    Could use some assistance setting up MMM-Carousel w/ Navigation and understanding the architecture
    carouselmmm-carouselnavigationslidepage
    27 Posts 9 Posters 18.2k Views 9 Watching
    • L
      lamachine @shbatm
      @shbatm
      wow, the developer again, thanks so much for the quick reply!
      I thought I was making some progress, but still not quite right…
      Code changes as follows
      module: 'MMM-Carousel',
                              transitionInterval: 10000,
                              ignoreModules: ['clock', 'alert','currentweather', 'com$
                              mode: 'slides',
                              slides: [
                                  [ {name:'calendar', carouselID:"1"}],
      and
                              header: "Boy's Calendar",
                                      carouselId: "1",
                                                      symbol: "calendar-check-o",
                                                      url: "https
      I ran it through JSHint, so at least the formatting is acceptable.
        shbatm Module Developer @lamachine
        Check your capitalization in the MMM-Carousel config. It should be carouselId, not carouselID.
          robiv8
          This is my config for test.
                      position: 'bottom_bar', // Required only for navigation controls
                          transitionInterval: 0,
                          showPageIndicators: true,
                          showPageControls: false,
                          ignoreModules: ['MMM-Podcast2', 'alert', 'MMM-Buttons', 'MMM-Remote-Control', 'MMM-Remote-Control-Repository'],
                          mode: 'slides',
                          slides: {
                              main: [{name:'clock', carouselId: "1"}],
                              "2": ['MMM-DarkSkyForecast', 'newsfeed'],
                              "3": ['MMM-DWD-WarnWeather'],
                              "4": ['MMM-DarkSkyForecast', 'newsfeed'],
                              "5": ['MMM-DWD-WarnWeather'],
                              "6": ['MMM-DarkSkyForecast', 'newsfeed']
          and this the two modules
          module: "clock",
          position: "middle_center",
          carouselId: "1",
          showDate: false,
          displayType: 'analog',
          analogSize: '540px',
          analogFace: 'face-001',
          secondsColor: '#FF0000',
          analogPlacement: 'top'
          module: "clock",
          carouselId: "2",
          showDate: false,
          analogSize: '570px',
          but the clock is only visible on page 6?
          And the main page is completely missing!
          I am confused :thinking_face:
          But then I tried the following:
          instead of
          main: [{name:‘clock’, carouselId: “1”}],
          I put this
          “1”: [{name:‘clock’, carouselId: “1”}],
          And what should I say! It works. :smiling_face_with_open_mouth:
            shbatm Module Developer @robiv8
            @robiv8 Strange. I wonder if it’s something with the word main. You could also try "Main".
            Here’s one of my carousel configs for another reference:
                            slides: {
                                Home: [{ name: 'clock', classes: 'zoom200', position: "middle_center", carouselId: 1 }],
                                Info: [{ name: 'clock', classes: 'zoom200', position: "top_center", carouselId: 1 },
                                    { name: 'calendar', position: 'top_left' }, 'MMM-Todoist',
                                    'newsfeed',
                                Status: [{ name: 'clock', classes: '', position: "top_left", carouselId: 2 },
                                    'MMM-JSONStatusChecker', "internet-monitor"
                                ISY: [{ name: 'clock', classes: '', position: "top_left", carouselId: 2 }, 'MMM-ISY'],
                                Cameras: ["MMM-RTSPStream"],
                                Octopi: [{ name: 'clock', classes: '', position: "top_left", carouselId: 2 }, 'octomirror-module'],
              mcneilp
              Does anyone know if it is possible with this module to have the first slide show for a longer period of time…then rotate through the other slides. This way you mainly see the primary one, and secondary ones periodically rotate through.
              • N
                NicB72
                So I am having a problem with the carouselID item as well
                In slides config I have this
                                    slides: [
                                            ["clock"],
                                            [{name:"weather", carouselId:"1"}],
                                            [{name:"weather", carouselId:"2"}],
                                            ["newsfeed"],
                                            ["calendar"]
                Then below I have the 2 modules.
                I have the other modules as well!
                Everything displays except these 2 weather slides where I get nothing,.
                                    module: "weather",
                                            carouselId: "1",
                                            type: "current",
                                            units: "imperial",
                                            roundTemp: true,
                                            onlyTemp: false,
                                            locationID: "4933743",
                                            apiKey: "cc448befd6aea28cbb05457253a9622b"
                                    module: "weather",
                                            carouselId: "2",
                                            type: "forecast",
                                            units: "imperial",
                                            apiKey: "cc448befd6aea28cbb05457253a9622b",
                  sdetweil @NicB72
                  @NicB72 the ID “1” is the name of the slide, not attribute carouselId
                  N 1 Reply Last reply
                  • N
                    NicB72 @sdetweil
                    @sdetweil I don;'t understand. I am using the carouselID as described in the advanced config section of MMM-Carousel.
                      banbutcher
                      hi,
                      while we are on the subject of carousel… ive just been playing with it and only having moderate success.
                      first here is my Module Code:
                      /*-------------------- MMM-Carousel Start-----------------*/
                      //	    position: 'botton_bar',
                      		showPageControls: true,
                                      ignoreModules: ['alert'],
                                      mode: 'slides',
                                      slides: [
                                          ['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast'],
                                          ['MMM-google-route2'],
                      		    ['MMM-GoogleMapsTraffic'],
                                          ['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
                      		    'MMM-COVID19-SPARKLINE', 'MMM-Spotify', 'MMM-GoogleFit', 'newsfeed'],
                                          ['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-YouTube',
                      		    'MMM-NetworkConnection', 'deluge', 'MMM-SystemStats', 'MMM-NetworkScanner'],
                                      keyBindings: {
                                          enabled: true,
                                          map: {
                                              NextSlide: "ArrowRight",
                                              PrevSlide: "ArrowLeft",
                                              Slide0:    "Home"
                                          mode: "DEFAULT"
                      when i used barnabycolby/MMM-Carousel it works fine rotating tru the pages every 10 secs… but when i change the rotation time to 0 so i can manually pick with arrow keys, it kind of has a fit and cant decide what page to show. and cpu usage goes high also
                      then i found shbatm/MMM-Carousel tried it and when used in the config above its loads all modules and stacks them on the first and only page. Then i tried it withhh this code:
                                      slides: [
                                          Default: ['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast'],
                                          Work: ['MMM-google-route2'],
                      		    Traffic:['MMM-GoogleMapsTraffic'],
                                          Home: ['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
                                          Info: ['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-YouTube',
                      and i get the “please create a config file” error
                      then i noticed the different type bracket after slide: changed the []'s to {}'s and again it tries to load all modules on first page. then taught to delete the Default: Work: etc and i was back with the “please create a config file” error.
                      also tried taking all the duplicate modules out and only have unique modules on each page with no luck, i think ive tried all the different ways covered in the post.
                      to say im stumped is a bit of an understatement! :/
                      hope all that made sense…hope someone can help :)
                      Thanks,
                      Richie
                        sdetweil @banbutcher
                        @banbutcher the words to the left of the [ needs to be in quotes, the page name/ id
                        B 1 Reply Last reply
                          sdetweil @NicB72
                          @NicB72 said in Could use some assistance setting up MMM-Carousel w/ Navigation and understanding the architecture:
                          looks like the id is supposed to be a number, by putting it in quotes it is a string.
                          see this post
                          https://forum.magicmirror.builders/topic/6640/could-use-some-assistance-setting-up-mmm-carousel-w-navigation-and-understanding-the-architecture/15?page=2
                          also, make sure which mmm-carousel u are using
                            banbutcher @sdetweil
                                            slides: {
                                                "Default":['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast'],
                                                "Work":['MMM-google-route2'],
                            		    "Traffic":['MMM-GoogleMapsTraffic'],
                                                "Home":['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
                                                "Info":['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-YouTube', 'MMM-NetworkScanner',
                            		    'MMM-NetworkConnection', 'deluge', 'MMM-SystemStats'],
                            like this? again all modules stacked on first and only page, also tried with numbers instead of words!
                              @banbutcher I am not near my computer so have to wait til I can try.
                              which module are you using, there are at least 3 different ones
                                banbutcher
                                ive used both barnabycolby and shbatm versions.
                                  banbutcher
                                  so i figured it out… using barnabycolby im not able to have the page rotation set to 0.
                                  MMM-GoogleAssistant works as intended along with MMM-GABackground.
                                  My config for barnabycolbys:
                                                  mode: 'slides',
                                                  slides: [
                                                      ['MMM-google-route'],
                                  using shbatm i needed the position: 'bottom_bar' and now i can set the rotation time to 0 and control the slides with the arrow keys and MMM-KeyBindings, however it seems that when i use this version the MMM-GoogleAssistant does not display the correct background and therefore cannot use the new MMM-GABackground
                                  my config for shbatm:
                                                  mode: 'slides',
                                                  slides: {
                                                      "Work":['MMM-google-route'],
                                                      "Office":['MMM-google-route2'],
                                                  keyBindings: {
                                                      enabled: true,
                                                      map: {
                                                          Slide0:    "Home"
                                                      keyBindingsMode: "DEFAULT"
                                  hope this helps someone
                                  @Bugsounet @shbatm any idea why GAB will work with one carousel module and not another?
                                    @banbutcher so, there were two problems
                                    0 cycle time
                                    and carouselId
                                    I had my brain screwed on crooked for carouselId.
                                    suppose you had multiple instances of the same module name in config.js, showing different things on different slides.
                                    when u define the slides, u use the module ‘name’, but in this case, name is not enough.
                                    so, in the module definitions themselves u add another unique identifier, carouselId: somestring. the value can be anything.
                                    in their config:{} section, that is where carousel module will look for ‘carouselId’
                                    in the slide definition, when u come to that module to be displayed, instead of putting the name in quotes, you need a little structure
                                    { name: "module name", carouselId:"samevalue_added_to_module_config" } ,
                                    that way the carousel module can tell which module instance should be shown
