    MMM-soccer : black screen, problem of config.js
    24 Posts 3 Posters 4.1k Views 3 Watching
      RIKKO14
      this is my black screen,
      so my pb comes from my config.js
        RIKKO14
        alt text
          sdetweil @RIKKO14
          @RIKKO14 ok, that is not a black screen,
          the pm2 logs says there is a missing close brace, }
            [[global:former-user]]
            and where is located you config.js file ?
            It should in this directory : /home/pi/MagicMirror/config/
            For me, it’s not a black screen, I’s just because, MagicMirror don’t find you config.js file
              sdetweil @Guest
              @Bugsounet no, he had a syntax error, and it loads the ‘no config’ error page
                right sam, i don’t read log
                maybe, this part missing, on the end of the file
                if missing, config will not be exported (like a file not there)
                it’s the same for var config = { on the start of the file
                but by reading the error log:
                /home/pi/MagicMirror/config/config.js:392
                there is an error before this ligne (generaly on line-1 … so line 391)
                So, can you past there your config From line 380 to 410 (don’t forget to remove personal ident)
                  RIKKO14
                  yes my config.js is this directory /home/pi/MagicMirror/config/
                  the problem comes from “}” or “},” but where ???
                    RIKKO14
                      sdetweil @RIKKO14
                      @RIKKO14 says line 392
                      0|mm       |         },
                      0|mm       |         ^
                      0|mm       |
                      0|mm       | SyntaxError: Unexpected token }
                        RIKKO14
                        I delete focus_on: { null }, and it’s good,
                        thank you very much to you 2 !
                          balaye toute la partie doite !
                          ça tombe tu as caractere de caché, je vois qu’il y a une grande brarre en bas pour se déplacer, déplace la sur la droite.
                          Regarde toute la partie que tu n’as pas vu
                          il doit avoir un caractere, c’est sur et certain !
                          @sam, sorry sometime it’s more simple between french user
                          I suspect a character in the right part of the file (because not displayed, he have to move the bar to the right)
                            sdetweil @Guest
                            @Bugsounet it’s ok. u exude me all the time! lol
                              complex to explain in english :(
                                sdetweil @Guest
                                @Bugsounet lol( not for me, french is harder!!)
                                  lol (not a problem french …don’t know why …)
                                  So @RIKKO14 ?
                                    [[global:former-user]] @RIKKO14
                                    @RIKKO14 said in MMM-soccer : black screen, problem of config.js:
                                    oupss … not see the answer :'(
                                      RIKKO14
                                      I searched in various files in the MMM-soccer folder but could not find how to change and where to write instead:
                                      • mmm-soccer over the line
                                      • “Matchday” per “Journée”: 2
                                      • “Team” by “Equipe”
                                      do you know which files to modify ?
                                        a french user make pull request for create a fr translate but … it’s not commit
                                        so try this:
                                        we will do a simple thing, we will override the en default file with the french value
                                        explain:
                                        in MMM-soccer directory, you have translation directory
                                        edit en.json file
                                        copy the content of this
                                        and past it in the en.json file
                                        of course delete all content of the en.json file and replace it with the french content
                                        and restart the mirror !
                                        Edit MMM-soccer will see some translation for en … it will not control and display french value :)
                                          RIKKO14
                                          so cool, it’s good
                                          thank you so much
