    How to implement specific module?
    12 Posts 6 Posters 10.0k Views 6 Watching
      Jeff
      I’m trying to implement the weather module from thobach (https://github.com/thobach/MagicMirror2.git).
      The module is based on html. That’s new to me for the moduls… well everything is new to me on Magic Mirror.
      How do I get all the stuff in the “web” folder running?
      Where do I put each file and so on?
      Would be great if you will also tell me the commands :)
      Hope you can help me.
        roramirez Core Contributors
        How is based in HTML?, do you not have a API?.
        First, I recomend you check the module helloworld and currentweather of MagicMirror, is inside modules/default. Try understand how work.
        Also, check the MagicMirror² Module Development Documentation
        • bheplerB Offline
          bhepler Module Developer @Jeff
          @Jeff Installing new modules is a pretty easy process. In general, it goes like this:
          • Navigate to the modules directory at ~/MagicMirror/modules
          • Download the module code using git: git clone [url]
          • Run any commands that the module requires. This will vary by module
          • Update the config.js file to configure the new module. There should be an example in the module readme. sudo nano ~/MagicMirror/config/config.js
          • Restart your mirror so the new configuration will be implemented. npm restart
            Jeff
            Both of you thanks to your reply.
            I can handle adding “normal” moduls, like the instagram modul…
            But I think this one is build in a different way.
            Can somebody try to implement it and tell me how to do it?
            E.g. I’m not sure what to put in the config.js and I can’t find a documentation about it.
            Just have a look, what I meant with html file:
            https://github.com/thobach/MagicMirror2/tree/master/web
            • yawnsY Offline
              yawns Moderator @Jeff
              @Jeff said in How to implement specific module?:
              Right, the mirror github repository looks like a custom and way more simple version of “our” magicmirror. So there is no easy way to add this as a module to the magicmirror. It is written in AngularJS instead of nodeJS.
              What exactly makes you want this module? It just derives data from weather underground.
                Jeff @yawns
                @yawns
                okay thanks for explaining the languages.
                I like the way it looks, that’s the only reason I’m trying to get it.
                It shows the min and max temp of the next days in a graph
                alt text
                • yawnsY Offline
                  yawns Moderator
                  Ok, got it.
                  Maybe you want to check out https://forum.magicmirror.builders/topic/506/mmm-weatherchart
                  I know it is not the same but it is the same direction.
                  Otherwise you could post a request in the module / request forum, including this screenshot:
                  Bild Text
                  I don’t know if I find some time on Sunday to look at it.
                    Jeff @yawns
                    @yawns
                    I pulled a request, let’s see what will come.
                    Thanks for your hint and the other modul.
                    I’ll give it a try
                      Jeff
                      Is it possible to get the moduls html running with the iframe modul?
                      https://github.com/desertblade/iFrame
                        Jeff @bhepler
                        @bhepler said in How to implement specific module?:
                        Do I also have to run npm update everytime auf git clone?
                        Or does that belong to point 3?
                        • strawberry 3.141S Offline
                          strawberry 3.141 Project Sponsor Module Developer @Jeff
                          @Jeff the instructions of @bhepler are based on magicmirror2 modules, the module you came up with is based on mm1 and is incompatible with mm2 so mayber there were also different instructions for them.
                          you can but you don’t have to run npm update if the readme doesn’t explicitly points it out, this command will only check for newer versions of the dependencies and update those.
                          • chamaeleon82C Offline
                            chamaeleon82
                            @Jeff - You can easily integrate this module with iFrame Module. You only need to update the iFrame page via javascript. Not perfect but running up until I’ve found a better way.
