    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 286.0k Views 35 Watching
      daymo87
      Hi is there a way to display units in imperial for just the strava module & not the whole magic mirror?
      Damon
      • L
        Lagmin
        I can’t get this step:
        Authenticate the module to allow access to the Strava API.
        Browse to the Strava authentication page: http://localhost:8080/MMM-Strava/auth/ - the exact URL may vary depending on your configuration.
        Simply it doesn’t connect to my local host which is 192.168.0.177 (I am replacing with it the “localhost” in page adress).
        It is saying that page is not existing… Any ideas?
        Arek
        • I
          ianperrin @Lagmin
          @Lagmin where are you accessing the MagicMirror from?
          If you are doing this from the Raspberry Pi, the url will probably start with http://localhost:8080
          If you are doing this from another computer on your network, the url will start with the IP address, http://192.168.0.177:8080 - though you will need to set the ipWhitelist option in the configuration file first.
          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
          • L
            Lagmin
            I am trying to do it from Raspberry directly. Still no success :/
              @Lagmin u must provide the port
              • L
                Lagmin @sdetweil
                @sdetweil where can I find the port?
                  sdetweil @Lagmin
                  @Lagmin it’s the value of port: in config.js
                    bachoo786 @sdetweil
                      bachoo786
                        bachoo786
                        Hi @ianperrin is it possible to show the strava stats of the people you are following?
                        • karsten13K
                          karsten13
                          everything you find here is possible: http://developers.strava.com/docs/reference/
                            bachoo786 @karsten13
                            @karsten13 Thanks for your answer but is it possible to show the strava stats of the people you are following on this particular module?
                            • I
                              ianperrin @bachoo786
                              @bachoo786 - you can add multiple instances of the module and link them to different athletes, but this is expected to be for other members of the household as you would need to authenticate the respective module as them so not intended for “remote” athletes you follow.
                                jawinemiller
                                I am new to the whole MM thing and I am trying to setup my first project and I am struggling to get the MMM-Strava to work. When I launch MM I just see the following message on the mirror.
                                Client id unauthorized - please visit /MMM-Strava/auth/
                                So i went back and check my Stava API CLient id and it looks to be correct as well as the secret code. I am wondering if my Authorization Callback domain is incorrect on Strava’s website.
                                Also when i try to use a web browser to remotely access my raspberryPi I get the following error. Not sure if both are tied to each other
                                This device is not allowed to access your mirror.
                                Please check your config.js or config.js.sample to change this.
                                Anybody have any thoughts?
                                • lavolp3L
                                  lavolp3 Module Developer @jawinemiller
                                  @jawinemiller said in MMM-Strava:
                                  You can set in your config:
                                  address: "0.0.0.0",
                                  ipWhitelist: [],
                                  or at least include your computer IP into the ipWhitelist.
                                  Only then you can access the mirror from another device.
                                  When you keep the whitelist empty every device (also external ones!!) will be allowed to access the mirror via browser.
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                  lavolp3L J 2 Replies Last reply Reply Quote 0
                                  • lavolp3L
                                    lavolp3 Module Developer @lavolp3
                                    @lavolp3 you can also include your IP subnet into the whitelist.
                                    I think there is even a description and some examples in the config itself.
                                      jawinemiller @lavolp3
                                      @lavolp3 thanks for the suggestions. I changed my ipWhitelist to ipWhitelist: [], and now i am able to view my MM on my phone. I already had the address set to “0.0.0.0” like you suggested.
                                      It still looks like i am getting the same Client-ID error (Client id unauthorized - please visit /MMM-Strava/auth/) on my MM. Anyone have any suggestions on how to correct that? What should the Authorization Callback domain be on the stava website? I currently have my it as my raspberrypi-IP-address:8080
                                      • lavolp3L
                                        I think it’s in the description. Open raspberrypi-IP-address:8080/MMM-Strava/auth/ on another device and try authenticating your device.
                                        You need to authenticate the device to get access to the API.
                                          @lavolp3 Thanks, i was finally able to get it to authorize!
                                          • G
                                            gab0ru
                                            Hi guys!
                                            i have some trouble with activate Strava on MagicMirror.
                                            after i go to auth link from MagicMirror and i authorise device, reboot MagicMirror i get again the link to authorise device, below is my configuration
        module: 'MMM-Strava',
        header: 'Strava',
        position: 'top_right',
        client_id: '55xxx',
        client_secret: '119e5dxxxxxxx',
        activities: ['run', 'ride']
                                            • 6 / 7
