    My first, slim mirror at home
    12 Posts 7 Posters 6.0k Views 6 Watching
    • uros76U Offline
      uros76
      Finally, I made it! My first magic mirror at home. I was planning and getting it all together for months.
      Software and motion…
      Initial MM install on Pi4 was not so hard, the only thing I struggled was putting the screen to sleep and waking it up with motion.
      After trying several PIR sensors I always had false detections or poor detection. It would also look ugly on a clean minimal frame I wanted to install. I simply gave up on the PIR sensor and switched to RCWL-0516 sensor.
      Here I need to thank @Fozi for his post on using a microwave sensor. Really good post with everything explained. When I tried a microwave sensor it just worked in the first try!
      I am still fine tuning MM modules use and so far I have on: weather, air quality, spotify, philips hue, calendar, news, system stats, sunrise sunset, and motion detection and bible verse. All runs great on a 2GB Pi4 system.
      Screen…
      I was lucky to have a spare samsung 24" screen that was easy to disassemble. Total screen depth without its motherboard is only 20mm. That gave me the opportunity to use an ordinary wood frame and go as slim as possible.
      I did need to move the screen mainboard to a different location which meant extending 6wire cable for the backlight. Another good thing with this monitor that it’s powered by external 14V brick. It means no mains AC power needed on mirror assembly.
      Mirror glass…
      Big thanks to @Goldjunge_Chriz for organizing group buy of mirror glass. The glass itself looks great and it’s not too heavy. I was double lucky with my order, got it delivered in one piece and it had no protective film to indicate correct side :D
      Advice for folks deciding on a future order of glass mirror, take it with polished edges. It makes your life easier when handling with a bigger piece of glass.
      Frame and mounting…
      First, I prepared the glass with putting sheets of black A3 format paper and taping it down to the backside. Also, I cut a hole for the screen and taped the edges of the screen.
      Then I went to local picture framing studio where at first I got weird looks but then guys took it in and did a good job. They did a frame under a frame design. First bigger frame for the glass and under it another smaller frame for screen.
      I was positively surprised how good it looked, even my wife changed her mind :D After getting frame done I focused on cables. I tried to minimize connections as much as possible but in the end, I have 3 cables (HDMI, screen power, motion sensor) that need to connect to the mirror. I am looking at cable connector ideas for quicker disassembly when needed.
      I was also worried about how to mount it all on a wall. In the end, I drilled 3 mounting holes to the wall with sturdy long hanging screws. Top and bottom screws are for hangers mounted on the frame and I also added a screw to the middle, just under the screen frame to add that extra holding place. There is another bigger hole for routing all cables from the back of wall.
      I hope this mounting will be sufficient, the whole mirror is like 7-8kg. If anyone has better ideas of mounting wooden framed mirror pls share.
      Overall I am happy with this build. The whole frame is max 26mm from the wall and the fact there are no wires anywhere it makes it a true magic mirror ;)
      Also, I learned some new things and found another great community of builders!
      mumblebajM 1 Reply Last reply Reply Quote 4
      • mumblebajM Offline
        mumblebaj Module Developer @uros76
        @uros76 Looks very nice and clean. Like the “no wires” idea. Well done.
        • devcybikoD Offline
          devcybiko
          Awesome. Really tall and slim. Nicely done
            ashishtank Module Developer
            Looks Beautiful !
              Philly
              Beautiful mirror! The only part that I’m stuck on is the microwave sensor, I don’t have a soldering iron so I’m curious on how you wired the sensor because that seems to be my issue
              uros76U 1 Reply Last reply Reply Quote 0
              • uros76U Offline
                uros76 @Philly
                @Philly yes I did solder on three needed wires. You can’t let them hang on sensor connection points, need to be soldered.
                Try getting soldering gun from some friend. And skip buying cheap soldering device…
                • FoziF Offline
                  Fozi Project Sponsor
                  Congrats! Just my kind of style! I’m happy that I could help you with the microwave sensor!:thumbs_up_light_skin_tone:
                    djdocta
                    @Fozi, can you please list out the different modules that you have used on your mirror ?
                    • FoziF Offline
                      Fozi Project Sponsor @djdocta
                      @djdocta Tese are the modules I have currently installed. Thy are distributed over 3 pages:
                      MMM-pages
                      MMM-TextClock
                      alert
                      updatenotification
                      clock
                      MMM-MyCalendar
                      newsfeed
                      MMM-withings
                      MMM-Strava
                      MMM-Sonos
                      MMM-DarkSkyForecast
                      MMM-RAIN-MAP
                      MMM-DWD-WarnWeather
                      MMM-MyScoreboard
                      MMM-Podcast2
                      MMM-PublicTransportHafas
                      MMM-Remote-Control
                      MMM-GroveGestures
                      netatmo
                      MMM-Tools
                      mmm-hue-lights
                      MMM-Homematic
                      MMM-PIR-Sensor
                      MMM-AlexaControl
                      MMM-page-indicator
                        djdocta
                        Nice…what spotify module are you using ? I like the background when it is idle.
                        FoziF uros76U 2 Replies Last reply Reply Quote 0
                        • FoziF Offline
                          @djdocta I don’t use a Spotify module as I have the sonos module which shows every music service it is connected to.
                          • uros76U Offline
                            uros76 @djdocta
                            @djdocta I am using this one for spotify https://github.com/raywo/MMM-NowPlayingOnSpotify
