    How to implement specific module?
    12 Posts 6 Posters 9.5k Views 6 Watching
      Jeff
      I’m trying to implement the weather module from thobach (https://github.com/thobach/MagicMirror2.git).
      The module is based on html. That’s new to me for the moduls… well everything is new to me on Magic Mirror.
      How do I get all the stuff in the “web” folder running?
      Where do I put each file and so on?
      Would be great if you will also tell me the commands :)
      Hope you can help me.
        roramirez Core Contributors
        How is based in HTML?, do you not have a API?.
        First, I recomend you check the module helloworld and currentweather of MagicMirror, is inside modules/default. Try understand how work.
        Also, check the MagicMirror² Module Development Documentation
        • bheplerB Offline
          bhepler Module Developer @Jeff
          @Jeff Installing new modules is a pretty easy process. In general, it goes like this:
          • Navigate to the modules directory at ~/MagicMirror/modules
          • Download the module code using git: git clone [url]
          • Run any commands that the module requires. This will vary by module
          • Update the config.js file to configure the new module. There should be an example in the module readme. sudo nano ~/MagicMirror/config/config.js
          • Restart your mirror so the new configuration will be implemented. npm restart
            Jeff
            Both of you thanks to your reply.
            I can handle adding “normal” moduls, like the instagram modul…
            But I think this one is build in a different way.
            Can somebody try to implement it and tell me how to do it?
            E.g. I’m not sure what to put in the config.js and I can’t find a documentation about it.
            Just have a look, what I meant with html file:
            https://github.com/thobach/MagicMirror2/tree/master/web
            • yawnsY Offline
              yawns Moderator @Jeff
              @Jeff said in How to implement specific module?:
              Right, the mirror github repository looks like a custom and way more simple version of “our” magicmirror. So there is no easy way to add this as a module to the magicmirror. It is written in AngularJS instead of nodeJS.
              What exactly makes you want this module? It just derives data from weather underground.
                Jeff @yawns
                @yawns
                okay thanks for explaining the languages.
                I like the way it looks, that’s the only reason I’m trying to get it.
                It shows the min and max temp of the next days in a graph
                alt text
                • yawnsY Offline
                  yawns Moderator
                  Ok, got it.
                  Maybe you want to check out https://forum.magicmirror.builders/topic/506/mmm-weatherchart
                  I know it is not the same but it is the same direction.
                  Otherwise you could post a request in the module / request forum, including this screenshot:
                  Bild Text
                  I don’t know if I find some time on Sunday to look at it.
                    Jeff @yawns
                    @yawns
                    I pulled a request, let’s see what will come.
                    Thanks for your hint and the other modul.
                    I’ll give it a try
                      Jeff
                      Is it possible to get the moduls html running with the iframe modul?
                      https://github.com/desertblade/iFrame
                        Jeff @bhepler
                        @bhepler said in How to implement specific module?:
                        Do I also have to run npm update everytime auf git clone?
                        Or does that belong to point 3?
