    MMM-Globe
    119 Posts 39 Posters 211.5k Views 40 Watching
    • LukeCodewalkerL Offline
      LukeCodewalker Module Developer @iMAGiC
      @iMAGiC & @gshimself: thanks for your feedback. would it be possible, that one of you could post a picture of the module on a mirror. I just started building mine (don’t have the glass yet) and would like to know how it looks on a mirror. right now I can only look at it on my monitor.
      iMAGiCI 1 Reply Last reply Reply Quote 0
      • iMAGiCI Offline
        iMAGiC @LukeCodewalker
        @LukeCodewalker my mirror will be built in my new living room on Jan, 2017.
        this is my test screen(22") with glass+film, I think you also want to see.
        Choice * Judgment * Values
        LukeCodewalkerL N 2 Replies Last reply Reply Quote 4
          @iMAGiC wow that looks great =)
          • N Offline
            Novocain @iMAGiC
            @iMAGiC
            Ni hao, fei chang hao :-)
            • G Offline
              GinSeng
              @LukeCodewalker great work! Thanks for this module, i already tested it. I will upload a picture tomorrow.
              But i have one question. Is it possible to fade the image ? Like its getting darker and brighter after time in repeat?
              LukeCodewalkerL 1 Reply Last reply Reply Quote 0
                LukeCodewalker Module Developer @GinSeng
                @GinSeng
                Thank you. I don’t really understand what you mean with fade. Do you want to have a fade between to images in the moment when a new picture was loaded? Or do you want to fade it over a longer time? Then you should try ‘natColor’ as the style property in your config for this module.
                • G Offline
                  GinSeng @LukeCodewalker
                  @LukeCodewalker
                  Yes i want to fade one picture over a longer time. Like an LED Fading on/off over a periodic time. But i managed to do it with a gif, i created.
                  Btw.: Here is a picture which i promised :) i used a custom picture. (It’s in the dark because the mirror isn’t complete by now and the monitor i use atm isn’t really the best :/ 0_1479547035036_2016-11-18_22-32-39_811.jpg
                    matt25
                    Have an issue with the module. Nothing display, only some lines…
                    I had a look at the code. The generated URL is correct, when I copy it into a browser I can see the picture:
                    http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_true_color.jpg?1479826211800
                    Then had a look at wrapper and image objects (in getDom) and display their attributes, everything seems ok.
                    All other modules works fine on my raspberry. Any help would be welcome, thanks in advance.
                    By the way, my config:
                        module: 'MMM-Globe',
                        position: 'center',
                            style: 'geoColor',
                            imageSize: 600,
                            ownImagePath:'',
                            updateInterval: 10*60*1000
                    Thank a lot.
                    Matt
                    • G Offline
                      GinSeng
                      @matt25
                      Hi Matt, try at position : ‘middle_center’ not only center.
                      M Andrius okA 2 Replies Last reply Reply Quote 0
                        matt25 @GinSeng
                        @GinSeng
                        Hi Ginseng, thanks for your help. Already tried different positions but no success:
                            position: 'middle_center',
                                style: 'geoColor',
                                imageSize: 600,
                                ownImagePath:'',
                        Also tried the module locally on my macbook, but still the same problem… very weird!
                        (note that the ‘updateinterval’ is modified when posting the message)
                        • 11
                        • 12
                        • 1 / 12
