    MMM-soccer : black screen, problem of config.js
    24 Posts 3 Posters 4.7k Views 3 Watching
      sdetweil @RIKKO14
      @RIKKO14 what are the messages in the window where u did npm start?
      if none then open the developers window, ctrl-shift-i on the keyboard, select the tab labeled console, and scroll up for any errors, usually red text
        RIKKO14
        I don’t understand what you’re asking me to do …
        my pm2 logs is :
        pi@raspberrypi:~/MagicMirror/modules/MMM-soccer $ pm2 logs
        /home/pi/.pm2/pm2.log last 15 lines:
        PM2        | 2020-09-02T16:53:22: PM2 log: ===============================================================================
        PM2        | 2020-09-02T16:53:22: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2020-09-02T16:53:22: PM2 log: App [mm:0] online
        PM2        | 2020-09-02T17:31:26: PM2 log: Stopping app:mm id:0
        PM2        | 2020-09-02T17:31:26: PM2 log: pid=568 msg=failed to kill - retrying in 100ms
        PM2        | 2020-09-02T17:31:26: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-09-02T17:31:26: PM2 log: pid=568 msg=process killed
        PM2        | 2020-09-02T17:31:26: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2020-09-02T17:31:26: PM2 log: App [mm:0] online
        PM2        | 2020-09-02T18:38:38: PM2 log: Stopping app:mm id:0
        PM2        | 2020-09-02T18:38:39: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-09-02T18:38:39: PM2 log: pid=4304 msg=process killed
        PM2        | 2020-09-02T18:38:39: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2020-09-02T18:38:39: PM2 log: App [mm:0] online
        0|mm       | [2020-09-02 18:38:41.282] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:392
        0|mm       |         },
        0|mm       |         ^
        0|mm       |
        0|mm       | SyntaxError: Unexpected token }
        0|mm       |     at Module._compile (internal/modules/cjs/loader.js:722:23)
        0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
        0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32)
        0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:560:12)
        0|mm       |     at Module.require (internal/modules/cjs/loader.js:685:19)
        0|mm       |     at require (internal/modules/cjs/helpers.js:16:16)
        0|mm       |     at loadConfig (/home/pi/MagicMirror/js/app.js:67:12)
        0|mm       |     at App.start (/home/pi/MagicMirror/js/app.js:202:3)
        0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:126:7)
        0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
        0|mm       | > magicmirror@2.12.0 start /home/pi/MagicMirror
        0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        0|mm       |
        0|mm       | [2020-09-02 18:38:41.268] [LOG]    Starting MagicMirror: v2.12.0
        0|mm       | [2020-09-02 18:38:41.277] [LOG]    Loading config ...
        0|mm       | [2020-09-02 18:38:41.285] [LOG]    Loading module helpers ...
        0|mm       | [2020-09-02 18:38:41.330] [LOG]    Initializing new module helper ...
        0|mm       | [2020-09-02 18:38:41.332] [LOG]    Module helper loaded: updatenotification
        0|mm       | [2020-09-02 18:38:41.334] [LOG]    No helper found for module: helloworld.
        0|mm       | [2020-09-02 18:38:41.336] [LOG]    All module helpers loaded.
        0|mm       | [2020-09-02 18:38:41.451] [LOG]    Starting server on port 8080 ...
        0|mm       | [2020-09-02 18:38:41.465] [LOG]    Server started ...
        0|mm       | [2020-09-02 18:38:41.467] [LOG]    Connecting socket for: updatenotification
        0|mm       | [2020-09-02 18:38:41.469] [LOG]    Sockets connected & modules started ...
        0|mm       | [2020-09-02 18:38:41.550] [LOG]    Launching application.
          RIKKO14
          alt text)
            sdetweil @RIKKO14
            @RIKKO14 that ctrl-shift-i needed to be done on the mirror screen
              RIKKO14
              this is my black screen,
              so my pb comes from my config.js
                RIKKO14
                alt text
                  sdetweil @RIKKO14
                  @RIKKO14 ok, that is not a black screen,
                  the pm2 logs says there is a missing close brace, }
                    A Former User
                    and where is located you config.js file ?
                    It should in this directory : /home/pi/MagicMirror/config/
                    For me, it’s not a black screen, I’s just because, MagicMirror don’t find you config.js file
                      sdetweil @Guest
                      @Bugsounet no, he had a syntax error, and it loads the ‘no config’ error page
                        A Former User
                        right sam, i don’t read log
                        maybe, this part missing, on the end of the file
                        if missing, config will not be exported (like a file not there)
                        it’s the same for var config = { on the start of the file
                        but by reading the error log:
                        there is an error before this ligne (generaly on line-1 … so line 391)
                        So, can you past there your config From line 380 to 410 (don’t forget to remove personal ident)
                          RIKKO14
                          yes my config.js is this directory /home/pi/MagicMirror/config/
                          the problem comes from “}” or “},” but where ???
                            RIKKO14
                              sdetweil @RIKKO14
                              @RIKKO14 says line 392
                              0|mm       |         },
                              0|mm       |         ^
                              0|mm       |
                                RIKKO14
                                I delete focus_on: { null }, and it’s good,
                                thank you very much to you 2 !
                                ? 1 Reply Last reply
                                  A Former User
                                  balaye toute la partie doite !
                                  ça tombe tu as caractere de caché, je vois qu’il y a une grande brarre en bas pour se déplacer, déplace la sur la droite.
                                  Regarde toute la partie que tu n’as pas vu
                                  il doit avoir un caractere, c’est sur et certain !
                                  @sam, sorry sometime it’s more simple between french user
                                  I suspect a character in the right part of the file (because not displayed, he have to move the bar to the right)
                                    sdetweil @Guest
                                    @Bugsounet it’s ok. u exude me all the time! lol
                                      A Former User
                                      complex to explain in english :(
                                        sdetweil @Guest
                                        @Bugsounet lol( not for me, french is harder!!)
                                          A Former User
                                          lol (not a problem french …don’t know why …)
                                          So @RIKKO14 ?
                                            A Former User @RIKKO14
                                            @RIKKO14 said in MMM-soccer : black screen, problem of config.js:
                                            oupss … not see the answer :'(
