    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.5k Views 6 Watching
      Bangee Module Developer
      yeah, no problem. today my calendar is running. I’ve made no changes…
      strange, I’ve sent you the link to the working one.
      Thanks! :hand_splayed_tone1:
        @MichMich did you find the problem?
        MichMichM 1 Reply Last reply Reply Quote 0
        • MichMichM
          MichMich @Bangee
          @Bangee Did not have any time to look into this … I’m sorry! Did I understand it correctly that you managed to solve it with the new calendar feed you sent me?
            i’ve sent you the working on. i don’t know why, but most of the time, the calendar is working find.
            And sometimes there is this bug. I’ve sent you a diff file, with the differences between the files.
              @MichMich I still have these problems with office365 calender :-(
              Did you found a solution for this issue?
              • MichMichM
                MichMich
                Did you tryout the develop branch yet? It might include some changes that could help you.
                • E
                  eugenelai
                  Any update on this? I’m also using office365 calendar and my Calendar randomly stopped working. I’ve tried the node debug.js and just get the below. @MichMich @KirAsh4
                  pi@rpi3:~/MagicMirror/modules/default/calendar $ sudo node debug.js
                  Create fetcher ...
                  Create fetcher done!
                  [ { title: 'Max',
                      startDate: '1493568000000',
                      endDate: '1493654400000',
                      fullDayEvent: true,
                      firstYear: 1990 },
                    { title: 'Someone',
                      startDate: '1493740800000',
                      endDate: '1493827200000',
                      fullDayEvent: true,
                      firstYear: 2010 },
                    { title: 'Another',
                      startDate: '1493913600000',
                      endDate: '1494000000000',
                      fullDayEvent: true,
                      firstYear: 2000 },
                    { title: 'Event',
                      startDate: '1494086400000',
                      endDate: '1494172800000',
                      fullDayEvent: true,
                      firstYear: 1980 } ]
                    nope, still same here… :-(
                      clumsy_ninja
                      I’m just starting with my MagicMirror today and am also having this issue.
                      I have two calendars,
                      1. Office 365 - gives this issue
                      2. google - loads, but doesn’t display all events in my calendar
                        so now I found something new:
                        in my Calendar the DTSTART is set to:
                        DTSTART;TZID="(UTC+00:00) Monrovia, Reykjavik":20161028T200000
                        when I remove (UTC+00:00) everything works fine.
                        Then it looks like this:
                        DTSTART;TZID="Monrovia, Reykjavik":20161028T200000
                        I’ve used a PHP Script to do this.
                        @MichMich can you implement this in the js script? or what will I need to replace for testing?
                                $ch = curl_init();
                                // set url
                                curl_setopt($ch, CURLOPT_URL, "https://ical.url/calendar.ics");
                                curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)");
                                curl_setopt($ch, CURLOPT_HEADER, false);
                                curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
                                curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
                                curl_setopt($ch, CURLOPT_COOKIEJAR, "blabla");
                                    // $output contains the output string
                                $output = curl_exec($ch);
                                // close curl resource to free up system resources
                                curl_close($ch);
                                $response = new Response();
                                $output = str_replace('(UTC+00:00) ', '', $output);
                                $response->setContent($output);
                                $response->setStatusCode(Response::HTTP_OK);
                                $response->headers->set('Content-type', 'text/calendar');
                                return $response;
                        • MichMichM
                          MichMich
                          I suggest you fork the project, implement the fix that works for you and send me a PR. That way you can test it and others can benefit from your solution. :)
                            Ok, :-) but actually I don’t no where to implement this in js :-)
                            Can someone give me a hint where to place my str_replace (UTC+00:00) in DTSTART variable?
                            Thanks ;-)
                              chadderwick
                              So I ran into this problem and have a fix. I have uploaded the files to drop box for know. If this fixes others, i’ll look into updating the project.
                              There are 2 files that need updated:
                              /home/pi/MagicMirror/modules/default/calendar/vendor/node-ical.js
                              line 33
                              https://dl.dropboxusercontent.com/u/1184191/node-ical.js
                              /home/pi/MagicMirror/modules/default/calendar/vendor/ical.js
                              line 97
                              https://dl.dropboxusercontent.com/u/1184191/ical.js
                                can you maybe post your solution? that would be great
                                thanks bangee
                                  chadderwick
                                  Apologies…my dropbox links dropped out.
                                  Here are the updated files:
                                  https://www.dropbox.com/sh/xvlusz1po4tvq24/AABF9ZuCL5j-ok4xfnYA5JsHa?dl=0
                                  This has not been tested with the latest version. I bought 6 different types of mirrors (glass and acrylic) and couldn’t find what i was looking for so gave up the dream for now…
                                    moshinh
                                    Does this work? Confirmed? I tried someone elses .js and it didnt :-(
                                      moshinh
                                      it does not :-(
