    MMM-Globe
    119 Posts 39 Posters 237.9k Views 40 Watching
    • G
      gshimself
      Cool and interesting! Im gonna try it out and see how it works. :)
      • iMAGiCI
        iMAGiC
        Implemented, thank you!
        Choice * Judgment * Values
        • L
          LukeCodewalker Module Developer @iMAGiC
          @iMAGiC & @gshimself: thanks for your feedback. would it be possible, that one of you could post a picture of the module on a mirror. I just started building mine (don’t have the glass yet) and would like to know how it looks on a mirror. right now I can only look at it on my monitor.
          iMAGiCI 1 Reply Last reply Reply Quote 0
          • iMAGiCI
            iMAGiC @LukeCodewalker
            @LukeCodewalker my mirror will be built in my new living room on Jan, 2017.
            this is my test screen(22") with glass+film, I think you also want to see.
            L N 2 Replies Last reply Reply Quote 4
            • L
              @iMAGiC wow that looks great =)
              • N
                Novocain @iMAGiC
                @iMAGiC
                Ni hao, fei chang hao :-)
                • G
                  GinSeng
                  @LukeCodewalker great work! Thanks for this module, i already tested it. I will upload a picture tomorrow.
                  But i have one question. Is it possible to fade the image ? Like its getting darker and brighter after time in repeat?
                  • L
                    LukeCodewalker Module Developer @GinSeng
                    @GinSeng
                    Thank you. I don’t really understand what you mean with fade. Do you want to have a fade between to images in the moment when a new picture was loaded? Or do you want to fade it over a longer time? Then you should try ‘natColor’ as the style property in your config for this module.
                    • G
                      GinSeng @LukeCodewalker
                      @LukeCodewalker
                      Yes i want to fade one picture over a longer time. Like an LED Fading on/off over a periodic time. But i managed to do it with a gif, i created.
                      Btw.: Here is a picture which i promised :) i used a custom picture. (It’s in the dark because the mirror isn’t complete by now and the monitor i use atm isn’t really the best :/ 0_1479547035036_2016-11-18_22-32-39_811.jpg
                        matt25
                        Have an issue with the module. Nothing display, only some lines…
                        I had a look at the code. The generated URL is correct, when I copy it into a browser I can see the picture:
                        http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_true_color.jpg?1479826211800
                        Then had a look at wrapper and image objects (in getDom) and display their attributes, everything seems ok.
                        All other modules works fine on my raspberry. Any help would be welcome, thanks in advance.
                        By the way, my config:
                            module: 'MMM-Globe',
                            position: 'center',
                                style: 'geoColor',
                                imageSize: 600,
                                ownImagePath:'',
                                updateInterval: 10*60*1000
                        Thank a lot.
                        Matt
                        • G
                          GinSeng
                          @matt25
                          Hi Matt, try at position : ‘middle_center’ not only center.
                          M Andrius okA 2 Replies Last reply Reply Quote 0
                            matt25 @GinSeng
                            @GinSeng
                            Hi Ginseng, thanks for your help. Already tried different positions but no success:
                                position: 'middle_center',
                                    style: 'geoColor',
                                    imageSize: 600,
                                    ownImagePath:'',
                            Also tried the module locally on my macbook, but still the same problem… very weird!
                            (note that the ‘updateinterval’ is modified when posting the message)
                            • L
                              LukeCodewalker Module Developer @matt25
                              @matt25 Puh. I don’t get what’s going wrong here. Could it be possible that there’s another module is having influence? Maybe you could show us your whole config file.
                                matt25 @LukeCodewalker
                                @LukeCodewalker
                                That’s what I thought… I even removed all the modules but no success!
                                Here’s my last config file…
                                */* Magic Mirror Config Sample
                                * MIT Licensed.
                                var config = {
                                	port: 8080,
                                	language: 'en',
                                	timeFormat: 24,
                                	units: 'metric',
                                			module: 'alert',
                                			module: 'clock',
                                			position: 'top_left'
                                			module: 'newsfeed',
                                			position: 'bottom_bar',
                                				feeds: [
                                						title: "New York Times",
                                				showSourceTitle: true,
                                				showPublishDate: true
                                				style: 'geoColor',
                                				imageSize: 200,
                                				ownImagePath:'',
                                if (typeof module !== 'undefined') {module.exports = config;}*
                                  binderth @LukeCodewalker
                                  @LukeCodewalker said in MMM-Globe:
                                  Hey guys,
                                  here is a module for displaying live pictures of our planet on your mirror.
                                  The pictures are taken from the Himawari-8 satellite.
                                  It’s also possible to use custom pictures.
                                  Thanks! Looks huge on my MagicMirror!
                                  Did you come across a live pic feed of a different satellite? I’m thinking of one, which has Europe and not Asian Pacific in the center! ;) Would be great to have a switch, so it would show the live shadows of my Position.
                                  greets,
                                  Thomas.
                                  • L
                                    lolobyte @binderth
                                    @binderth
                                    i replacded the original links in the MMM-Globe.js for the image with this:
                                        start: function () {
                                                self = this;
                                                this.url = '';
                                                this.imageUrls = {
                                                        'natColor': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBNatColour_LowResolution.jpg',
                                                        'geoColor': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_IR108Color_LowResolution.jpg',
                                                        'airMass': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBAirmass_LowResolution.jpg',
                                                        'fullBand': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_MPE_LowResolution.png'
                                                this.hiResImageUrls = {
                                    good luck
                                      binderth @lolobyte
                                      @lolobyte said in MMM-Globe:
                                      EUMETSAT_MSG_MPE_LowResolution.png’
                                      That’s great! I did this:
                                      	self = this;
                                      	this.url = '';
                                      	this.imageUrls = {
                                      		'natColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_natural_color.jpg',
                                      		'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_true_color.jpg',
                                      		'airMass': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_rgb_airmass.jpg',
                                      		'fullBand': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/himawari-8_band_03_sector_02.gif',
                                      		'europeDiscNat': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBNatColour_LowResolution.jpg',
                                      		'europeDiscSnow': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBSolarDay_CentralEurope.jpg'
                                      		'natColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_natural_color.jpg',
                                      		'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                                      		'airMass': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_rgb_airmass.jpg',
                                      		'europePartSnow': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBSolarDay_CentralEurope.jpg'
                                      	console.log(this.imageUrls[this.config.style]);
                                      So, you can choose from more Images.
                                      • europeDiscNat: natural Color Europe Picture
                                      • europeDiscSnow: snow!!! ;)
                                      config.js
                                      		position: 'center',
                                      			style: 'europeDiscNat',
                                      			imageSize: 600,
                                      			ownImagePath:'',
                                      If I have a bit more time, I’d like to add the standard ones and make a pull request to choose from. There’s a list of (near) real-time images from EUMETSAT: http://oiswww.eumetsat.org/IPPS/html/latestImages.html
                                      S S 2 Replies Last reply Reply Quote 3
                                        binderth @lolobyte
                                        only Problem with these images are the white bottomline, on my MM it looks like this:
                                        0_1483012096329_upload-dda9a5c9-d918-4dc6-b35c-ecf790791bed
                                        sadly, there’s some white capping down there, but I guess we have to live with that - real time cropping of images won’t make the PIs any faster! ;)
                                        L S 2 Replies Last reply Reply Quote 0
                                        • L
                                          lolobyte @binderth
                                          @binderth
                                          yes, i know. That’s the south pole. ;-))
                                          Pull request, good idea.
                                          The Images are better then nothing.
                                          I searched for a better view for Europe with full disk, but nothing found.
                                          Maybe other sources from other user here?
                                            schlachtkreuzer6 @binderth
                                            @binderth niiiice! :)
                                            • 1 / 6
