    Could use some assistance setting up MMM-Carousel w/ Navigation and understanding the architecture
    carouselmmm-carouselnavigationslidepage
    27 Posts 9 Posters 18.2k Views 9 Watching
      mcneilp
      Does anyone know if it is possible with this module to have the first slide show for a longer period of time…then rotate through the other slides. This way you mainly see the primary one, and secondary ones periodically rotate through.
      • N
        NicB72
        So I am having a problem with the carouselID item as well
        In slides config I have this
                            slides: [
                                    ["clock"],
                                    [{name:"weather", carouselId:"1"}],
                                    [{name:"weather", carouselId:"2"}],
                                    ["newsfeed"],
                                    ["calendar"]
        Then below I have the 2 modules.
        I have the other modules as well!
        Everything displays except these 2 weather slides where I get nothing,.
                            module: "weather",
                            position: "middle_center",
                                    carouselId: "1",
                                    type: "current",
                                    units: "imperial",
                                    roundTemp: true,
                                    onlyTemp: false,
                                    locationID: "4933743",
                                    apiKey: "cc448befd6aea28cbb05457253a9622b"
                            module: "weather",
                                    carouselId: "2",
                                    type: "forecast",
                                    units: "imperial",
                                    apiKey: "cc448befd6aea28cbb05457253a9622b",
          sdetweil @NicB72
          @NicB72 the ID “1” is the name of the slide, not attribute carouselId
          N 1 Reply Last reply
          • N
            NicB72 @sdetweil
            @sdetweil I don;'t understand. I am using the carouselID as described in the advanced config section of MMM-Carousel.
              banbutcher
              hi,
              while we are on the subject of carousel… ive just been playing with it and only having moderate success.
              first here is my Module Code:
              /*-------------------- MMM-Carousel Start-----------------*/
                          module: 'MMM-Carousel',
              //	    position: 'botton_bar',
                              transitionInterval: 10000,
              		showPageIndicators: true,
              		showPageControls: true,
                              ignoreModules: ['alert'],
                              mode: 'slides',
                              slides: [
                                  ['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast'],
                                  ['MMM-google-route2'],
              		    ['MMM-GoogleMapsTraffic'],
                                  ['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
              		    'MMM-COVID19-SPARKLINE', 'MMM-Spotify', 'MMM-GoogleFit', 'newsfeed'],
                                  ['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-YouTube',
              		    'MMM-NetworkConnection', 'deluge', 'MMM-SystemStats', 'MMM-NetworkScanner'],
                              keyBindings: {
                                  enabled: true,
                                  map: {
                                      NextSlide: "ArrowRight",
                                      PrevSlide: "ArrowLeft",
                                      Slide0:    "Home"
                                  mode: "DEFAULT"
              when i used barnabycolby/MMM-Carousel it works fine rotating tru the pages every 10 secs… but when i change the rotation time to 0 so i can manually pick with arrow keys, it kind of has a fit and cant decide what page to show. and cpu usage goes high also
              then i found shbatm/MMM-Carousel tried it and when used in the config above its loads all modules and stacks them on the first and only page. Then i tried it withhh this code:
                              slides: [
                                  Default: ['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast'],
                                  Work: ['MMM-google-route2'],
              		    Traffic:['MMM-GoogleMapsTraffic'],
                                  Home: ['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
                                  Info: ['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-YouTube',
              and i get the “please create a config file” error
              then i noticed the different type bracket after slide: changed the []'s to {}'s and again it tries to load all modules on first page. then taught to delete the Default: Work: etc and i was back with the “please create a config file” error.
              also tried taking all the duplicate modules out and only have unique modules on each page with no luck, i think ive tried all the different ways covered in the post.
              to say im stumped is a bit of an understatement! :/
              hope all that made sense…hope someone can help :)
              Thanks,
              Richie
                sdetweil @banbutcher
                @banbutcher the words to the left of the [ needs to be in quotes, the page name/ id
                B 1 Reply Last reply
                  sdetweil @NicB72
                  @NicB72 said in Could use some assistance setting up MMM-Carousel w/ Navigation and understanding the architecture:
                  looks like the id is supposed to be a number, by putting it in quotes it is a string.
                  see this post
                  https://forum.magicmirror.builders/topic/6640/could-use-some-assistance-setting-up-mmm-carousel-w-navigation-and-understanding-the-architecture/15?page=2
                  also, make sure which mmm-carousel u are using
                    banbutcher @sdetweil
                                    slides: {
                                        "Default":['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast'],
                                        "Work":['MMM-google-route2'],
                    		    "Traffic":['MMM-GoogleMapsTraffic'],
                                        "Home":['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
                                        "Info":['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-YouTube', 'MMM-NetworkScanner',
                    		    'MMM-NetworkConnection', 'deluge', 'MMM-SystemStats'],
                    like this? again all modules stacked on first and only page, also tried with numbers instead of words!
                      @banbutcher I am not near my computer so have to wait til I can try.
                      which module are you using, there are at least 3 different ones
                        banbutcher
                        ive used both barnabycolby and shbatm versions.
                          banbutcher
                          so i figured it out… using barnabycolby im not able to have the page rotation set to 0.
                          MMM-GoogleAssistant works as intended along with MMM-GABackground.
                          My config for barnabycolbys:
                                          mode: 'slides',
                                          slides: [
                                              ['MMM-google-route'],
                          using shbatm i needed the position: 'bottom_bar' and now i can set the rotation time to 0 and control the slides with the arrow keys and MMM-KeyBindings, however it seems that when i use this version the MMM-GoogleAssistant does not display the correct background and therefore cannot use the new MMM-GABackground
                          my config for shbatm:
                          	    position: 'bottom_bar',
                                          transitionInterval: 0,
                                          mode: 'slides',
                                          slides: {
                                              "Work":['MMM-google-route'],
                                              "Office":['MMM-google-route2'],
                                          keyBindings: {
                                              enabled: true,
                                              map: {
                                                  Slide0:    "Home"
                                              keyBindingsMode: "DEFAULT"
                          hope this helps someone
                          @Bugsounet @shbatm any idea why GAB will work with one carousel module and not another?
                            @banbutcher so, there were two problems
                            0 cycle time
                            and carouselId
                            I had my brain screwed on crooked for carouselId.
                            suppose you had multiple instances of the same module name in config.js, showing different things on different slides.
                            when u define the slides, u use the module ‘name’, but in this case, name is not enough.
                            so, in the module definitions themselves u add another unique identifier, carouselId: somestring. the value can be anything.
                            in their config:{} section, that is where carousel module will look for ‘carouselId’
                            in the slide definition, when u come to that module to be displayed, instead of putting the name in quotes, you need a little structure
                            { name: "module name", carouselId:"samevalue_added_to_module_config" } ,
                            that way the carousel module can tell which module instance should be shown
