    MMM-Globe
    119 Posts 39 Posters 239.7k Views 40 Watching
    • G
      GinSeng @LukeCodewalker
      @LukeCodewalker
      Yes i want to fade one picture over a longer time. Like an LED Fading on/off over a periodic time. But i managed to do it with a gif, i created.
      Btw.: Here is a picture which i promised :) i used a custom picture. (It’s in the dark because the mirror isn’t complete by now and the monitor i use atm isn’t really the best :/ 0_1479547035036_2016-11-18_22-32-39_811.jpg
        matt25
        Have an issue with the module. Nothing display, only some lines…
        I had a look at the code. The generated URL is correct, when I copy it into a browser I can see the picture:
        http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_true_color.jpg?1479826211800
        Then had a look at wrapper and image objects (in getDom) and display their attributes, everything seems ok.
        All other modules works fine on my raspberry. Any help would be welcome, thanks in advance.
        By the way, my config:
            module: 'MMM-Globe',
            position: 'center',
                style: 'geoColor',
                imageSize: 600,
                ownImagePath:'',
                updateInterval: 10*60*1000
        Thank a lot.
        Matt
        • G
          GinSeng
          @matt25
          Hi Matt, try at position : ‘middle_center’ not only center.
          M Andrius okA 2 Replies Last reply
            matt25 @GinSeng
            @GinSeng
            Hi Ginseng, thanks for your help. Already tried different positions but no success:
                position: 'middle_center',
                    style: 'geoColor',
                    imageSize: 600,
                    ownImagePath:'',
            Also tried the module locally on my macbook, but still the same problem… very weird!
            (note that the ‘updateinterval’ is modified when posting the message)
            LukeCodewalkerL 1 Reply Last reply
            • LukeCodewalkerL
              LukeCodewalker Module Developer @matt25
              @matt25 Puh. I don’t get what’s going wrong here. Could it be possible that there’s another module is having influence? Maybe you could show us your whole config file.
              M 1 Reply Last reply
                matt25 @LukeCodewalker
                @LukeCodewalker
                That’s what I thought… I even removed all the modules but no success!
                Here’s my last config file…
                */* Magic Mirror Config Sample
                * MIT Licensed.
                var config = {
                	port: 8080,
                	language: 'en',
                	timeFormat: 24,
                	units: 'metric',
                			module: 'alert',
                			module: 'clock',
                			position: 'top_left'
                			module: 'newsfeed',
                			position: 'bottom_bar',
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                				style: 'geoColor',
                				imageSize: 200,
                				ownImagePath:'',
                if (typeof module !== 'undefined') {module.exports = config;}*
                • binderthB
                  binderth @LukeCodewalker
                  @LukeCodewalker said in MMM-Globe:
                  Hey guys,
                  here is a module for displaying live pictures of our planet on your mirror.
                  The pictures are taken from the Himawari-8 satellite.
                  It’s also possible to use custom pictures.
                  Thanks! Looks huge on my MagicMirror!
                  Did you come across a live pic feed of a different satellite? I’m thinking of one, which has Europe and not Asian Pacific in the center! ;) Would be great to have a switch, so it would show the live shadows of my Position.
                  greets,
                  Thomas.
                  lolobyteL 1 Reply Last reply
                  • lolobyteL
                    lolobyte @binderth
                    @binderth
                    i replacded the original links in the MMM-Globe.js for the image with this:
                        start: function () {
                                self = this;
                                this.url = '';
                                this.imageUrls = {
                                        'natColor': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBNatColour_LowResolution.jpg',
                                        'geoColor': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_IR108Color_LowResolution.jpg',
                                        'airMass': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBAirmass_LowResolution.jpg',
                                        'fullBand': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_MPE_LowResolution.png'
                                this.hiResImageUrls = {
                    good luck
                    binderthB 2 Replies Last reply
                    • binderthB
                      binderth @lolobyte
                      @lolobyte said in MMM-Globe:
                      EUMETSAT_MSG_MPE_LowResolution.png’
                      That’s great! I did this:
                      	self = this;
                      	this.url = '';
                      	this.imageUrls = {
                      		'natColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_natural_color.jpg',
                      		'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_true_color.jpg',
                      		'airMass': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/full_disk_ahi_rgb_airmass.jpg',
                      		'fullBand': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest/himawari-8/himawari-8_band_03_sector_02.gif',
                      		'europeDiscNat': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBNatColour_LowResolution.jpg',
                      		'europeDiscSnow': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBSolarDay_CentralEurope.jpg'
                      		'natColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_natural_color.jpg',
                      		'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                      		'airMass': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_rgb_airmass.jpg',
                      		'europePartSnow': 'http://oiswww.eumetsat.org/IPPS/html/latestImages/EUMETSAT_MSG_RGBSolarDay_CentralEurope.jpg'
                      	console.log(this.imageUrls[this.config.style]);
                      So, you can choose from more Images.
                      • europeDiscNat: natural Color Europe Picture
                      • europeDiscSnow: snow!!! ;)
                      config.js
                      		position: 'center',
                      			style: 'europeDiscNat',
                      			imageSize: 600,
                      			ownImagePath:'',
                      If I have a bit more time, I’d like to add the standard ones and make a pull request to choose from. There’s a list of (near) real-time images from EUMETSAT: http://oiswww.eumetsat.org/IPPS/html/latestImages.html
                      schlachtkreuzer6S S 2 Replies Last reply
                      Reply Quote 3
                      • binderthB
                        binderth @lolobyte
                        only Problem with these images are the white bottomline, on my MM it looks like this:
                        0_1483012096329_upload-dda9a5c9-d918-4dc6-b35c-ecf790791bed
                        sadly, there’s some white capping down there, but I guess we have to live with that - real time cropping of images won’t make the PIs any faster! ;)
                        lolobyteL schlachtkreuzer6S 2 Replies Last reply
                        • lolobyteL
                          lolobyte @binderth
                          @binderth
                          yes, i know. That’s the south pole. ;-))
                          Pull request, good idea.
                          The Images are better then nothing.
                          I searched for a better view for Europe with full disk, but nothing found.
                          Maybe other sources from other user here?
                          C 1 Reply Last reply
                          • schlachtkreuzer6S
                            schlachtkreuzer6 @binderth
                            @binderth niiiice! :)
                            • schlachtkreuzer6S
                              @binderth the globe is cut at south pole area, i think the white slice down there is the background color
                              so i think the module cut a circle out of the webpage and down there is some part of the earth missing, or out of view. Also i got another issue: If I´m using the random Photo Module as background, i see a small black border around the full globe. So to fix that, there must be an adjustment for the size of the cutting circle. But anyway the main problem with that white slice is, the image source.
                              SvenSommerS 1 Reply Last reply
                                shgmongohh @binderth
                                @binderth
                                Very nice work!
                                It would be awesome, if you could add the real time images!
                                Sebastian
                                schlachtkreuzer6S 1 Reply Last reply
                                Reply Quote -1
                                • schlachtkreuzer6S
                                  schlachtkreuzer6 @shgmongohh
                                  @shgmongohh that would be awesome! thank you in advance :)
                                  • SvenSommerS
                                    SvenSommer @schlachtkreuzer6
                                    @schlachtkreuzer6
                                    Hey guys,
                                    I was able to cut the white bar by cutting the last pixels (depending on the image size) from this image with adding the following to MMM-Globe.js
                                    getDom: function () {
                                        if (this.config.style == "europeDiscNat") {
                                    	wrapper.style.height = 0.98 * this.config.imageSize - 1 + "px";
                                    	wrapper.style.overflow = "hidden";
                                        var image = document.createElement("img");
                                    Looking for some building inspiration?
                                    Check out my large, thin and metal framed mirror on robstechlog.com.
                                    Modules released:
                                    MMM-GoogleAnalytics
                                    MMM-GrafanaChart
                                    MMM-GrafanaGauges
                                    • schlachtkreuzer6S
                                      schlachtkreuzer6 @SvenSommer
                                      @SvenSommer Nice work! Thanks. Post it on github as well :)
                                      • SvenSommerS
                                        @schlachtkreuzer6
                                        done, I also included the sources from binderth and made a pull request.
                                        Modules released:
                                        MMM-GoogleAnalytics
                                        MMM-GrafanaChart
                                        MMM-GrafanaGauges
                                        LukeCodewalkerL lolobyteL 2 Replies Last reply
                                        • LukeCodewalkerL
                                          LukeCodewalker Module Developer @SvenSommer
                                          @SvenSommer
                                          could you please adjust the README.md that it contains your additional image-styles? then i will merge your pull request =)
                                          thanks for your help improving the module
                                          • lolobyteL
                                            lolobyte @SvenSommer
                                            @SvenSommer
                                            Wrong, the picture source information was from me.
                                            You can read my first entry above the post from @binderth !
                                            • 1 / 6
