    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 278.4k Views 35 Watching
      matt216
      Hi there. Icons. Recently updated my config to include ‘hike’ activity, and it does, but without the nice little icon beside (like the little shoe beside run activities, and bike beside cycle activities). In ‘chart’ mode. Any ideas?
      • H Offline
        huso15
        why am I getting this error?
        pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ npm install --production
        audited 1631 packages in 19.838s
        73 packages are looking for funding
        run npm fund for details
        found 0 vulnerabilities
        – how do I fix this funding issue? I don’t have any luck with “nom fund”.
        I’m also having difficulties connecting to http://localhost:8080/MMM-Strava/auth/ and I’m thinking it’s because of this funding. Any help would be appreciated.
        Thank you!
        • W Offline
          Wilson101 @ianperrin
          @ianperrin hello i have tried to run this i am a complete beginner learning as i am going, however trying to get this radial version which i think looks really cool it gets stuck, i launch my magic mirror and then it gets stuck on the “loading…” process
            ruudvddries @ianperrin
            @ianperrin Is it possible to shrink the radial display from the current 500px width to something smaller. Like 300px?
            The radial display for strava is awesome. With its default size it somewhat messes up my MagicMirror layout.
            I already tried some CSS and JS adaptions but it not yet helped to achieve what I wanted. Any help is welcome!
            Greetings,
            Ruud
            • thymonT Offline
              thymon
              Hello
              Today I have an error message on display :
              502 - undefined
              Any idea for this ?
                ctatos
                Hey Ian, are you aware if the recent changes in API will affect the module? For non-paying Strava users, it seems like the API request goes through but no data is fetched…
                From Strava: “We realize these API changes could be especially challenging for some developers, so they’ll be non-breaking for 30 days, returning empty data during that time so they can make necessary adjustments. After June 18th, those endpoints will either omit the data or return an error message.”
                • lavolp3L Offline
                  lavolp3 Module Developer @ctatos
                  @ctatos said in MMM-Strava:
                  From Strava: “We realize these API changes could be especially challenging for some developers, so they’ll be non-breaking for > 30 days, returning empty data during that time so they can make necessary adjustments. After June 18th, those endpoints will
                  That’s only valid for segment leaderboards which are not used in this module.
                  This module only calls user statistics which will still work with the changes.
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                    ctatos @lavolp3
                    @lavolp3 Oh OK that’s good news. Do you know why the YTD stats stopped working from June 1st? or maybe it’s only on my side…
                      daymo87
                      Hi is there a way to display units in imperial for just the strava module & not the whole magic mirror?
                      Damon
                      • L Offline
                        Lagmin
                        I can’t get this step:
                        Authenticate the module to allow access to the Strava API.
                        Browse to the Strava authentication page: http://localhost:8080/MMM-Strava/auth/ - the exact URL may vary depending on your configuration.
                        Simply it doesn’t connect to my local host which is 192.168.0.177 (I am replacing with it the “localhost” in page adress).
                        It is saying that page is not existing… Any ideas?
                        Arek
                        • I Offline
                          ianperrin @Lagmin
                          @Lagmin where are you accessing the MagicMirror from?
                          If you are doing this from the Raspberry Pi, the url will probably start with http://localhost:8080
                          If you are doing this from another computer on your network, the url will start with the IP address, http://192.168.0.177:8080 - though you will need to set the ipWhitelist option in the configuration file first.
                          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                          • L Offline
                            Lagmin
                            I am trying to do it from Raspberry directly. Still no success :/
                              @Lagmin u must provide the port
                              • L Offline
                                Lagmin @sdetweil
                                @sdetweil where can I find the port?
                                  sdetweil @Lagmin
                                  @Lagmin it’s the value of port: in config.js
                                    bachoo786 @sdetweil
                                      bachoo786
                                        bachoo786
                                        Hi @ianperrin is it possible to show the strava stats of the people you are following?
                                        • karsten13K Online
                                          karsten13
                                          everything you find here is possible: http://developers.strava.com/docs/reference/
                                            bachoo786 @karsten13
                                            @karsten13 Thanks for your answer but is it possible to show the strava stats of the people you are following on this particular module?
                                            • 6 / 7
