoughts?
                                          • lavolp3L
                                            lavolp3 Module Developer @jawinemiller
                                            @jawinemiller said in MMM-Strava:
                                            You can set in your config:
                                            address: "0.0.0.0",
                                            ipWhitelist: [],
                                            or at least include your computer IP into the ipWhitelist.
                                            Only then you can access the mirror from another device.
                                            When you keep the whitelist empty every device (also external ones!!) will be allowed to access the mirror via browser.
                                            lavolp3L J 2 Replies Last reply
                                            • 6 / 7
