    MMM-soccer : black screen, problem of config.js
    24 Posts 3 Posters 4.7k Views 3 Watching
      RIKKO14
      alt text
        sdetweil @RIKKO14
        @RIKKO14 ok, that is not a black screen,
        the pm2 logs says there is a missing close brace, }
          A Former User
          and where is located you config.js file ?
          It should in this directory : /home/pi/MagicMirror/config/
          For me, it’s not a black screen, I’s just because, MagicMirror don’t find you config.js file
            sdetweil @Guest
            @Bugsounet no, he had a syntax error, and it loads the ‘no config’ error page
              A Former User
              right sam, i don’t read log
              maybe, this part missing, on the end of the file
              if missing, config will not be exported (like a file not there)
              it’s the same for var config = { on the start of the file
              but by reading the error log:
              /home/pi/MagicMirror/config/config.js:392
              there is an error before this ligne (generaly on line-1 … so line 391)
              So, can you past there your config From line 380 to 410 (don’t forget to remove personal ident)
                RIKKO14
                yes my config.js is this directory /home/pi/MagicMirror/config/
                the problem comes from “}” or “},” but where ???
                  RIKKO14
                    sdetweil @RIKKO14
                    @RIKKO14 says line 392
                    0|mm       |         },
                    0|mm       |         ^
                    0|mm       |
                    0|mm       | SyntaxError: Unexpected token }
                      RIKKO14
                      I delete focus_on: { null }, and it’s good,
                      thank you very much to you 2 !
                      ? 1 Reply Last reply
                        A Former User
                        balaye toute la partie doite !
                        ça tombe tu as caractere de caché, je vois qu’il y a une grande brarre en bas pour se déplacer, déplace la sur la droite.
                        Regarde toute la partie que tu n’as pas vu
                        il doit avoir un caractere, c’est sur et certain !
                        @sam, sorry sometime it’s more simple between french user
                        I suspect a character in the right part of the file (because not displayed, he have to move the bar to the right)
                          sdetweil @Guest
                          @Bugsounet it’s ok. u exude me all the time! lol
                            A Former User
                            complex to explain in english :(
                              sdetweil @Guest
                              @Bugsounet lol( not for me, french is harder!!)
                                A Former User
                                lol (not a problem french …don’t know why …)
                                So @RIKKO14 ?
                                  A Former User @RIKKO14
                                  @RIKKO14 said in MMM-soccer : black screen, problem of config.js:
                                  oupss … not see the answer :'(
                                    RIKKO14
                                    I searched in various files in the MMM-soccer folder but could not find how to change and where to write instead:
                                    • mmm-soccer over the line
                                    • “Matchday” per “Journée”: 2
                                    • “Team” by “Equipe”
                                    do you know which files to modify ?
                                      A Former User
                                      a french user make pull request for create a fr translate but … it’s not commit
                                      so try this:
                                      we will do a simple thing, we will override the en default file with the french value
                                      explain:
                                      in MMM-soccer directory, you have translation directory
                                      edit en.json file
                                      copy the content of this
                                      and past it in the en.json file
                                      of course delete all content of the en.json file and replace it with the french content
                                      and restart the mirror !
                                      Edit MMM-soccer will see some translation for en … it will not control and display french value :)
                                        RIKKO14
                                        so cool, it’s good
                                        thank you so much
