    No stream output from webcam. No errors raised.
    12 Posts 5 Posters 4.9k Views 5 Watching
    • H
      hsalas
      I’m trying to use a USB Logitech webcam on my raspberry pi 4 running a magic mirror. I tested the webcam via a webcam test website in my raspberry pi and it works; however, it doesn’t in the magic mirror nothing displays. This is what I tried so far:
      Added camera module to config.js
      Changed in camera.js -> display: true
      updated my raspberry pi
      updated magic mirror
      node version in raspberry pi is 14.15.0
      Any help or advice is greatly appreciated. Thank you in advance.
        sdetweil @hsalas
        @hsalas what module are u using for webcam display? nothing is built in
        H 1 Reply Last reply
        • H
          hsalas @sdetweil
          @sdetweil Hi Sam, im using https://github.com/alexyak/camera.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @hsalas
            @hsalas
            You set up your models (.pmdl files) for the voicecontrol module?
            S H 2 Replies Last reply
              sdetweil @Mykle1
              @Mykle1 hey is asking about displaying video
              • H
                hsalas @Mykle1
                @Mykle1 Hi Mykle1, I haven’t however the stream should start as soon as the magicmirror comes up without me saying anything to the voice control. I changed the following to true in camera.js:
                display: true
                I have the same setup on windows pc and it works; however, when doing the same with the same webcam on the raspberry I get no stream.
                Windows PC
                Y 1 Reply Last reply
                • Y
                  yax51
                  I am having the exact same issue. I have also made the same changes that you have.
                  Were you able to get it fixed?
                  A 1 Reply Last reply
                  • A
                    Axel51 @yax51
                    I have the same problem with my usb cam.
                    So, i installed Motion and then I used the iShow module to show the stream of the cam.
                    but that’s was not easy.
                    • Y
                      yax51 @Axel51
                      @Axel51 I wasn’t able to find any iShow module…Can you send a link>
                      • A
                        Axel51 @yax51
                        @yax51 https://github.com/l0b5ter/iShow
                        • Y
                          yax51 @Axel51
                          @Axel51 Thanks! I’ll check it out!
                          • Y
                            yax51 @hsalas
                            @hsalas After thinking about it, I came to the conclusion that it had more to do with the power usage of the raspberry pi than any sort of code/module issue. I noticed I was getting low power notices while just trying to use the webcam. Even using webcamoid would lag, stutter, and give those errors. So I installed Ubuntu 20.04 on a mini desktop, installed MM and the modules (with some tweaking to get pyaudio working) I had no issues, and everything worked perfectly.
                            Which means it’s either the pi itself not having enough power, the webcam you are using is drawing too much power, or a combination of both.
                            Might be worth exploring
