    Update auf 2.13.0
    65 Posts 4 Posters 24.8k Views 4 Watching
    • kusselinK Offline
      kusselin
      O.K. danke Dir
      • kusselinK Offline
        kusselin
        habe eben probiert das update zu machen mit folgendem Befehl:
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        dann kommt aber folgende Melsung:
        pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetwe                 il/MagicMirror_scripts/master/upgrade-script.sh)" apply
        No LSB modules are available.
        doing test run = false
        saving custom.css
        upgrading from version 2.9.0 to 2.13.0
        fetching latest revisions
        error: cannot lock ref 'refs/tags/v2.12.0': unable to resolve reference 'refs/ta                 gs/v2.12.0': reference broken
        From https://github.com/MichMich/MagicMirror
         ! [new tag]           v2.12.0    -> v2.12.0  (unable to update local ref)
        MagicMirror git fetch failed
        restoring custom.css
        Wo ist mein Fehler?
        Gruss
          sdetweil @kusselin
          @kusselin let me look. can u send me the upgrade.log from the installers folder?
          my email in this same userid at gmail
          • kusselinK Offline
            kusselin
            @sdetweil said in Update auf 2.13.0:
            Upgrade started - So Nov 15 12:26:19 CET 2020
            system is Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
            user requested to apply changes
            saving custom.css
            remote name = origin
            git fetch rc=1
            removing git alias
            Upgrade ended - So Nov 15 12:26:23 CET 2020
            Upgrade started - So Nov 15 12:26:55 CET 2020
            saving custom.css
            git fetch rc=1
            removing git alias
            Upgrade ended - So Nov 15 12:26:59 CET 2020
            Upgrade started - So Nov 15 12:27:33 CET 2020
            saving custom.css
            git fetch rc=1
            removing git alias
            Upgrade ended - So Nov 15 12:27:37 CET 2020
              sdetweil @kusselin
              @kusselin try this
              git remote prune origin
              then run in test mode (no apply param)
              • kusselinK Offline
                kusselin
                hi sdetweil schau hier:
                pi@raspberrypi:~/MagicMirror $ git remote prune origin
                pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                saving custom.css
                error: cannot lock ref 'refs/tags/v2.12.0': unable to resolve reference 'refs/tags/v2.12.0': reference broken
                das gleiche wieder :-(
                  sdetweil @kusselin
                  @kusselin said in Update auf 2.13.0:
                  reference broken
                  ok, one more time
                  git gc --prune=now
                  then script again
                  • kusselinK Offline
                    kusselin
                    pi@raspberrypi:~ $ cd MagicMirror
                    pi@raspberrypi:~/MagicMirror $ git gc --prune=now
                    fatal: bad object refs/tags/v2.12.0
                    fatal: failed to run repack
                    saving custom.css
                      ok, another try
                      git remote set-head origin --auto
                      git gc --prune=now
                      • kusselinK Offline
                        kusselin
                        saving custom.css
                        Wo ist das Problem…ist klar…bei mir läuft nie was auf Anhieb :-(
                        der Pi ist auf aktuellem Stand mit update && upgrade
                        • 1 / 7
